Author Topic: plum mx 96 on OS X?  (Read 4418 times)
Offline Gumberculese
  • Man, Machine, Scientist?
plum mx 96 on OS X?
« on: Mon, 30 December 2013, 22:42:17 »
I just got a plum morphling mx 96 (http://www.aliexpress.com/item/Plum-MX-96-Machanical-Keyboard-wireless-Wired-Cherry-Brown-switch-N-key-rollover-Fast-Free-shipping/703473804.html) for Christmas and I absolutely love the keyboard.
With one small exception:
I am primarily a Mac user and cannot for the life of me get the keyboard to work in OS X.  Has anyone else with this keyboard had any luck?
Offline terran5992
  • One With The Cup Rubber
Re: plum mx 96 on OS X?
« Reply #1 on: Mon, 30 December 2013, 23:27:50 »
Hmm my friend used to have this problem, He eventually gave up and bought a HHKB
« Reply #2 on: Tue, 31 December 2013, 00:30:16 »
Yeah, that's about where I am at now.  I haven't found any solutions anywhere.  On the other hand, it works fine on my Windows 7 bootcamp.
Offline terran5992
« Reply #3 on: Tue, 31 December 2013, 01:19:04 »
Could it be a driver issue?
Offline IvanIvanovich
  • Mr. Silk Underwear
« Reply #4 on: Tue, 31 December 2013, 02:05:23 »
It's the way Apple did their multiple interface keyboard handling. Lot of mechanical keyboards have this problem only on Mac OSX. Not keyboard fault... Apple fault.
« Reply #5 on: Tue, 31 December 2013, 14:39:48 »
Perhaps no one else has tried using this keyboard on a Mac?  Maybe describing what is wrong could help identify the problem?
None of the non-alphanumeric keys work (space, shift, caps, return, etc.) or at least work properly. And many of the alphanumeric keys, particularity on the right-hand side of the keyboard are accompanied by nonsense characters. for example whenever I hit b it looks like 'b[' and k is 'k<' and other such nonsense.  It seems to pick up the proper key stroke but adds junk to it.
When I boot into my windows 7 partition, the keyboard works fine.
It seems like OS X just doesn't know how to handle the input (both wired and wireless). They keyboard setup assistant won't recognize the keyboard either, it never realizes when I hit the '?' key (left of the right shift).
Offline kyb
  • i love the smell of nopsleds in the morning
« Reply #6 on: Tue, 31 December 2013, 15:25:39 »
Of course keyboard fault. If you can't guarantee compatibility with one of the three major operating systems you made a **** product. Especially if it's something as simple as a keyboard.
Ergodox :o
Offline tbc
« Reply #7 on: Tue, 31 December 2013, 15:49:36 »
done alot of keyboard firmware programming recently?
« Last Edit: Tue, 31 December 2013, 19:04:28 by tbc »
Offline Grendel
« Reply #8 on: Tue, 31 December 2013, 18:50:00 »
He sure looks like it...
- I'm game !
Offline terran5992
« Reply #9 on: Tue, 31 December 2013, 19:55:51 »
Looks like what?
Offline jabar
« Reply #10 on: Tue, 31 December 2013, 21:44:39 »
it is probably forcing the NKRO-over-USB hack, which can be alleviated by using a USB -> PS/2 -> USB dual adapter combo.
http://deskthority.net/wiki/NKRO-over-USB_issues
Leopold FC660C - Max Keyboard Nighthawk X8 - Ducky DK9008 Shine II 78 Edition - Noppoo Choc Mini - Cherry G80-2100HDD - Cherry G80-8113HDPUS - Plu-M87 - Leopold FC700R Ergo Clears - Deck Legend Frost 105 - IBM F PC Keyboard - IBM M 122 (Lexmark) - Apple Extended Keyboard II
Phantom 7bit
« Reply #11 on: Thu, 02 January 2014, 22:27:31 »
Thanks!  That was actually a huge help!  I figured it out!
I just needed to disable nkro and switch it to 6kro using fn+F12.  Works like a dream now!  Wired and wirelessly.  I also needed to use the numlock fix described here:
http://geekhack.org/index.php?topic=39135.0
to get the numpad working.  It's my new favorite keyboard...now to find some fancier keycaps...
« Last Edit: Fri, 03 January 2014, 10:52:01 by Gumberculese »
