Author Topic: Blue LEDS on a Unicomp Customizer  (Read 14626 times)
Offline kliclak
« on: Fri, 06 February 2009, 21:31:55 »
Hey all,
In advance of my set of black keys arriving for my Unicomp Customizer, I decided to change the green LEDs to blue ones.
I picked up some 3mm blue LEDs from the electronics shop and opened up the keyboard.  I booted up the computer so the Num Lock was on (green LED was lit).  I took the new blue LED and tried to just touch the existing solder points on the back of the pc board with it to see it light up.
It didn't light up.  I tried switching the polarity, nothing, I then tried it on the caps lock and the scroll lock, the LED didn't light up when touched to the solder points of any of them.
I even tried a 5mm LED and it didn't light up either.
None of this hurt the board, the green LEDs never stayed lit...never even flickered.  I'm just wondering if I desolder the original green LED and replace it with one of these blue ones, will it light up?
Did it not light up because the board will not light two LEDs in parallel?
Any ideas?
Offline Chloe
  • Switch Kitten
« Reply #1 on: Fri, 06 February 2009, 21:35:19 »
Blue LEDs typically require more power to light up. You will have to remove or replace the series resistors. Do you have a multimeter?
Offline kliclak
« Reply #2 on: Fri, 06 February 2009, 22:15:19 »
Yes I have a multimeter.  So I assume I need to trace back and find the resistors?
Is there anything in particular I should look for on the board?
Offline bhtooefr
    • bhtooefr.org
« Reply #3 on: Fri, 06 February 2009, 23:12:14 »
I still vote for UV LEDs for a blackout Customizer.
Offline wellington1869
« Reply #4 on: Fri, 06 February 2009, 23:31:37 »
yea, if you're putting them in parallel, arent they drawing more current? more than it can supply maybe. So it may well work if you desolder one end of the green led and then try the blue one.
UV sounds even cooler than blue, but I wonder if the average electronics store would have those. They're kind of blue-ish, right?
Looking forward to your pics, kliclak!
using: ms 7000/Das 3
Offline bhtooefr
    • bhtooefr.org
« Reply #5 on: Fri, 06 February 2009, 23:51:18 »
UV LEDs are purple.
(Remember, V is Violet. ;))
Offline kliclak
« Reply #6 on: Sat, 07 February 2009, 07:31:57 »
Yeah I was originally trying for some UV ones, but of course the store didn't have any.
I do have a UV LED I put in one of my computers as a power indicator, it's not as bright as the blue ones.  Maybe it doesn't draw as much.
I wonder if UV LEDs would work without modifications?
Of course the place I bought that LED is out of business, so I'll need to order some and wait for them to arrive...
In the meantime, I loaded up GIMP and made a new label for the keyboard with some laser printer labels...
Offline kliclak
« Reply #7 on: Sat, 07 February 2009, 09:52:54 »
Ok, I took out the trusty multimeter and took some readings.
Hopefully this will provide enough info on what specifics I need to know before ordering LEDs.
This is a USB Customizer keyboard...I thought I'd mention it because the PS/2 version might have different voltages.
The voltage at the LED (when it is on of course) was 2.02 volts
The voltage before the resistor was 4.5 volts
The resistance I measured across each resistor was 323-324 ohms, but the bands were Orange, Orange, Brown then Gold, so I guess they are 330 ohm resistors with 5% tolerance.
Does that sound correct?
So am I correct in assuming I need LEDs that will work at 2 volts?  Or resistors that change 4.5 volts to what makes the purple or blue LEDs happy?
The purple LEDs I am finding on Ebay seem to run at 3.2 to 3.8 volts (the blue ones too for that matter).
So the question is, what value of resistor do I need to step the 4.5 volts down to between the 3.2 and 3.8 volts that make the pretty purple LEDs work?
Offline xyzzy
« Reply #8 on: Sat, 07 February 2009, 12:51:41 »
Is that a new keyboard? It has a white Unicomp logo, different from the blue one I've always seen.
And, I must admit, the white one is not as fugly as the blue one. Maybe Unicomp finally listened to us and hired a new designer? ;)
PFU HHKB Pro (capacitive) • Topre Realforce 87U (capacitive) • IBM Model M SSK 1391472 (buckling spring) • IBM Model M SSK UNI04C6 (buckling spring) • IBM Model M 1391405 (buckling spring, x4) • Cherry MX 5000 ErgoPlus + MX 5700 keypad (brown Cherry) • Cherry MX 1800 Compact (blue Cherry) • Cherry MX 11900 Touchboard (brown Cherry) • Dell AT102W (black Alps) • Apple Extended Keyboard II (cream Alps) • Acer 6312-TA (black Acer) • Unikey KWD-601 (white Cherry)
Offline lal
« Reply #9 on: Sat, 07 February 2009, 12:59:57 »
Quote from: xyzzy;21056
Answer:
Quote from: kliclak;21034
Looks great! But I think it'll be impossible for Unicomp to use this font because of trademarks and stuff. :(
BS: Customizer, Model Ms; Alps: CSK-2101, FK-2002, AT-101 (SGI & Dell), MCK-860, FKBN87Z/EB; Cherry: Poker X, FKBN87MC/EB, WY60, G80-3000, G84-4100, TDV 5010
Offline lal
« Reply #10 on: Sat, 07 February 2009, 13:02:59 »
Klicklak, would you share the .xcf for this label with us?
Offline xyzzy
« Reply #11 on: Sat, 07 February 2009, 13:05:24 »
Thanks, I missed that bit... I was too excited seeing a different logo. :eek:
Ok, back to reality now :(
« Reply #12 on: Sat, 07 February 2009, 13:13:47 »
Quote from: kliclak;21043
good question, its been too long since my EE classes, but I believe V=IR. :)
I would think though that a standard LED should work fine (it just might not be as bright, or might be too bright, but it should work I think). Did you try desoldering a green one and putting in the blue one? I think it wouldnt work in parallel but might work if you substitute.
Nice logo by the way.
Offline kliclak
« Reply #13 on: Sun, 08 February 2009, 11:18:36 »
The blue one will not light up...not enough voltage.  After looking around elsewhere, and found that I most likely need to use 50 ohm resistors.
Unfortunately the "local" electronics shop is 50km away and closed on Sundays.
If I go to Radio Shack (or the abomination that Circuit City transformed them into up in Canada) all they have are assorted packs of resistors (2 ea) of 50 different values that cost $6.99.  So I'd need to buy 2 'assorted' packs for $14 just to get the 3 resistors I'll need, and then have 197 resistors that I don't need.  Wow, what a useless store!
I may just order a pile of UV LEDs with included resistors from Ebay straight from Hong Kong.
Offline Chloe
  • Switch Kitten
« Reply #14 on: Sun, 08 February 2009, 11:58:16 »
It's best to use a series resistor. Too much power will reduce the life if it does not burn out the LED.
To calculate series resistor:
Resistor value = (Supply voltage - LED voltage)/Current
You might find the blue LED is too bright so I would experiment with resistor values upward of 68 ohms. I think purple looks better than UV unless you specifically want UV lighting effect.
Offline kliclak
« Reply #15 on: Mon, 09 February 2009, 17:54:02 »
Well,
Good news and bad news.
I got the blue leds installed and they work fine...good.
AND
The black keys arrived today...really good...BUT...
There was a small mistake in the package, basically I got one less letter key than I need, and one extra "+" or "Enter" key for the keypad.
I'm sure Unicomp will straighten it out, but for now the keyboard is "almost" done.
I guess I could do a number of things in the meantime (take an extra model M keycap and paint it black or red for the esc key), or even take one of the clear keycaps I have and do something with it, but I'd really rather just have all black keys no painted ones.
Once it's fully done I'll post some better, higher res pictures.
Offline bhtooefr
    • bhtooefr.org
« Reply #16 on: Mon, 09 February 2009, 17:57:08 »
Alright, I think I know what I need to do.
Black Customizer 104 + blacked out LED cluster + UV LEDs + black keys + blank white key for escape, dyed red.
Offline lowpoly
« Reply #17 on: Mon, 09 February 2009, 18:02:44 »
Good work on the LED cluster, kliclak.
Miniguru thread at GH, preview site at guru-board.com
The Apple M0110 Today
Offline kliclak
« Reply #18 on: Mon, 09 February 2009, 19:01:58 »
I just got word from Jim at Unicomp, he is sending out black key for me tomorrow.  Excellent service as always.
Quote from: bhtooefr;21259
Anything that sells more Unicomp 'boards is a good thing.
I actually do have a package of UV leds on their way.  I may change these if I like the colour better, I'll see what they look like when they arrive.
Quote from: lowpoly;21260
Thanks for the kind word...I guess it was bound to happen.  They do call it the Customizer after all.
Oh yeah, one last thing, how can I post the .xcf file of the label for people to use?  I know how to post pictures (obviously) but is there a place that will host a file like this?  Is there even enough demand for it?
Offline bhtooefr
    • bhtooefr.org
« Reply #19 on: Mon, 09 February 2009, 19:05:42 »
If you can't attach it to your post, I can host it for you.
Edit: Doesn't look like you can attach .xcf files... shoot me an e-mail... my username @gmail.com... and I'll put it on my own server.
Offline kliclak
« Reply #20 on: Mon, 09 February 2009, 19:37:35 »
Quote from: bhtooefr;21266
Ok, will do.
I just took a couple other photos to post.  It really looks better than the photos show.
Unicomp really needs to market these aggressively.  The funny thing is, I would never have even searched out Unicomp (or even found out about the model M) if the Das Keyboard website had not praised the model M so highly.  They say their keyboard "compares" with the model M.  This one "compares" somewhat more faithfully though...the EXACT same key mechanism to be precise.
I just may make an all black Endurapro (with a bit of grease to quiet it down for use at work) my next project.
Offline ozar
« Reply #21 on: Mon, 09 February 2009, 19:52:46 »
Nice job!   :cool:
That makes me want to work over one of my own customizers.
Offline bhtooefr
    • bhtooefr.org
« Reply #22 on: Mon, 09 February 2009, 20:33:25 »
« Reply #23 on: Tue, 10 February 2009, 00:00:27 »
dude, thats *sweet*.  I want to eat it.
The blue really looks very, very nice.
red RIT on the escape key?
Offline D-EJ915
    • http://dej915.darktech.org:777/
« Reply #24 on: Tue, 10 February 2009, 09:36:03 »
I like that IBM-styled logo, nice job.
Offline kliclak
« Reply #25 on: Thu, 12 February 2009, 21:57:44 »
Quote from: wellington1869;21279
I don't know about dying the escape key.  If I use a model M key, they are too dark already to come out bright red, and I don't know what red dye would do to the metallic grey key that originally came with the keyboard.
Does anyone think paint would work well enough?  After all, the ESC key doesn't get anywhere near the same amount of use as the letter keys.
Quote from: D-EJ915;21304
Thanks.  I think it suits it well.  It's a tip of the hat to the company that designed the keyboard, and it also shows Unicomp's name off a bit more than even their own label does.  I could have gone a lot flashier with it, but I think less is more in this case.
Offline kliclak
« Reply #26 on: Sun, 08 March 2009, 09:52:15 »
Ok, this is a look at the finished (for now) project.
The final black key arrived from Unicomp (thanks to Jim Owens), and now with UV leds.
The purple of the leds is VERY difficult to capture with a digital camera.  It always seems to turn out blue.  This is the best I could do to show the purple colour.
Also, anyone that has seen these leds will know, you can't really focus your eye on them.  They always look a bit blurry.  It's hard to explain, but like I said, if you've seem them...well, you know.
Offline lal
« Reply #27 on: Sun, 08 March 2009, 10:15:32 »
This rocks. You gotta send Jim a link to show them what could be done.
Offline wheel83
« Reply #28 on: Sun, 08 March 2009, 10:30:01 »
If Unicomp did their marketing like DAS, and updated their logos and made an all black product line as well as a real space saver, they could maybe make it through this recession.
I <3 BS
Offline D-EJ915
« Reply #29 on: Sun, 08 March 2009, 12:52:07 »
Unicomp needs to sell that.
Offline itlnstln
« Reply #30 on: Mon, 09 March 2009, 06:40:58 »
I'd buy that, especially if it were a spacesaver.  I would like to see one with black keys and black legends.  You know, for us people that need those kind of crutches.
Offline CX23882
« Reply #31 on: Mon, 09 March 2009, 09:37:31 »
That looks awesome.  Great job!  I don't like the metallic grey/silver keys that come as standard with the black Customizer.  When I see that type of plastic (shiny with silver flecks) it always reminds me of cheap plastic toys from China.  I'm aware that there are issues with getting white lettering to stay on the black keys but does anyone else think the keyboard would look much better with "plain" dark-ish grey keys and black lettering?  (I mean compared to the silver keys, not compared to your beautiful device)
I think all-black keys look great, but the general public don't want that, even if we think they're cool. :)  I saw a piece on The Gadget Show where they had a Das III and I think it was under a list of silly gadgets.  :rolleyes:
I wonder how many international sales Unicomp are getting right now.  A year ago I'd have no problem buying another Unicomp Customizer and having it posted to the UK, but right now the exchange rate is terrible.
I hope Unicomp can keep going and I'm sure that business will pick up in the future even if it's quiet now.
Offline wheel83
« Reply #32 on: Wed, 11 March 2009, 17:10:23 »
Does this mean if I buy LEDs with a 2.0 voltage and a low amprage,  i can directly switch the Unicomp LEDs with off white ones Ive purchased? Using no resistors as well.
I <3 BS
Offline Hak Foo
  • Make America Clicky Again!
« Reply #33 on: Thu, 12 March 2009, 00:50:37 »
As I understand it, LEDs are more about current than voltage, within reason.  The resistors usually seen in series with the LED are designed to restrict the current through the LED.
I think if the LED is designed to accomodate, say, 20mA, putting 5mA through will be safe, just dimmer.
I swapped the green LEDs on my 1391401 with some near-white LEDs that came off a $2.50 set of LED Christmas lights.  Obviously, no specs whatsoever.  They're so bright I had to tint-film them over.
Home: Tactile Pro 4 PC
Work: Customizer 104
Spare: Quickfire XT, Greens, Retro DSA
Offline FKSSR
« Reply #34 on: Thu, 12 March 2009, 08:48:40 »
That's pretty awesome!
Is Unicomp pretty easy to order blank black keys from, or are they resistant to doing so?
Add me on Steam | Twitter
Offline lal
« Reply #35 on: Thu, 12 March 2009, 08:51:05 »
They are *happy* to do so, FKSSR!
Offline FKSSR
« Reply #36 on: Thu, 12 March 2009, 08:52:48 »
Nice!  Thanks.
Offline o2dazone
« Reply #37 on: Thu, 12 March 2009, 21:42:50 »
Wow that looks great. Been lurking this forum for about a week, and your project has definitely made me consider the M/Unicomp boards as my first mechanical (what can I say...I'm a sucker for form as well as the function)
Offline FKSSR
« Reply #38 on: Fri, 13 March 2009, 15:26:38 »
Is the logo on the front of the keyboard in this thread the old Unicomp one?  I like it a lot better than the other ones I've seen (i.e. on the site).
Offline nerp
« Reply #39 on: Fri, 13 March 2009, 16:30:01 »
DUDE.
Could you possibly e-mail me the image you made in gimp? I'd kill to do that. Brilliant! Also, what size label did you use? Avery size?
Love it!
U N I.C O M P - Am I the only one that likes the logo?
Offline nerp
« Reply #40 on: Fri, 13 March 2009, 16:32:08 »
Quote from: bhtooefr;21272
Here's the file: http://bhtooefr.ath.cx/files/keyboard%20label%204.xcf
You'll also need the Men In Blue font, http://bhtooefr.ath.cx/files/MIB.ttf
Aha! Should have read the full thread.
Thanks.
Offline FKSSR
« Reply #41 on: Fri, 13 March 2009, 22:28:51 »
I actually thought I did read everything, but I definitely missed a couple things.  Maybe I confused a couple threads.  Sorry about that. :)
Offline kliclak
« Reply #42 on: Mon, 16 March 2009, 19:38:49 »
Thanks for the comments guys.  This is by most measures a mild mod that anyone can do so I think it appeals to a lot of people.
The purple leds I bought off Ebay worked without any modification, and yes they are BRIGHT!!!  I needed to "tint" the leds with a black marker - a couple of coats to get them down to a brightness that doesn't sunburn my eyeballs.
The keyboard originally came with 3mm leds, but the ones I bought were 5mm, the spacing between the "leads" (the anode and cathode) is the same as a 3mm led, so they fit into the holes in the pc board just fine.
The new logo was something I whipped up on Gimp, which I then printed on a clear label on my laser printer.  I used a clear label to let the light shine through the label, but you could use a white label and cut out the area over the lights with an exacto knife before putting the label on.
Like I said, it's a pretty easy thing to do.  I hope this helps Unicomp sell more keyboards.
Offline lam47
« Reply #43 on: Mon, 16 March 2009, 19:43:21 »
I might have missed it so sorry if it has been posted.
What voltage leds did you use in the end? And what ohm resistors?
looks amazing by the way.
I now have to get some LEDs for a couple of my boards :)
Keyboards. Happy Hacking pro 2 x2. One white one black. IBM model M US layout. SGI silicone Graphics with rubber dampened ALPS. IBM model F. ALPS apple board, I forget what it is. And some more I forget what I have.
Typewriters. Olivetti Valentine. Imperial Good Companion Model T. Olympia SM3
Offline FKSSR
« Reply #44 on: Mon, 16 March 2009, 20:13:41 »
Good question.  I am going to buy some red leds for a couple boards of mine (including the Spacesaver I order next week).
Offline kliclak
« Reply #45 on: Mon, 16 March 2009, 21:53:51 »
In the end I wound up using the original resistors once I went with the purple leds (Wellington was correct about that after all).
Here is a link to the same leds I bought:
http://cgi.ebay.com/Lot-of-50-X-5mm-UV-LED-Ultra-Bright-Free-Resistors_W0QQitemZ220379103418QQihZ012QQcategoryZ66954QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
In reality they are purple, not blue like the picture shows.
Also, if you want to stay with 3mm leds, here are some as well:
http://cgi.ebay.com/Lot-of-50-X-3mm-UV-LED-Ultra-Bright-Free-Resistors_W0QQitemZ220378890053QQihZ012QQcategoryZ66954QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
You'll have a few leftovers...47 to be exact.
Offline lam47
« Reply #46 on: Tue, 17 March 2009, 03:55:11 »
Thanks I appreciate it :)
Offline FKSSR
« Reply #47 on: Tue, 17 March 2009, 09:27:16 »
Are the LEDs in keyboards normally just 3mm?
Offline Chloe
  • Switch Kitten
« Reply #48 on: Tue, 17 March 2009, 12:08:35 »
Some are surface mount and some are 5mm.
Offline FKSSR
« Reply #49 on: Tue, 17 March 2009, 12:11:03 »
Thanks.  I'm mainly just trying to decide which I should get.  I don't want to be blinded. :)
