Author Topic: Annoying folding leg... any suggestions?  (Read 2096 times)
Offline LouisHjelmslev
  • This is all so complicated
« on: Fri, 27 December 2013, 14:44:46 »
I love my new fc660m, however whenever I push back my keyboard, the left leg always folds down. Very strange, as the right one never does. Any suggestions for a permanent fix? I don't want to do anything as drastic as gluing the leg open.
Offline Gniourf
  • Good feeling of oneness with cup rubber
Re: Annoying folding leg... any suggestions?
« Reply #1 on: Fri, 27 December 2013, 15:34:58 »
The best thing is to leave the legs closed! You'll see that your wrist will not be as tired after typing for a long period!
« Reply #2 on: Fri, 27 December 2013, 18:53:11 »
Otherwise, jam some rubbery object or substance in it.
- Plato
Offline Pacifist
  • on hiatus
« Reply #3 on: Wed, 29 January 2014, 22:49:35 »
A little bit of scotch tape on the side? Easy to take off and should hold it together. Otherwise more tape :))
« Reply #4 on: Wed, 29 January 2014, 22:52:12 »
return it, sounds defective
Offline domoaligato
« Reply #5 on: Thu, 30 January 2014, 17:45:02 »
my fc660C does the same thing. I am really only using it to test fit my custom caps on so I don't care enough to return it.
Offline tooki
« Reply #6 on: Fri, 31 January 2014, 08:40:06 »
Quoted for truth. A high slant is actually really bad for your wrists. (In reality, keyboards should have a slight negative slant, away from you!)
Offline Linkbane
« Reply #7 on: Fri, 31 January 2014, 14:09:15 »
I used to use the incline, but since I really type a lot, I figured it was better to learn to type without the angle, and it honestly took no time at all to switch over.
Quickfire TK MX Blue Corsair K60 MX Red Ducky Shine 3 Yellow TKL MX Blue Leopold FC660C
Current best: 162 wpm.
Offline quickcrx702
  • Ready to bomb with Vietnam tatted on my back
« Reply #8 on: Sun, 02 February 2014, 03:13:10 »
Get a desk with a glass top, WD40 on the bottom of the leg, or wipe your desk to make sure that there isn't anything causing friction?  Alternatively you could jam something like folded paper in where the clips rest to keep it propped out.  Having the legs popped out is more comfortable, and doesn't cause any strain typing for hours every day over a period of decades, that's my experience anyways.  You can also hide stuff under the keyboard better when the legs are popped up.
