Author Topic: Model M with "Rubber Springs"  (Read 2957 times)
Offline ayoung24
« on: Sat, 07 February 2009, 10:36:12 »
Looking at buying this keyboard on ebay, which the buyer has listed as "clicky":
http://cgi.ebay.ca/Vintage-IBM-PS-2-Model-M-Clicky-Keyboard-1994-USA_W0QQitemZ370151386058QQcmdZViewItemQQptZPCA_Mice_Trackballs?hash=item370151386058&_trksid=p3286.c0.m14&_trkparms=72%3A1215%7C66%3A2%7C65%3A12%7C39%3A1%7C240%3A1318
The part number (71G4644) and appearance of the keyboard, however, seem to indicate that it is a "Quiet Touch Keyboard" with "rubber springs", as per:
http://sandy55.fc2web.com/keyboard/ibm.html
Can anyone explain the difference in terms of sound/feel/quality between this and a normal model m?
Offline zwmalone
« Reply #1 on: Sat, 07 February 2009, 10:40:37 »
Unicomp still sells those.  It's just a standard rubber dome 'board.  If you're looking for clicky without the noise this is NOT it.  You'd be better off just buying a standard M and greasing the springs.  These "quiet touch" 'boards feel like your average $2 dome keyboard.
Can't get enough of them ALPS
Offline lexicon
    • http://www.word-detective.com
« Reply #2 on: Sat, 07 February 2009, 11:06:05 »
I actually have one of these -- paid $10 new in box.  It is the most weirdly unpleasant keyboard I've used.  The key throw is as long as an M's, but it's like typing in really thick pudding.  It's very tiring to use.
IBM Model M 1391401 (1989)
IBM Model M 52G9658 (1993) x2
Unicomp Customizer 101 (black)
Solidtek ASK-6600U
Dell AT101W (way too many)
Dell AT101W (black)
Silicon Graphics AT-101 (1993)
Cherry G84-4100
Offline ayoung24
« Reply #3 on: Sat, 07 February 2009, 11:08:26 »
Thanks for the heads-up!  I'll definitely pass.
Offline Mercen_505
« Reply #4 on: Sat, 07 February 2009, 16:49:42 »
Yeah, definitely pass on that. The keys are insanely loud if you happen to strike them toward the edges, and as others have mentioned they just don't feel... right... at all.
Offline lexicon
« Reply #5 on: Sat, 07 February 2009, 19:58:53 »
It was really a horrible mistake.  My wife, who knows nothing about keyboards and has no interest in them (she uses an old Gateway 2000 board...), happened to try to type on this board while it was briefly hooked up to my computer and said, "That's a HORRIBLE keyboard.  You LIKE that?"
Solidtek ASK-6600U
Dell AT101W (black)
Cherry G84-4100
Offline bhtooefr
    • bhtooefr.org
« Reply #6 on: Sat, 07 February 2009, 20:01:41 »
One of the old Gateway 2000 boards is fine if you like functionality, and don't care about key feel... was it the Anykey? Had programmability, and Gateway churned them out like crazy.
Offline cchan
« Reply #7 on: Sat, 07 February 2009, 22:24:10 »
In my opinion, the AnyKey's (I had one, with call centre keycaps, but I sold it) had a pretty decent key feel for being rubber domes.
HP Envy17: Core i7-2760QM, 8GB DDR3, 128GB Crucial m4 + 750GB Hitachi, Windows 7 Home Premium x64, Cherry ML4100, Logitech M500, HP zr22w
IBM Thinkpad X60: Core Duo T2400, 2GB DDR2, 128GB Samsung 830, Xubuntu 12.04 x86, Cherry ML4100, Logitech M205, HP zr22w
Raspberry Pi Model B: BCM2835, 0.25GB DDR2, 8GB Samsung SD card, Raspbian Wheezy, human interaction devices as above
