Author Topic: Is KBC poker ii compatible with mac?  (Read 10072 times)
Offline vatin
« on: Sun, 05 January 2014, 05:19:41 »
I carry my kbc poker ii to use at the client's office which happen to use macs. How can I assign command key to my poker ii. I suppose you need to change some settings in os x?
HHKB Professional Classic
Offline terran5992
  • One With The Cup Rubber
Re: Is KBC poker ii compatible with mac?
« Reply #1 on: Sun, 05 January 2014, 07:00:37 »
Autohotkey
Offline vatin
« Reply #2 on: Sun, 05 January 2014, 07:02:59 »
Autohotkey
If I'm not allowed to install software, is there any alternatives?
Offline laffindude
« Reply #3 on: Sun, 05 January 2014, 07:20:36 »
There is no AHK for Macs.
Windows key = command key on Macs.
Offline riotonthebay
  • Cherry Peasant
  • keycult.com
« Reply #4 on: Sun, 05 January 2014, 07:21:54 »
This can be done without external software just using system preferences. System preferences > keyboards > modifier keys (or something like this... On my phone at the moment.)
Offline vatin
« Reply #5 on: Sun, 05 January 2014, 08:03:44 »
If it's automatically remap win to command then that's jolly
Offline terran5992
« Reply #6 on: Sun, 05 January 2014, 08:13:12 »
You havent tried it yet?
Offline vatin
« Reply #7 on: Sun, 05 January 2014, 08:22:18 »
No this is the first time I'm introducing it to the mac
Offline Hyde
  • White Tofu Extraordinaire
« Reply #8 on: Sun, 05 January 2014, 13:51:32 »
You can do it through Mac keyboard software settings.
Go to system preference  ->  keyboard  ->  top right hand corner there should be a scroll down menu pick usb keyboard  ->  then pick modifier key
Now what want is to map:
CMD key -> Alt key
Alt key -> CMD key
Then you're done  :D
