Author Topic: CM Storm QuickFire Ultimate Case  (Read 4992 times)
Offline ripper121
« on: Thu, 12 December 2013, 04:29:34 »
Hi,
is there any Top Replacement Case for CM Storm QuickFire Ultimate available?
Offline Ghetto Caps
  • i make ghetto caps.
Re: CM Storm QuickFire Ultimate Case
« Reply #1 on: Thu, 12 December 2013, 22:47:32 »
Im guessing you havent read the intro part
Visit the Typing Test and try![/sigpic]
Offline Ghetto Caps
« Reply #2 on: Thu, 12 December 2013, 22:49:41 »
Hi,
http://www.cmstore-usa.com/quickfire-rapid-replacement-top-panel/
its 9.99 after discount
Offline ripper121
« Reply #3 on: Fri, 13 December 2013, 01:54:45 »
And I guessing you haven't read the thread header.
I need it for the Ultimate and not for the rapid!
Offline MsYutai
« Reply #4 on: Fri, 13 December 2013, 10:44:54 »
You could always buy some Rapid replacement cases and practice painting on them. Once you think you have it down, then paint your Ultimate case. That's my plan, at least.
CM Storm Quickfire XT - MX Reds
Roccat Kone Pure Optical|Kana v2|Zowie FK|Logitech g500s|Mionix Naos 7000|CM Spawn|Logitech Performance MX
Offline Ghetto Caps
« Reply #5 on: Fri, 13 December 2013, 10:45:59 »
I'm guessing you can't get one.  Unless from the Classified.
 :p
Offline ripper121
« Reply #6 on: Fri, 13 December 2013, 17:49:35 »
Sure fore the ultimate and what is with the numpad of the keyboard?
