Author Topic: Key-bored  (Read 17955 times)
Offline billm
Key-bored
« Reply #50 on: Sun, 01 February 2009, 16:14:12 »
Quote from: lam47;20418
does the sleep watcher thing switch layouts based on the controller in each keyboard?
Does it work if you just pull one out and stick another in.
Hi lam47-
To answer the 2nd part of this question, no it doesn't work if you just pull out one keyboard and plug in another. Sleepwatcher just gives you a hook on sleep/wake. If anybody could tell me how I can run a script on a usb plug event on the mac I'd be ecstatic.
That said, you can also just execute the .wakeup script by hand and it'll do the correct remapping.
If it's not ALPS it's crap!
Offline lowpoly
Key-bored
« Reply #51 on: Sun, 01 February 2009, 16:22:46 »
Is there anything like that for Windows?
Offline billm
Key-bored
« Reply #52 on: Tue, 03 February 2009, 13:37:40 »
Quote from: xsphat;20502
Billm, KeyRemap4macbook is the best remapper for Mac I have ever used. There are so many options, but I only use one.
Hi xsphat-
Now that I have the RealForce, I'm curious what options to KeyRemap4macbook you're using. I'm trying to get this thing dialed in.
Seriously, why use any other board? I think I'm going to post my modded Filco on ebay this afternoon.
Offline xsphat
  • Enlightened
    • Dan Newman, Writer
Key-bored
« Reply #53 on: Tue, 03 February 2009, 22:26:37 »
Offline billm
my keyremap4macbook for RealForce 86U
« Reply #54 on: Thu, 05 February 2009, 17:20:11 »
This puts command & option in the correct places on both the left and right side of the space bar.
These are the kernel MIB variables, but its pretty obvious what GUI tick boxes they correspond to:
Code: [Select]
keyremap4macbook.general.dont_remap_internal: 1
keyremap4macbook.remap.commandL2optionL: 1
keyremap4macbook.remap.optionL2commandL: 1
keyremap4macbook.remap.optionR2commandL: 1
keyremap4macbook.remap.pc_application2optionL: 1
keyremap4macbook.initialized: 1
Offline xsphat
  • Enlightened
Key-bored
« Reply #55 on: Thu, 05 February 2009, 18:19:12 »
You're smarter than I am. I map the rest of the modifiers using System Preferences.
Offline banyanleaf
Key-bored
« Reply #56 on: Thu, 24 September 2009, 13:19:35 »
If I have the time and knowledge, I will convert an IBM ThinkPad 600E keyboard into a desktop keyboard. Even better, a wireless one.
