Author Topic: [SOLVED] IBM Model F 122-key: weight?  (Read 4852 times)
Offline spremino
« on: Fri, 13 December 2013, 09:34:47 »
How much does an IBM Model F 122-key weigh? Thanks.
« Last Edit: Fri, 13 December 2013, 15:35:40 by spremino »
A long space bar... what a waste of space!
Offline oTurtlez
  • DAT ZACKATTACK
  • Fo' Realforce
Re: IBM Model F 122-key: weight?
« Reply #1 on: Fri, 13 December 2013, 09:36:20 »
A lot. Like. Assault with a deadly weapon a lot.
EDIT: On a more relevant note, http://www.ebay.com/itm/IBM-Model-F-122key-Clicky-Keyboard-6110668-7-October-1985-tested-working-vintage-/181266908935?pt=PCA_Mice_Trackballs&hash=item2a34598707#viTabs_0 Contact that seller and ask for a shipping weight. My guess is somewhere in the realm of 7Lbs or so.
« Last Edit: Fri, 13 December 2013, 09:40:29 by oTurtlez »
TOO BAD FOR YOU
              Phantom 62g MX Whites
« Reply #2 on: Fri, 13 December 2013, 10:22:38 »
8.25 pounds
3.75 kilograms
There are 3 sheets of steel in these babies!
- D Trump 2026-10-24
Offline oTurtlez
  • DAT ZACKATTACK
  • Fo' Realforce
« Reply #3 on: Fri, 13 December 2013, 10:24:57 »
8.25 pounds
3.75 kilograms
Good lord! How heavy are the 122-key M's? I've got one of those and that thing is a tank too.
TOO BAD FOR YOU
« Reply #4 on: Fri, 13 December 2013, 10:26:40 »
I would estimate at least 2 pounds less.
