Author Topic: Any keyboards with Cherry switches mounted on a curved plate?  (Read 3610 times)
Offline spremino
« on: Wed, 04 December 2013, 09:05:33 »
Are there any keyboards with Cherry switches mounted on a curved plate, the way Unicomp keyboards do for BS?
I have found what looks like a USA patent for such a keyboard:
http://www.google.nl/patents/US4560844
But I can't find any implementations.
Thanks.
« Last Edit: Wed, 04 December 2013, 09:19:21 by spremino »
A long space bar... what a waste of space!
Re: Any keyboards with Cherry switches mounted on a curved plate?
« Reply #1 on: Wed, 04 December 2013, 09:18:16 »
Are there any keyboards with Cherry switches mounted on a curved plate, the way Dell AT101 did for ALPS switches,
What? I have completely disassembled two AT101Ws and an AT101 in the past week, and I can assure you that the plates are all flat.
"you've got to cheat like hell"
- D Trump - 2026-09-10 Dallas, Texas
"The pure products of America go crazy"
- William Carlos Williams - "For Elsie" 1942
Offline lonedruid
  • Red switch fan
« Reply #2 on: Wed, 04 December 2013, 09:19:45 »
Lol some serious **** u stumbled over on interblnet right there :cool:
Steelseries 6gv2 red switch
Ducky shine 3 TKL blue switch http://i.imgur.com/5LcUxh.jpg
HHKB Professional 2 no-blank http://i.imgur.com/JSIa1.pngk
Offline spremino
« Reply #3 on: Wed, 04 December 2013, 09:20:56 »
I have fixed my original post. Thanks.
I have never owned a Dell keyboard. I have looked only at a few pictures of disassembled ones and it looked like the plates were curved.
Offline suka
« Reply #4 on: Wed, 04 December 2013, 09:41:28 »
Are there any keyboards with Cherry switches mounted on a curved plate, the way Unicomp keyboards do for BS? I have found what looks like a USA patent for such a keyboard http://www.google.nl/patents/US4560844
Sue me, sue me  ;D
Wait: no mold, no circuit board, multiple curves - guess not then ...
Offline spremino
« Reply #5 on: Wed, 04 December 2013, 10:05:43 »
Suka, yours is an interesting alternative solution. I guess that afterwards you connected each switch by using wires, didn't you?
Offline MKULTRA
  • telling it how it is
« Reply #6 on: Wed, 04 December 2013, 10:16:40 »
I actually had this idea awhile ago and was discussing it with another member.  The only production board was the Kinesis which is an ergonomic keyboard.  It is definitely possible though.
Offline BearManJim
« Reply #7 on: Wed, 04 December 2013, 11:46:51 »
Wasn't sure whether Maltron keyboards mounted their switches onto a plate?
http://www.keyboardco.com/keyboard/maltrons-range-of-ergonomic-mechanical-keyboards.asp
The Maltron is very much not plate mounted ;-)  You'll know what I mean when I see one.  It's basically a contoured shaped piece of plastic with square holes cut in it (probably by hand, on the keyboard I've got) and Cherry switches push fit in there.
That's like how you'd plate mount the switches, I guess, except that the keyboard matrix wiring is done using *lots* of individual jumper wires point-to-point - there's no PCB.  If you're careful you can sometimes pop the switches out but you have to be careful not to break those connections.
I reckon for someone with more patience than me it should be possible to switch the mechanisms for MX blues.  I even have some donor switches here to try.  But it's likely to be a fairly fiddly operation and those usually result in me breaking things.  When I got this keyboard I had to fix a part of the keyboard matrix, which has left me with a desire not to do so again!
Guess not then...
That forum thread however linked to this interesting project mod;
http://geekhack.org/index.php?topic=16112.0
Noppoo Choc Mini 84S White (Gateron Black) - KBD75 (Grey, GMK screw-in stabs, Kailh BOX Navy, MAXKEY Foundation SA Keycaps)
Offline suka
« Reply #8 on: Wed, 04 December 2013, 12:07:01 »
Yes, exactly. Works really well and speeds up prototyping a lot since no PCB has to be designed and produced. You can find details on my boards in my DIY thread over at DT.
Offline spremino
« Reply #9 on: Wed, 04 December 2013, 12:22:50 »
Then you can bend a PCB... I didn't know that.
I started this thread because I realized that modern mechanical keyboards emulate a bent panel by sculpting key caps differently depending on their row. However, that makes key presses push not in plumb way over all switches. I guess that that could impact the response and feel of the switch, but I could be guessing wrongly.
« Last Edit: Wed, 04 December 2013, 12:29:12 by spremino »
