Author Topic: Clear coat for Plastic?  (Read 2863 times)
Offline Ghetto Caps
  • i make ghetto caps.
« on: Mon, 09 December 2013, 19:19:08 »
Ive been painting plastics such as caps and cases but I've never used clear coat.
What does clear coat do and where can i buy some in canada
Visit the Typing Test and try![/sigpic]
Offline do_Og@n
Re: Clear coat for Plastic?
« Reply #1 on: Thu, 12 December 2013, 01:33:59 »
I've been painting keycaps and cases for a little while now and for cases a simple clear coat will work but for keycaps you will want to use a couple layers of spray on lacquer. Or, if you have the resources some 2K clear coat works really well and doesn't give you nearly as much shine as lacquer does.
Offline IvanIvanovich
  • Mr. Silk Underwear
« Reply #2 on: Thu, 12 December 2013, 11:32:54 »
I was making some custom cap for fun a little bit with waterslides. Mostly impossible to find language sets for some friends. Obviously that isn't so durable so I used some Vallejo matte acrylic varnish. It's made for miniatures for like tabletop games and stuff so it's fairly durable. You should be able to find it at places that sell game miniatures or model kits.
As far as I know it's still holding up after more than a year since they haven't asked about redoing. They liked this better than keytop stickers anyway as far as feel.
« Last Edit: Thu, 12 December 2013, 11:35:23 by IvanIvanovich »
Offline Ghetto Caps
« Reply #3 on: Thu, 12 December 2013, 11:47:15 »
Oh.  I'm planning to hydro dipping carbon fiber case.  And I was thinking if I should use cleat coat
Offline PointyFox
« Reply #4 on: Thu, 12 December 2013, 11:48:42 »
From what I've read in the past, the instructions for that always have you put a clear coat on to protect it.
Offline C5Allroad
  • Formerly HUNTERANGEL121
« Reply #5 on: Fri, 13 December 2013, 09:03:53 »
Would on be able to use plasti-dip on caps?
