Author Topic: Post your keypads!  (Read 110917 times)
Re: Post your keypads!
« Reply #50 on: Wed, 15 January 2014, 21:00:11 »
so simple.. yet so pretty.
Offline JimByr
  • ...old guy...
« Reply #51 on: Wed, 15 January 2014, 21:27:21 »
Does anyone know of a serial to usb adapter that will work with a keyboard or the keypad above?
I tried one adapter and it doesn't support keyboards.
I guess that something could be made with a teensy.
« Reply #52 on: Wed, 15 January 2014, 21:38:36 »
At one stage mkawa was selling PS2 to USB adaptors that apparently also work as serial to USB adaptors IIRC.
Offline JimByr
  • ...old guy...
« Reply #53 on: Wed, 15 January 2014, 21:48:40 »
The Tripp-Lite Keyspan USA-19HS supports keyboards so should work. And has drivers for just about any operating system you would use. Costs a bit though.
« Last Edit: Wed, 15 January 2014, 22:06:56 by JimByr »
Offline terrpn
  • Alpha Geezer
  • - Buy Vintage -
« Reply #54 on: Wed, 15 January 2014, 21:54:29 »
i asked the same question and after a little research found the same thing :thumb:
Luga G80-1865/MX Reds + Dolch G80-1813/MX Blues + G80-3700HQAUS + DK9008G2 Pro/MX Browns Thick PBT + DK9008G2 Pro/MX Clears Thick PBT +  QFR TKL/Ghetto Greens + Cherry G80-1800/MX Blues + IBM Model M SSK Bolt Modded + IBM Model M + IBM Model F + IBM AT F + Cherry G80-1000 (HAD)/MX Vintage Blacks + Razer BWU/MX Blues + Leading Edge DC2214/Blue Alps + Compaq MX11800/Browns + Chicony 5181/Monterey Blues + Chicony 5161/MX Black Cherry Clone + Focus 2001/White Alps + Chicony 5191/White Futabas + Olivetti ANK27-101 + Dell (Old Logo) AT101/Black Alps + NMB RT8255C+/Black Space Invaders + Unitek K260/Green Alps + Apple M0116/Orange Alps + AEK II M3501/Cream Alps + AEK M0115/Orange Alps + NEC  APC412/Blue Sliders + NEC APC410/Blue Sliders + Omnikey /White Alps + Wang/Yellow Alps (Omrons) + Laser/White SMK + Fame/Blue Aruz + AEK II M3501/Salmon Alps + Zenith ZKB-2R/Green Alps + Wang 724/Orange Alps + DK1087/Green Alps + Zenith ZKB-2/Yellow Alps + Dell Old Logo AT101/Salmon-Pink Alps + Leading Edge AK1012/White SMK's + Magitronic SK-1030/White (Linear) Futaba's + Packard Bell/White (Clicky) Futaba's + Datacomp DFK101/White  Alps + SGI AT101/Dampened White Alps + NMB AQ6RT-72511/Grey Space Invaders (Hi-Tek) + Datacomp/Blue Alps + Phillips 2812/White Space Invaders (Linear) + Dah Yang K251/Vintage MX Blues + Chicony 5161/DS Caps/Vintage MX Blue + Archie-NMB AQ659ZRT-725/Black Space Invader (Tactile) + IBM Model M 71G4644 (RD) Bolt Modded with Soarers Converter + IBM Model M Silver Label 1390131 + Cherry G80-1501/Vintage MX Clears + Focus FK8000/Linear Futabas + Gateway 2000 Anykey Programmable/Maxi-Switch + Dell GY13PVAT101/Dye Sub Caps/Salmon Alps + Chicony 5161/White Alps + AST K0B101/Slider over RD + Qtronix QX-32H + Everex/NMB RT8255CW+ Black Space Invaders-Split Erase + Tandon/NMB AQ659ZRT-101A/Beige Space Invaders + Cherry G80-11903 MNRUS/MX Blacks + Apple IIGS A9M0330/SMK Whites + WYSE PCE/MX Blacks + Chicony 5160AXT/Clicky Futaba + Cherry G80-0528/Vintage MX Blacks + Dell AT101/Linear (Modded) Black Alps+Topre 55g
Offline kenmai9
  • Unicornforce
  • Skrrr
« Reply #55 on: Wed, 22 January 2014, 04:33:19 »
51915-0
51917-1
Went back to stock caps until Hyperfuse arrives :D
Offline VesperSAINT
  • vpsert
  • #CustomKorean
« Reply #56 on: Thu, 23 January 2014, 16:45:52 »
Changed mine up a lil' for fun :) Turned out aight.
« Reply #57 on: Thu, 23 January 2014, 16:56:20 »
So clean!!!!!  :thumb: I need to get those lime caps sometime in the forum classifieds.. ;p
« Reply #58 on: Thu, 23 January 2014, 19:30:20 »
Need a yellow (or orange) one in between for the full traffic light effect.
Offline VesperSAINT
  • vpsert
  • #CustomKorean
« Reply #59 on: Thu, 23 January 2014, 23:00:13 »
Thankies! Do it up. I'm sure you should be able to score a set :)
:)) LOL! Didn't think of that. That would actually look pretty good... but can't afford to spend another $100+ on a Topre set :P
« Reply #60 on: Fri, 24 January 2014, 03:13:23 »
That's the thing - you have to buy a full set (if they are even still available).
There was a rumour that Bro was going to make Topre gamer sets - I wonder if (a) the profile of one of those would suit, and (b) whether he will make yellow or orange.
I suspect the answer to both is YES!
Offline kelske
  • The North Borders
« Reply #61 on: Fri, 24 January 2014, 04:36:13 »
you could grab an orange WASD from o2dazone for $15! I mean.. if you're really set on the traffic light theme that is  :))
Offline oscillik
    • music podcasts
« Reply #62 on: Fri, 24 January 2014, 06:26:13 »
so much jealousy is being aimed at every one of you who have a 23UB.
Keymacs A620N-Rev.A with Alps SKCM Salmon switches
Offline VesperSAINT
  • vpsert
  • #CustomKorean
« Reply #63 on: Fri, 24 January 2014, 14:42:19 »
That actually sounds pretty dang awesome! Gotta wait n see :D
This is so very true... BLARGH. Money tho... lol... to do or not to do... le sigh.
:[ sowey man. Don't quit! I didn't, and ended up finding one.
Offline ComradeSniper
  • HHKB Pro
« Reply #64 on: Sat, 25 January 2014, 00:58:14 »
If he can make topre gamer sets, I hope he makes HHKB arrow sets.
« Reply #65 on: Sat, 25 January 2014, 18:33:42 »
And HHKB Fn key! :)
Offline VesperSAINT
  • vpsert
  • #CustomKorean
« Reply #66 on: Sat, 25 January 2014, 18:50:23 »
And HHKB Fn key! :)
Definitely agree with you guys. I actually have an idea. I'll do it tonight or so and post pics ASAP, when i get home.
Offline Wildcard
  • When caffeine isn't enough
« Reply #67 on: Sat, 25 January 2014, 19:22:03 »
20 years old, complex white Alps, double-shot keycaps.
That's one nice keypad :)
Offline VesperSAINT
  • vpsert
  • #CustomKorean
« Reply #68 on: Mon, 27 January 2014, 02:54:54 »
makeshift
« Last Edit: Mon, 27 January 2014, 03:07:21 by VesperSAINT »
« Reply #69 on: Mon, 27 January 2014, 03:08:26 »
makeshift
Close enough ;D
Offline VesperSAINT
  • vpsert
  • #CustomKorean
« Reply #70 on: Mon, 27 January 2014, 03:10:03 »
makeshift
Close enough ;D
:)) tee hee
« Reply #71 on: Mon, 27 January 2014, 03:13:01 »
makeshift
Close enough ;D
:)) tee hee
Pretty awesome, actually ;)
I'd love to have a Drunken Skull to complement my Oktoberfest!
Offline VesperSAINT
  • vpsert
  • #CustomKorean
« Reply #72 on: Mon, 27 January 2014, 03:16:51 »
makeshift
Close enough ;D
:)) tee hee
Thankies, bro~ I'm sure you'll be able to find one too!
Bro.. that almost 10k posts... :eek:
« Reply #73 on: Mon, 27 January 2014, 03:18:56 »
makeshift
Close enough ;D
:)) tee hee
It's on the list, along with a lot of other things :))
Sort of nearer to the top of the list though!
« Reply #74 on: Tue, 28 January 2014, 17:25:47 »
« Reply #75 on: Tue, 28 January 2014, 17:26:47 »
Thats cool it has an external screen!
Offline Pacifist
  • on hiatus
« Reply #76 on: Tue, 28 January 2014, 17:27:25 »
because its a calculator and a keypad
« Reply #77 on: Tue, 28 January 2014, 17:27:46 »
« Reply #78 on: Tue, 28 January 2014, 22:39:02 »
less talk more pics
Offline BunnyLake
  • The OG HHKB Master
  • X
« Reply #79 on: Wed, 29 January 2014, 07:19:34 »
ok
Offline pichu23
  • ୧༼ಠ益ಠ༽୨ FITE ME
  • ʕ ͡·ᴥ ͡· ʔ
« Reply #80 on: Wed, 29 January 2014, 08:20:40 »
many wow. ^
Offline VesperSAINT
  • vpsert
  • #CustomKorean
« Reply #81 on: Wed, 29 January 2014, 12:57:28 »
ok
So so very nice.
Offline baldgye
  • Will Smith Disciple
« Reply #82 on: Wed, 29 January 2014, 14:25:28 »
Offline VesperSAINT
  • vpsert
  • #CustomKorean
« Reply #83 on: Wed, 29 January 2014, 14:30:44 »
ok
So so very nice.
dat gif
what makes it more funny is that i'm korean and that was pretty much my reaction to his pictures :P
Offline baldgye
« Reply #84 on: Wed, 29 January 2014, 14:50:01 »
I miss the young sc2 days when Koreans had personalities :( Genius BM'ing the whole MVP team while he got on his way to the GSL finals made my sub invaluable ^^
Offline gameaholic
« Reply #85 on: Wed, 29 January 2014, 17:49:36 »
This is a BS keypad... Maybe NIB. At least, it came in the box and has no signs of use. Arrived in yesterday's mail.
Nice!  I need one of these.
IBM Model M SSK, Filco MJ2 Ninja TKL with Reds ergo-clears, CM Storm QFR 55g Whites, Poker II with Reds
Offline VesperSAINT
  • vpsert
  • #CustomKorean
« Reply #86 on: Wed, 29 January 2014, 18:41:05 »
Lol... too bad the scene is dying/dead.
Offline wrwhoami
« Reply #87 on: Thu, 30 January 2014, 05:00:33 »
When I see the pictures
I need a keypads! :-\
Offline moonexe
« Reply #88 on: Thu, 30 January 2014, 12:47:39 »
Is there such a thing as a calculator/keypad with MX switches out there?
G80-3000, MX brown           -           Filco Majestouch 2 HAKUA TKL+TK, MX brown, JIS Layout
Offline baldgye
« Reply #89 on: Thu, 30 January 2014, 12:48:19 »
Don't worry the whole game and scene will be fixed with LotV...............
pretty sure if you scroll up on this page you'll see exactly that
Offline moonexe
« Reply #90 on: Thu, 30 January 2014, 12:54:21 »
That's with alps though isn't it? There's a reason I specified MX. :rolleyes:
Offline baldgye
« Reply #91 on: Thu, 30 January 2014, 12:55:09 »
ah ok missed that bit ;)
« Reply #92 on: Sun, 02 February 2014, 03:07:01 »
Shot of my keypad from today.. :)
Offline Paranoid
« Reply #93 on: Sun, 02 February 2014, 05:12:24 »
What a beauty! What keypad is that?
« Reply #94 on: Sun, 02 February 2014, 13:14:20 »
Thank You! Leopold FC210TP with PBT Cherry Profile.
Offline VesperSAINT
  • vpsert
  • #CustomKorean
« Reply #95 on: Mon, 03 February 2014, 19:37:09 »
Never cease to amaze, dood.
Mine changed a lil' today:
Offline neunelfer
  • HHKB Pro
« Reply #96 on: Mon, 03 February 2014, 20:27:54 »
hnnggg
Offline Jokrik
« Reply #97 on: Tue, 04 February 2014, 08:13:13 »
Where did you get that keyboard cover for the keyboard on the top left if I may know?
Offline VesperSAINT
  • vpsert
  • #CustomKorean
« Reply #98 on: Tue, 04 February 2014, 08:16:04 »
hnnggg
:P
It's the keyboard cover that came with my Filco.
Offline mr_a500
« Reply #99 on: Thu, 06 February 2014, 12:28:11 »
 :blank:
« Last Edit: Wed, 04 July 2018, 08:28:22 by mr_a500 »
