Author Topic: This has been a test. This has been updated  (Read 2473 times)
Offline OldDataHands
« on: Fri, 13 December 2013, 20:38:43 »
jeffgran noted that my datahand recreation project title needs to be updated - no longer first babysteps.
Now I need to be able to do that without screwing up.
I will try the process out on this thread.
« Last Edit: Fri, 13 December 2013, 20:40:40 by OldDataHands »
Re: This has been a test. This has been updated
« Reply #1 on: Fri, 13 December 2013, 20:39:40 »
Does it work by changing the subject in a new post?
Re: This is test. This will get updated
« Reply #2 on: Fri, 13 December 2013, 20:40:21 »
And what happens if I change it in the original to the subjects of the subsequent posts?
« Reply #3 on: Fri, 13 December 2013, 20:41:17 »
Your 2nd and 3rd posts will retain the old title. If you change the title in the first post, it will change the title of the thread and continue in the replied threads.
« Reply #4 on: Fri, 13 December 2013, 20:41:25 »
So, it looks like you just have to go back and modify the original post.
Easy as Pie.
« Reply #5 on: Fri, 13 December 2013, 20:42:19 »
Thanks CPT for the quick (as always!) response.
Offline Tym
« Reply #6 on: Fri, 13 December 2013, 20:45:16 »
You can also change the title of a thread responxe :)
Don't look here
« Reply #7 on: Fri, 13 December 2013, 22:15:09 »
Is that so Tym?
Offline Tym
TeeHee
« Reply #8 on: Sat, 14 December 2013, 08:37:23 »
Is that so Tym?
Only if yo OP bro, only if go OP ;D
« Reply #9 on: Sat, 14 December 2013, 08:48:50 »
