Author Topic: Ducky DK 9008S  (Read 3864 times)
Offline cupr
Ducky DK 9008S
« on: Thu, 09 January 2014, 14:07:59 »
Hello.
A year ago a bought DK 9008S. And it was the best kb I ever used.
But sometimes ago I faced with an issue with one switch ("R" letter), suddenly it stopped working after some time in could wor again.
I tried solder that switch but it didn't help at all. It was my first mechanical keyboard. Maybe someone know how to resolve this issue/
KB
DK 9008S
p/n Ducky KB 9008S-B
s/n SACLE 10647
Re: Ducky DK 9008S
« Reply #1 on: Thu, 09 January 2014, 14:09:52 »
Looks like you have cold solder joints. The joints need to be shiny not dull.
Redo the joints so they look like the other joints on the other switches and you should be ok.
Re: Ducky DK 9008S
« Reply #2 on: Thu, 09 January 2014, 15:27:07 »
Welcome to Geekhack!
If you are redoing the solder joints, it might be an opportune moment to also replace the switch, just in case it is a faulty switch.
Offline cupr
Re: Ducky DK 9008S
« Reply #3 on: Thu, 09 January 2014, 15:35:27 »
I have already replaced this switch, but it didi't resolve my issue, so you advice to redoing all solder joint ?
Re: Ducky DK 9008S
« Reply #4 on: Thu, 09 January 2014, 15:40:01 »
As CPT said, the joints don't look shiny, and might not be providing good conductivity.
Offline BlueBär
Re: Ducky DK 9008S
« Reply #5 on: Thu, 09 January 2014, 15:59:02 »
Can we also get a close-up of the solder joints on the R? On the left side it kinda looks like a broken pad.
Also you don't need to redo ALL the solder joints, just on the R switch.
I'm sorry to say this but the soldering you did looks really bad. Did you watch a tutorial on soldering first or did you ever do some soldering before?
Offline laffindude
Re: Ducky DK 9008S
« Reply #6 on: Fri, 10 January 2014, 01:01:00 »
Bridge the 2 pads of the diode to see if it is a bad diode.
Offline BlueBär
Re: Ducky DK 9008S
« Reply #7 on: Fri, 10 January 2014, 02:10:40 »
Take a closer look at the solder joints in the "R" - I highly doubt it's the fault of a broken diode.
Offline cupr
Re: Ducky DK 9008S
« Reply #8 on: Fri, 10 January 2014, 12:43:37 »
There is closer 'R' switch.
I agree my soldering is bad, didn't do thana for 8 years.
Bridge the 2 pads of the diode to see if it is a bad diode. You mean do this by wire?
Alsoo my tools are outaged  :)
Re: Ducky DK 9008S
« Reply #9 on: Fri, 10 January 2014, 17:04:50 »
:eek:
With that soldering iron, you have done a good job!
But with a better iron it might have been perfect.
From those pictures, I would suggest that ideally the joints should be redone.  Also check the continuity between the pins you have soldered and the pins supposedly connected via the traces on the PCB to make sure the traces were not damaged.
Offline cupr
Re: Ducky DK 9008S
« Reply #10 on: Sat, 11 January 2014, 09:35:28 »
Bougth some stuff
Resolder switch, and it began work :)
Now testing it, in previous try it has worked two days.
Offline cupr
Re: Ducky DK 9008S
« Reply #11 on: Sat, 11 January 2014, 10:29:24 »
And again it's back
after couple of hours it stopped working
Offline cupr
Re: Ducky DK 9008S
« Reply #12 on: Mon, 13 January 2014, 12:28:12 »
Resolder it once again, now works!
« Last Edit: Tue, 14 January 2014, 12:09:44 by cupr »
Offline BlueBär
Re: Ducky DK 9008S
« Reply #13 on: Mon, 13 January 2014, 13:27:45 »
I think you just need to train your soldering skills ;)
Offline Linkbane
Re: Ducky DK 9008S
« Reply #14 on: Mon, 13 January 2014, 15:24:07 »
Evidently so, nice job!
Quickfire TK MX Blue Corsair K60 MX Red Ducky Shine 3 Yellow TKL MX Blue Leopold FC660C
Current best: 162 wpm.
