Author Topic: Custom PBT MX Cherry (TKL) keycaps?  (Read 7665 times)
Offline izzon
« on: Wed, 18 December 2013, 15:52:41 »
Hi.
    I've been looking through the thread for key caps, but I've failed to find any company that would let you customize your keycaps by the color that you want, and to also deliver them in PBT for nordic layout keyboards. I see a lot of companies that sell complete sets, but with ABS plastic and already pre-set color. What I was hoping for was something along the lines of how WASD keyboards do it (http://www.wasdkeyboards.com/index.php/products/mechanical-keyboard/wasd-v2-88-key-iso-custom-mechanical-keyboard.html#ad-image-0), but they ofcourse don't sell PBT ones. Any advice? :)
Steelseries 7G MX Cherry Black ABS | Ducky G2Pro TKL PBT MX Cherry Brown
Offline phoenix1234
Re: Custom PBT MX Cherry (TKL) keycaps?
« Reply #1 on: Wed, 18 December 2013, 21:37:24 »
I'm not sure if it is impossible but I think it is very unlikely to find anything like that.
Perhaps, the best you can do is either to :
- Buy Ducky Nordic PBT set
http://tigerimports.net/sunshop/index.php?l=product_detail&p=13383
- Buy a blank imsto PBT set and do the dyesub process by yourselves.
something like Ivan did with his sets, perhaps
http://geekhack.org/index.php?topic=52405.msg1162448#msg1162448
I like linear switches
Offline terran5992
  • One With The Cup Rubber
« Reply #2 on: Wed, 18 December 2013, 21:51:11 »
Nope i dont think they exist
Offline IvanIvanovich
  • Mr. Silk Underwear
« Reply #3 on: Wed, 18 December 2013, 22:26:50 »
It's simply not cost effective. To do a one off set it would be something like $60 for the keycaps set plus about $3 per key for dyesubbing or in other words $372 for ONE keycap set. Of course the other big problem with PBT is lack of ISO enters from most sources, and lack of keycap color selection without very high production minimum orders.
That G80-3000 in purple, it's just stock lasered keycap. I only dyed the key solid color myself.
« Last Edit: Wed, 18 December 2013, 22:29:13 by IvanIvanovich »
Offline Oobly
« Reply #4 on: Thu, 19 December 2013, 03:40:12 »
Hi.
Order a white PBT set and dye them yourself.
Buying more keycaps,
it really hacks my wallet,
but I must have them.
Offline terran5992
« Reply #5 on: Thu, 19 December 2013, 03:41:13 »
Hi.
Easier said than done
Offline izzon
« Reply #6 on: Thu, 19 December 2013, 08:06:36 »
The thing is that I already have PBT keycaps. I guess that if dyesubbing is legit, then that seems like the best solution. I've read up short about it, and I've got several older keyboards that are not in use that I could try it on.
What I'm curious about is how much work that would go into making sure that the surface doesn't get changed. It feels like the surface would change if this was not done properly/with the wrong sort of color.
« Last Edit: Thu, 19 December 2013, 08:08:12 by izzon »
Offline terran5992
« Reply #7 on: Thu, 19 December 2013, 08:25:32 »
The cost of gear required to dyesub your own keys is gonna be over the moon
