Author Topic: Keycool 84 or Noppoo Choc Mini ISO layout  (Read 1997 times)
Offline epzy
  • HHKB Fiend
  • ded
« on: Sat, 04 January 2014, 21:35:53 »
Not looking for a 75% anymore.
« Last Edit: Fri, 25 April 2014, 15:27:12 by epzy »
Offline Lain1911
  • God of the Wired
Re: Keycool 84 or Noppoo Choc Mini layout ISO
« Reply #1 on: Thu, 24 April 2014, 20:21:17 »
Ya let me know when you find it.
Offline Pacifist
  • on hiatus
« Reply #2 on: Thu, 24 April 2014, 20:30:32 »
sprit?
Offline IvanIvanovich
  • Mr. Silk Underwear
« Reply #3 on: Fri, 25 April 2014, 15:16:10 »
Closest MX I have seen are the Quantel/Access-IS AKE079339 which are more like a 60% with a function row on top. Though, they speak some kind of terminal protocol so you would need a soarers or replace the controller inside.
If you don't mind Alps you could get an Ortek MCK-84. Otherwise, I think customs is your only other choice.
Offline epzy
  • HHKB Fiend
  • ded
« Reply #4 on: Fri, 25 April 2014, 15:18:06 »
Welp, there you go Lain1911. :) This thread is pretty old, and I don't have any interest in a 75% any longer.
Offline Lain1911
  • God of the Wired
Re: Keycool 84 or Noppoo Choc Mini ISO layout
« Reply #5 on: Fri, 25 April 2014, 15:49:33 »
:p The reason I'm interested in 75% is that it's the smallest I can go while retaining the functionality I need. It's not that Keycool is hard to find, It's just hard to find in blues. Reds and Blacks are rampant. I'm not dissatisfied with me QFR. I just didn't want reds.
