Author Topic: Ducky Shine 3 Trouble  (Read 3333 times)
Offline Sanctum
« on: Sat, 04 January 2014, 22:49:52 »
First Post Here - for some reason, the entire 5th row of my Ducky Shine 3 keyboard (shift, z, x, c, etc...) has an error with actually registering if the key is being pressed or not.
It also happens to be every other key (z, c, b, m, >, shift).  I have tried restarting in safe mode, restarting in general, and playing with the functions and/or resetting them, on the keyboard itself.  Really hoping one of you guys have the answer!
Offline tbc
Re: Ducky Shine 3 Trouble
« Reply #1 on: Sat, 04 January 2014, 22:52:31 »
did you reset the keyboard to stock settings?  it's REALLY easy to accidentally turn on some of the special settings on that board.
Offline Sanctum
« Reply #2 on: Sat, 04 January 2014, 22:54:30 »
Yea, the double windows key for 3 seconds seems to 'reset' the board.  And yes, the amount of times I've accidentally messed up something up on it in 2 weeks of use is amazing.
Offline terran5992
  • One With The Cup Rubber
« Reply #3 on: Sat, 04 January 2014, 22:55:06 »
Care to elaborate the problem?
Are the keys not registering ? If so please test using Aquakeytest
Offline Sanctum
« Reply #4 on: Sat, 04 January 2014, 23:03:14 »
« Last Edit: Sat, 04 January 2014, 23:52:26 by Sanctum »
« Reply #5 on: Sat, 04 January 2014, 23:38:01 »
Still under warranty?  Can you RMA it?
Offline Sanctum
« Reply #6 on: Sat, 04 January 2014, 23:49:17 »
Yea, I bought it at the beginning of December.  I'd rather look for a solution if there is one though xD
Offline Sanctum
« Reply #7 on: Sat, 04 January 2014, 23:52:54 »
Used the Aqua key test.  WEIRD findings (for me).  All of the keys I stated would not go off, but they almost looked to be pushed down? on the key test.
Here's the weird part - Shift + Z activates X, V, N, <, ?, /, ., Alt, Down, Right Arrow, Down Arrow, and CTRL.  The keys in my first post would straight up not register :S
« Reply #8 on: Sun, 05 January 2014, 00:31:47 »
Sounds a bit like a controller issue.
But as soon as you open the case to investigate, you are likely to void your warranty.
Offline Sanctum
« Reply #9 on: Sun, 05 January 2014, 01:36:28 »
RESOLVED: Not entirely sure how, but plugging in another keyboard and leaving the other one off, and then LATER coming back to it fixed all of the issues.  Still convinced I messed up one of the thousands of features with the Function key.  Thanks for all of the help anyways!
« Reply #10 on: Sun, 05 January 2014, 02:32:41 »
A happy ending :)
