Author Topic: WASD V2 87-Key Custom Mechanical Keyboard  (Read 2457 times)
Offline avtar
« on: Tue, 31 December 2013, 11:23:05 »
Does anyone use this keyboard?
http://www.wasdkeyboards.com/index.php/products/mechanical-keyboard/wasd-v2-87-key-custom-mechanical-keyboard.html
I'm wondering which controller and PCB it uses and if it's possible to use custom firmware, ex. https://github.com/tmk/tmk_keyboard
And also if there would be any custom case options.
Thanks.
Offline daerid
    • Rossipedia
Re: WASD V2 87-Key Custom Mechanical Keyboard
« Reply #1 on: Tue, 31 December 2013, 11:30:23 »
Pretty sure the controller and firmware are both custom made to WASD's spec. I doubt it's reprogrammable.
However, that doesn't mean that you couldn't mod your own board with something like a Teensy 2.0 to enable use of the TMK firmware.
Offline avtar
« Reply #2 on: Tue, 31 December 2013, 16:32:18 »
Thanks for clearing that up. Conveniently I ordered a Teensy controller but I think I'll try getting a Phantom board.
Offline terran5992
  • One With The Cup Rubber
« Reply #3 on: Tue, 31 December 2013, 20:00:48 »
Look in the classifieds for your phantom parts
