Author Topic: Is it possible to buy an Ergo clear TKL keyboard?  (Read 4150 times)
Offline medvednic
« on: Sun, 22 December 2013, 13:45:47 »
Hello and happy holidays,
Is there any place that sells already modified TKL ergo clear keyboards?
thanks.
IBM Model M | CM Strom QFR Stealth MX Brown
Offline riotonthebay
  • Cherry Peasant
  • keycult.com
Re: Is it possible to buy an Ergo clear TKL keyboard?
« Reply #1 on: Sun, 22 December 2013, 13:47:20 »
You could probably get a custom board made, but your best bet is to buy one from somewhere here. They pop up in classifieds every once in a while.
Or, of course, you could make one yourself! I had a lot of fun doing it.
Offline Pacifist
  • on hiatus
« Reply #2 on: Sun, 22 December 2013, 14:22:35 »
you can't get ergo clear from big sellers like cm, filco, etc
but what you can do is search classifieds for an ergo clear board, or get 60 posts and make a wtb thread
Offline 1pq
  • Hipster Doofus
« Reply #3 on: Sun, 22 December 2013, 16:39:16 »
I'd recommend building one yourself. You can really customize it and build the best feeling board that way. That's what I'm doing currently :P
It can get pretty expensive though! The lube, switches, good key caps etc really do add up
main kbs:  87UB (55g)  Custom Filco TKL (62g clears)
WTS JD40, Custom Ergoclear Filco
WTB ROHS Red BBv2 (Topre), OG EK Tri-Color Skull (TOPRE)
  • Cherry Peasant
  • keycult.com
« Reply #4 on: Sun, 22 December 2013, 16:44:21 »
Here's a custom ergo-clear board being sold right now: http://geekhack.org/index.php?topic=51380.0
Offline meiosis
  • Time
« Reply #5 on: Sun, 22 December 2013, 16:50:20 »
Not a bad price at all full led, stickered. Cost around the same as a Filco +stufs
Keyboards:
Aripeko TKL
Offline dragonxx21
« Reply #6 on: Sun, 22 December 2013, 17:00:32 »
It doesn't include keycaps so I'm sure it'll cost a little bit more.
Keyboards Owned:
Realforce Topre 91 Key JIS Profile - Main
CM Quickfire Rapid Blue Switches
IBM Model M in Industrial Shell
Offline 1pq
  • Hipster Doofus
« Reply #7 on: Sun, 22 December 2013, 17:15:27 »
Less, actually: a filco is $150, switches are $50, plus lube, custom plate, springs, key caps, and loads of shopping...
That said, if you do it yourself you can make sure you're getting the best possible experience (with lube, etc).
Offline terran5992
  • One With The Cup Rubber
« Reply #8 on: Sun, 22 December 2013, 17:48:20 »
thanks.
You could get a code keyboard and mod it yourself
« Reply #9 on: Sun, 22 December 2013, 18:02:55 »
thanks.
The code with clears is not only equally hard to find but would be a nightmare to mod.... all those LED's.
Offline 1pq
  • Hipster Doofus
« Reply #10 on: Sun, 22 December 2013, 18:09:39 »
You could wait for a QFR with clears or just mod another board and just but the clears elsewhere...
Offline Oobly
« Reply #11 on: Mon, 23 December 2013, 02:01:25 »
That's really not a bad price! Add a set of Banggood PBT or POM caps and you have an awesome custom (LED's, red plate, acrylic case, 62g stickered and lubes ErgoClears, decent caps) for less than $250!.
Or get the retro or CCnG set he's also selling (although I don't think those sets go so well with a white case, personally).
Buying more keycaps,
it really hacks my wallet,
but I must have them.
