Author Topic: Laser Etched Key Caps  (Read 2188 times)
Offline cdamonsmith
« on: Sat, 30 November 2013, 00:50:52 »
I apologize if this has been discussed elsewhere, but I have a question regarding the laser etched key caps on a used black Dell AT101W I recently bought. The keyboard has been cleaned inside and out and everything is perfect (I actually like the black alps quite a bit), but the most often used key caps themselves are worn out.
My question is: is this a matter of cleaning? Is there a way I can get them bright white again? Or, because they are etched, is this just the black plastic underneath showing through?
If the latter is the case, what are my best options? Has anyone tried to Rit Dye laser etched key caps before? I might just try to erase the etchings completely rather than clean them up.
Thanks for any help. Also, this is the first time I've visited this forum in a couple years and DAMN has this place grown.
« Last Edit: Sat, 30 November 2013, 01:50:41 by cdamonsmith »
IBM M13 (13H6705)
Ione Scorpius M10
HHKB Lite 2
Offline davkol
  •  Post Editing Timeout
Re: Laser Etched Key Caps
« Reply #1 on: Sun, 01 December 2013, 09:42:13 »
Can you post a picture?
Anyway, I'd try plastidip. It creates coating that can last for a while and feel good IMHO.
« Reply #2 on: Wed, 04 December 2013, 20:18:20 »
ABS can be Retro-Brited but not dyed with RIT, because the activation temperature of the dye and the melt temperature of the plastic (190F-200F / 90C-95C) is about the same.
- D Trump 2026-09-28
