Author Topic: [WTB] i5-2500k 3570k motherboard and ram  (Read 1868 times)
Offline brialona
  • Trade Count: (0)
« on: Sat, 21 December 2013, 02:51:49 »
As the title says, looking for a combo of these in a good price range.  i am on a budget so i am not looking for anything too expensive.
ozil
Offline meiosis
  • Trade Count: (3)
  • Time
Re: [WTB] i5-2500k 3570k motherboard and ram
« Reply #1 on: Sat, 21 December 2013, 03:47:05 »
I know you said not so expensive but I have a Maximus V Formula (lga 1155) for $180 shipped conus :|.
Also have an i5 3570k I might be able to bundle if you can do mid 300's
Anyways good luck :)
Keyboards:
Aripeko TKL
Offline Chau
  • Trade Count: (0)
  • .5 Korean, .25 Vietnamese, .25 Chinese, Oz accent
« Reply #2 on: Sat, 21 December 2013, 04:49:36 »
I have an i5-2500k tray, only been tested. Never used.
Offline Elrick
  • Hype Master
  • Trade Count: (0)
  • Keyboard Orgasmist
« Reply #3 on: Sat, 21 December 2013, 05:09:37 »
Damn, nice price.  Rarely do you get a combo price of $300-350 for a decent cpu and flash motherboard  :thumb: .
Offline brialona
  • Trade Count: (0)
« Reply #4 on: Sun, 22 December 2013, 02:17:28 »
 thanks for the offer but i am looking for a cpu mobo ram combo for sub 300. I am on a budget
chau pmd
ozil
Offline tormentor
  • Trade Count: (0)
« Reply #5 on: Wed, 25 December 2013, 01:50:07 »
http://www.newegg.com/Product/Product.aspx?Item=N82E16820148540&nm_mc=EMC-IGNEFL122413&cm_mmc=EMC-IGNEFL122413-_-EMC-122413-Latest-_-DesktopMemory-_-20148540-L0H
You should of bought RAM around Black Friday. Newegg was selling G. Skills Ripjaws 2133 2x4 GB for $50. Oh well, to be honest I would never buy crucial memory but since budget is such a concern I listed it. Reason I wouldn't recommend crucial is because I received a set of these exact ram at 1.35 volt (these are 1.5 volt so they are not exactly the same mind you) free with my MOBO. First set had 1 dead stick, second RMA was the same. It wasn't until the 3rd set I got they both worked and I pawned them off on ebay for $40 because I didn't want to deal with it. Apparently the 1.35 volts were discontinued (Newegg was giving them out for free for a reason) http://www.newegg.com/Product/Product.aspx?Item=N82E16820148662 that's the set I had. I Ended up buying some Corsair Vengeance LP and don't regret it.
If Meiosis would seperate with just that i5 3570k for around $180 you should feel lucky. You might be able to find one on ebay for around $150 BIN if you're patient enough. Just be aware those particular ones probably got what is known as "bad silicone". It probably runs hot or something.
http://www.ebay.com/itm/MSI-Z77A-G41-LGA-1155-Socket-H2-Intel-Motherboard-/231121929065?pt=Motherboards&hash=item35cff0c369
Only 1 PCI-E X16 3.0 and only 2 Sata 6 ports but again, budget.
That would be $310 barring Meiosis selling the i5 for that or if you wanna wait to see it would be $280
« Last Edit: Wed, 25 December 2013, 19:03:59 by tormentor »
