Author Topic: Socket size for Model M  (Read 15083 times)
Offline tad
« on: Thu, 05 February 2009, 18:01:05 »
Just in case anyone was wondering, a 7/32" deep socket (at least the one made by Stanley) will NOT work to disassemble a Model M case. The size is too small to work. 5.5mm sockets are what you need.
Offline lam47
« Reply #1 on: Thu, 05 February 2009, 18:19:01 »
It should fit mate.
Do you have one there with you?
Keyboards. Happy Hacking pro 2 x2. One white one black. IBM model M US layout. SGI silicone Graphics with rubber dampened ALPS. IBM model F. ALPS apple board, I forget what it is. And some more I forget what I have.
Typewriters. Olivetti Valentine. Imperial Good Companion Model T. Olympia SM3
Offline tad
« Reply #2 on: Thu, 05 February 2009, 18:24:02 »
Yeah, I just purchased it. Doesn't even try to fit, it just turns smoothly on top of the nut.
Other 7/32" might work. This Stanley bit is smooth around the edge, while others might have the hex pattern extend out into the edge.
Offline lam47
« Reply #3 on: Thu, 05 February 2009, 18:29:38 »
That could be the problem. as 7/32 and 5.5 should be only very very slightly different.
Offline cchan
« Reply #4 on: Thu, 05 February 2009, 19:44:21 »
I have a Sears/Craftsman 7/32 deep socket (1/4" drive) that works fine on my 1989 Model M.
HP Envy17: Core i7-2760QM, 8GB DDR3, 128GB Crucial m4 + 750GB Hitachi, Windows 7 Home Premium x64, Cherry ML4100, Logitech M500, HP zr22w
IBM Thinkpad X60: Core Duo T2400, 2GB DDR2, 128GB Samsung 830, Xubuntu 12.04 x86, Cherry ML4100, Logitech M205, HP zr22w
Raspberry Pi Model B: BCM2835, 0.25GB DDR2, 8GB Samsung SD card, Raspbian Wheezy, human interaction devices as above
Offline tad
« Reply #5 on: Fri, 06 February 2009, 01:39:14 »
Does it fit completely over the nut, or does it just catch the edge?
Offline lal
« Reply #6 on: Fri, 06 February 2009, 05:57:08 »
If I understand this correctly, the 7/32" deep socket is too *small* to fit over the nut? Then I would say this thing is broken, as 7/32" equals 5,55625 mm and should therefore be five hundredths millimeter *bigger* than the 5,5 mm type. Of course only if I didn't just fail miserably in this what seems to be simple math... ;)
BS: Customizer, Model Ms; Alps: CSK-2101, FK-2002, AT-101 (SGI & Dell), MCK-860, FKBN87Z/EB; Cherry: Poker X, FKBN87MC/EB, WY60, G80-3000, G84-4100, TDV 5010
Offline lowpoly
« Reply #7 on: Fri, 06 February 2009, 06:24:03 »
Quote from: tad;20897
Maybe it's the outer diameter? Can't get it down to the screw.
Offline bhtooefr
    • bhtooefr.org
« Reply #8 on: Fri, 06 February 2009, 08:44:21 »
A Craftsman 7/32" deep socket fits loosely over the screws in the cases on my keyboards.
5.5 mm is correct, though.
Offline pex
« Reply #9 on: Fri, 06 February 2009, 09:14:10 »
I third or fourth move on the possibility that the 'deep socket' is just not so deep or is too big in outer diameter.
To think: if you use just any old 7/32 socket screwdriver, why don't those just work?  The answer is being too fat-headed...
⌨Ж®Cherry G80-8113 (someday I hope to have one that reads magstripes, rfid cards, and smartcards), ⌨broken \'98 42H1292 Model M, ⌨some other Model M from a decade before that, ⌨30 more keyboards in a box, ⌨4 more lying here or there
Destroying Sanctity: my Model M project. Status: Dead.
Offline ozar
« Reply #10 on: Fri, 06 February 2009, 14:31:57 »
Yep, I've found that some deep-well sockets will fit and other won't.  I purchased one from my local Ace Hardware that works perfectly.
Offline wellington1869
« Reply #11 on: Fri, 06 February 2009, 14:42:37 »
I got a 5.5 from ebay that works great, before that I had one of those 7/32 ones that worked too...
using: ms 7000/Das 3
Offline wumpyr
« Reply #12 on: Sat, 07 February 2009, 01:13:20 »
For any Aussies here, you can pick up a 5.5mm as part of a red handled set of 7 (japanese made) from Jaycar.  Don't bother trying Bunnings.
IBM Model M13 Raven Black \'96, \'97 (2), \'98 (2)
IBM Model M13 Industrial Gray \'96 (2)
IBM Model M Industrial Gray \'88, \'94
IBM Model M White Label 1391401 \'92
IBM Model M International \'95 (2), \'96
IBM Model M 52G9658 \'93
IBM Model M 1370475 Mini \'93
Offline nowsharing
  • Swoop
« Reply #13 on: Sun, 21 June 2009, 15:53:53 »
Sorry to dig up this old thread, but could someone please let me know if this tool looks like it would work to open up an M?
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&Item=270398091260&_trksid=p3286.m20.l1116
The seller offers $1 intl shipping, so I'd like to get this one if possible.
« Reply #14 on: Sun, 21 June 2009, 15:55:32 »
Quote from: nowsharing;98193
yes that will work -- although, it is me, or in the pic doesnt the socket end of it look a little beat up? whats is that?
basically if its a hex driver at 5.5mm, it should work. Is that a hex driver? cant really tell from the socket end of it.
« Last Edit: Sun, 21 June 2009, 15:58:20 by wellington1869 »
Offline cchan
« Reply #15 on: Sun, 21 June 2009, 15:57:57 »
Can't tell from the picture if the walls of the socket will be small enough.  But I know Sears #45815 works:
http://www.sears.com/shc/s/p_10153_12605_00945815000P
Offline nowsharing
  • Swoop
« Reply #16 on: Sun, 21 June 2009, 16:41:50 »
I didn't notice that, your right, it doesn't look good. I'll keep looking.
If I can't get something shipped here, that's what I'll go with.
Thank you both for the fast response!
« Reply #17 on: Sun, 21 June 2009, 16:44:22 »
Quote from: nowsharing;98213
nowsharing - what do you want to pay? I'll send you mine. I doubt i'll ever open up another M board again. Name price that you're comfortable with and its yours. :)
(assuming i find it that is; i'll poke around in my closet but it should be there!)
Update: I could have sworn I bought an individual driver, but the only thing i'm finding in the ol' closet is a set of hex socket attachment/adapters (for my multipurpose screwdriver). Hmmmmm. So never mind. Sorry about that bro. :)
« Last Edit: Sun, 21 June 2009, 16:55:55 by wellington1869 »
Offline nowsharing
  • Swoop
« Reply #18 on: Sun, 21 June 2009, 17:04:02 »
Thank you for the offer regardless!
I came across this one, which has free intl shipping, but again it doesn't mention if it's a deep socket: http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&Item=250436521557
I may just pick up the craftsman socket when I'm home over Christmas. It would travel better anyways.
Offline cchan
« Reply #19 on: Sun, 21 June 2009, 20:20:34 »
Quote from: nowsharing;98217
Nut drivers should always be good just as long as the socket wall is thin enough to make it all the way down in the screw well. Socket depth only matters for sockets because the drive end is thicker.
« Reply #20 on: Sun, 21 June 2009, 20:38:40 »
bette midler, cchan, bette midler?!  ;)
you went from a led zeppelin reference to a bette midler reference! I think there are laws against that...
« Last Edit: Sun, 21 June 2009, 21:14:34 by wellington1869 »
Offline nowsharing
  • Swoop
« Reply #21 on: Mon, 22 June 2009, 15:56:40 »
Aha! The light-bulb above my head just lit up; I never stopped to think about that.
The Ebay one will work fine but since you'll have a garage full of them and want to make sure it will fit any size hole (click da pic):
Thanks for the link Ripster. That Milwaukee driver looks sci-fi--I like it, and so does my swanky friend
Offline lowpoly
« Reply #22 on: Mon, 22 June 2009, 16:55:09 »
Where are you located? This is a standard tool, intl. shouldn't be necessary. I bought mine from an RC car vendor, they also offer tools, this being one of them. I got the same one clickykeyboards sells, except it was 5.5mm which will fit as well.
Will also open DEC LK201.
Offline nowsharing
  • Swoop
« Reply #23 on: Mon, 22 June 2009, 17:01:38 »
Southern Brazil. You're right, everything here is metric and I could surely get it locally now that I know what I'm looking for.
Offline lowpoly
« Reply #24 on: Mon, 22 June 2009, 17:20:44 »
The guys here would sell me a 7/32" socket without raising an eyebrow. But they would have to order it too and it would cost 4 times as much as the China-made tool I got instead.
Offline o2dazone
« Reply #25 on: Mon, 22 June 2009, 18:44:43 »
Quote from: ripster;98412
Ya shoulda seen the look on MY hardware store guy's face when I said I needed a 5.5mm metric socket wrench.
"A 5.5mm - sure you don't mean 5?"
"Nope, 5.5"
"Metric?"
"Yep"
starts mumbling under his breath about the metric system....
The last two cars I've owned had metric bolts. Thankfully, my dad has every Mac tool under the sun, so I just borrowed his set. But yeah...it shouldn't be uncommon, Americans deal with metrics all the time, when our crappy system isn't accurate enough.
Offline lowpoly
« Reply #26 on: Wed, 24 June 2009, 04:43:19 »
My Jeep has metric and imperial mixed. Congratulations, Jeep. :crazy:
Offline Special K
« Reply #27 on: Tue, 14 July 2009, 18:24:51 »
FYI, the 7/32" deep socket in this set works fine with my model M:
http://www.homedepot.com/webapp/wcs/stores/servlet/ProductDisplay?storeId=10051&langId=-1&catalogId=10053&productId=100653632
Funny story:
I'm not a tool expert, so I asked a HD employee for help finding this particular socket.  It took him awhile to find a set that had this particular type of socket in it, so he asked me what I needed it for.
I told him I needed it to take apart an old keyboard.  His response:
"You know, Microsoft and Logitech make keyboards for like $10 now.  Are you sure you wouldn't be better off just getting a new keyboard?"
:laugh:
Filco FKBN104MC/EB
Filco FKBN104M/EB2
IBM Model M 1391401 - 11/13/87
Quote from: ripster
LOL - we're on post #163 of this mega-thread and you've gone from"keyboard n00b" to "keyboard sn0b".  We've done our job.
Offline bhtooefr
    • bhtooefr.org
« Reply #28 on: Tue, 14 July 2009, 23:36:31 »
Every car I've owned has either been German or Japanese. (Well, two were built in the US, but they were all still 100% metric.)
So, funnily enough, my SAE tool selection is woefully inadequate.
Offline o2dazone
« Reply #29 on: Wed, 15 July 2009, 08:50:24 »
Quote from: Special K;102599
:laugh:
He makes a good point :P
I was at Home Depot looking for a petroleum-less grease to put on the stabilizer bar, and he asked what it was for. Not to sound like a total creep, I told him it was a squeaky fan on the case. Another employee walked up and said "you should just buy new fans on Newegg.com", which he then started to spell it out. I was so angry about that, I make sure when I leave the house to look like a complete shut-in, and this guy is rattling off domains to me like I wouldn't know what they are. Insulting :laugh:
Offline codek
« Reply #30 on: Thu, 11 November 2010, 12:04:20 »
will that work with the screws from the smaller holes? I got one to fit but couldn't get to ones with the smaller holes, the bit wasn't skinny enough
Offline steeef
« Reply #31 on: Thu, 11 November 2010, 13:08:02 »
Here's a 5.5mm deep socket driver from jpc's bolt mod for klutzes:
http://www.amazon.com/Wiha-26555-Precision-Driver-Metric/dp/B000O5EG42/ref=sr_1_1?ie=UTF8&s=industrial&qid=1286904125&sr=1-1
Should work. I already had a wrench, so I just got this:
http://www.amazon.com/gp/product/B000NY97XO/ref=oss_product
Worked great on mine.
Cherry MX Blue: Filco Majestouch Tenkeyless. Cherry MX Black: TG3 KBA-BLTD-5RBUVS (Police Cruiser keyboard). Cherry MX Clear: KBC Poker (modded with Ergo Clears) Cherry MX Brown: Goldtouch GTC-077 USB numpad. Buckling Spring: IBM Model M 1391401 (1989-01-03 and 1991-11-21).
Offline Soarer
« Reply #32 on: Thu, 11 November 2010, 15:42:26 »
For those who live in the UK, this '6 Piece Nut Spinner Set' by Rolson is only £4.99 from Maplin or Halfords (and probably plenty of other places as well). Sizes are 3mm to 5.5mm. Not the last word in quality, but sufficient.
Offline Cheese101
« Reply #33 on: Thu, 11 November 2010, 17:20:28 »
all i did was drill the holes larger so i could fit a regular socket piece in (couldn't be bothered going out and buying deep set sockets or socket screwdrivers)
there are only 3 holes you need to englarge
Main:
IBM Model M 1391401 ; 4th October 1991
Spare:
IBM kb-8923 ; 1996 - owned from new!
