Author Topic: How bright are the Blue LEDs for Ducky Shine 3?  (Read 3034 times)
Offline Stevenator21
« on: Thu, 05 December 2013, 17:07:00 »
So I am buying a Ducky Shine 3 and wanted Cherry MX Browns + Blue LEDs. Then I heard that they are very bright and was wondering if it is actually that bad. Also do they impede on the simplistic look of the keyboard? Any help would be awesome!
Ducky Shine 3 TKL w/ Browns + White LEDs
Offline C5Allroad
  • Formerly HUNTERANGEL121
Re: How bright are the Blue LEDs for Ducky Shine 3?
« Reply #1 on: Thu, 05 December 2013, 17:39:14 »
They are amazing! They are bright, but it's not too bright maxed out. Then again you can always lower the brightness. This is the best board I have typed on.  ;D
It is a deeper blue than Corsair boards. Simply amazing.  :p
« Reply #2 on: Thu, 05 December 2013, 17:40:07 »
Alright I guess that settles it, I am getting the blue :D
Offline terran5992
  • One With The Cup Rubber
« Reply #3 on: Thu, 05 December 2013, 17:53:37 »
Is this your first board?
« Reply #4 on: Thu, 05 December 2013, 18:18:54 »
Yes, have had months of "lurking" and researching. Very excited for it.
Offline C5Allroad
« Reply #5 on: Thu, 05 December 2013, 19:28:31 »
Very good buy! Love mine. :p
« Reply #6 on: Thu, 05 December 2013, 20:13:19 »
Are there PBT's that can have light shine through them that I could put on this keyboard?
Offline C5Allroad
« Reply #7 on: Thu, 05 December 2013, 21:41:01 »
I think thin PBTs have light shine through but not legends. Max keyboard has a set that is ABS but is transparent.
Offline Linkbane
« Reply #8 on: Thu, 05 December 2013, 21:59:41 »
I have a QF TK, and light shines through perfectly well on the medium thick blank PBT. However, if you use legends, those won't shine through unless they're like the Ducky caps.
Quickfire TK MX Blue Corsair K60 MX Red Ducky Shine 3 Yellow TKL MX Blue Leopold FC660C
Current best: 162 wpm.
« Reply #9 on: Thu, 05 December 2013, 22:08:27 »
Imsto's white PBT lets quite a bit of light through. I used them over my KMAC and it looked pretty nice. I have some thin ABS that lets less light through.
Also, the PBT that TG3 uses in the BL82 and Deck 82 lets light through of course (it is designed for backlighting)
« Reply #10 on: Fri, 06 December 2013, 03:56:11 »
You can adjust the brightness levels.  My Shine 1 (one with red LED one with green LED) go from just about visible, all the way up to waaay too bright.
Also consider Ducky Shine Zero with blue LED - apparently that is a softer blue that is not as harsh on the eyes.
Offline C5Allroad
« Reply #11 on: Fri, 06 December 2013, 09:26:26 »
I don't know about you rowdy, but I really love harsh/deep blues on my boards lol. And my phone wallpaper on my phone. It's a solid, deep blue. I'm really happy with my shine, and I savor every moment with it. My fingers are massaged all day long.  :p
« Reply #12 on: Fri, 06 December 2013, 17:32:22 »
I'd prefer a deeper blue - the blue Zero Shine seems a bit washed-out to me, but apparently it is a very nice relaxing shade of blue.  Not that I have one.
« Reply #13 on: Fri, 06 December 2013, 18:31:54 »
I have not had a board yet, although I believe I would love the deep blue of the Shine 3.
« Reply #14 on: Fri, 06 December 2013, 18:33:47 »
Thanks for all the help, I am getting one for Christmas and am so excited! Getting the Ducky Sine 3 TKL w/ Cherry MX Browns + Blue LEDs! I am thinking I want to try o-rings, are there free sample packs circulating?
Offline C5Allroad
« Reply #15 on: Fri, 06 December 2013, 19:41:41 »
Grats! Not that I know of. But they are pretty cheap.
« Reply #16 on: Fri, 06 December 2013, 20:13:20 »
Actually, this makes me consider the White LEDs
quack quack...Shine II (Brown with white LEDs):
« Reply #17 on: Sat, 07 December 2013, 02:23:26 »
It's not free, but the WASD Sampler Kit contains a few O-rings (as well as keycaps and switches, although you can opt not to receive those to lower the cost).
