Author Topic: Profile difference between Pure Pro and Techkeys.us  (Read 3778 times)
Offline eosph
« on: Wed, 18 December 2013, 04:49:44 »
I've recently received two new keys for my Pure Pro (Hammer and Sickle and Radiation Symbol). I've replaced the escape key and back space key but they have a lower profile than the rest of the keys. It's not a huge issue but it's something I want to understand more.
Are the pure pro keys height none standard?
What type of keys would I have to buy to replace the entire lot if I wanted them the same height?
Once the Raindrop set goes backup on GB then I'll be buying a set of those will this be an issue on the Pure Pro?
Offline terran5992
  • One With The Cup Rubber
Re: Profile difference between Pure Pro and Techkeys.us
« Reply #1 on: Wed, 18 December 2013, 06:05:28 »
I guess that techkeys keycaps are cherry profile
« Reply #2 on: Wed, 18 December 2013, 06:44:29 »
Most of the regular novelty keys at techkeys are made by signature plastics and are SP DCS profile. It is similar to cherry profile but not quite the same.
Offline terran5992
« Reply #3 on: Wed, 18 December 2013, 06:58:21 »
ooops i had no idea
Offline eosph
« Reply #4 on: Wed, 18 December 2013, 07:07:50 »
Thanks for all the replies. I'll look out for cherry size key sets then.
  • Live long and prosper
« Reply #5 on: Wed, 18 December 2013, 07:18:58 »
Yeah, SP profile is a little shorter than Cherry IIRC.
Aren't GMK keys Cherry profile?
tp thread is tp thread
« Reply #6 on: Wed, 18 December 2013, 07:21:50 »
Yes GMK is the same as Cherry.
« Reply #7 on: Wed, 18 December 2013, 07:22:34 »
Thought so, thanks for confirming Ray.
« Reply #8 on: Wed, 18 December 2013, 07:47:59 »
Well if you want all the keys to match you can get in on any of the SP DCS group buys, they are really common around here, if you want that profile but if you want cherry there are also group buys for those you want to look for the term GMK , those are cherry profile key caps, or older cherry sets come up in classifieds as well.
Offline eosph
« Reply #9 on: Wed, 18 December 2013, 08:21:04 »
Is there anyway or sorting the GBs by ones that aren't closed?
« Reply #10 on: Wed, 18 December 2013, 08:30:00 »
No not really. Sometimes they update the title to reflect the status but not always.
« Reply #11 on: Wed, 18 December 2013, 13:16:06 »
Welcome to Geekhack!
The original keys are probably OEM profile - these are generally higher than Cherry, DSA or DCS profile keycaps.
« Reply #12 on: Wed, 18 December 2013, 14:20:02 »
They are OEM profile, I just checked,
Offline eosph
« Reply #13 on: Thu, 19 December 2013, 05:24:24 »
I think in the future I'm going to stay away from OEM sized keys, they're a bit too high for my liking. The techkeys profile is actually just right for me.
Also thanks for the welcome! Is there any way of getting rid of the captcha on post? I assure you I'm human!
Offline tbc
« Reply #14 on: Thu, 19 December 2013, 05:31:35 »
Don't be asking for 'techkeys' profile; no one will understand what you're talking about.
I think it's either 5 or 10 posts before the captcha goes away
Offline eosph
« Reply #15 on: Thu, 19 December 2013, 07:27:44 »
Sorry I meant cherry profile over oem.
Offline terran5992
« Reply #16 on: Thu, 19 December 2013, 08:28:14 »
Cherry profile is better for me. Alot more comfortable for typing IMO
