Author Topic: Looking to replace worn/shiny keycaps - g80-3000 versions  (Read 3791 times)
Offline bondonin
« on: Sun, 05 January 2014, 20:43:05 »
If I read the faq correctly the g80-3000 keycaps should fit in any keyboard with standard layout. After some reading I found the g80-3000 has several different keycaps and I'm interested in the black and all gray versions.
So my questions are:
What materials are those keycaps made of? Black is pom but gray is?
Where can I get the all gray set?
Are the legends on all the versions from the dyesub days pretty much the same or identical?
Offline Dubsgalore
Re: Looking to replace worn/shiny keycaps - g80-3000 versions
« Reply #1 on: Sun, 05 January 2014, 20:47:49 »
Cherry Article Numbers are going to be pretty much need. look at the 5-7 digit code after the '3000' and you will know the type of material used, the connector type, the method of legends, the layout, the switches used, and some other helpful things.
Dyesubs have nearly identical legends, just as a slightly fuzzier version of doubleshot legends. it's not very noticable, but certainly you can tell up close. Cherry Dyesubs however are done extremely well, it's very hard to notice, unlike imsto legends.
Offline bondonin
« Reply #2 on: Sun, 05 January 2014, 21:03:23 »
Are the lasered versions etched or infill?
Offline Dubsgalore
« Reply #3 on: Sun, 05 January 2014, 21:06:00 »
PBT is etched; POM is engraved, with infill and without it sometimes, it varies.
Offline phoenix1234
« Reply #4 on: Sun, 05 January 2014, 21:14:44 »
Is this the one that you are looking for?
http://imsto.cn/index.php?route=product/product&path=59&product_id=59
I like linear switches
Offline bondonin
« Reply #5 on: Mon, 06 January 2014, 08:43:42 »
Looks good but expensive though.
« Reply #6 on: Mon, 06 January 2014, 08:48:19 »
You could probably find some in the classifieds if you wanted...
Offline IvanIvanovich
  • Mr. Silk Underwear
« Reply #7 on: Mon, 06 January 2014, 14:32:58 »
IF you have ANSI keyboard you can get Cherry official replacement KC104 set for pretty cheap in taobao.
Offline bondonin
« Reply #8 on: Thu, 09 January 2014, 18:42:51 »
How do the old 2nd hand cherry pbt keycaps feel? Do they have that coarse sandy feel like the Vortex?
« Reply #9 on: Thu, 09 January 2014, 20:04:58 »
No Cherry PBT have a very fine texture. They don't feel like ****ty sandpaper.
Offline bondonin
« Reply #10 on: Thu, 09 January 2014, 20:58:50 »
Thats good to know. Now would it be possible to mix and match say a 37 cherry pbt set onto a Ducky keyboard?
Would the cherry keycaps be too low compared to oem profile and make typing awkward?
« Reply #11 on: Thu, 09 January 2014, 21:09:40 »
Cherry profile is about 2mm shorter than OEM. Some people seem to be OK with that... it would make me crazy but I hate OEM profile anyway.
If you just want a cheap Cherry set to put on something like a Ducky, I would suggest looking for G80-8113/8200/8963. These models have all the right keys including a flat caps lock that will fit properly. While there are not any I can see for really cheap (there is a fair priced doubleshot one though) from a quick look on ebay at the moment, it's not all that uncommon for them to pop up in the $20-40 range.
[edit] Looks like a cheaper one was listed, has an ISO enter though... here
« Last Edit: Fri, 10 January 2014, 12:46:31 by IvanIvanovich »
Offline bondonin
« Reply #12 on: Fri, 10 January 2014, 18:51:59 »
It looks like I missed the boat on the Tai Hao thick ds in 2013. Any chance of a group buy this year?
