Author Topic: Ugh, another high eBay seller  (Read 3933 times)
Offline bhtooefr
    • bhtooefr.org
« on: Tue, 10 February 2009, 21:38:29 »
http://search.ebay.com/190265435238
Trying to do some research on how much this FKB4725-501 I've got is worth, and I saw that.
Keep in mind, you can buy a new FKB4726-651, which adds PS/2, Windows keys, and N-key rollover to that FKB4700-001, for $70.
Edit: Ahahahaha, an FKB4725, from the same seller...
http://search.ebay.com/190283176319
The funniest part is, he's removed the one key I need, to show off the key stem. :p
Edit 2: Oh snap, RecycledGoods has what looks based on the shadows to be a failed Rit dye attempt (does the case look warped to you, or is it just me?): http://search.ebay.com/200255859272
Offline bhtooefr
    • bhtooefr.org
« Reply #2 on: Tue, 10 February 2009, 22:14:08 »
Oh, that's what that is. (I wasn't looking too closely, and it looked like the shadow of the edge of the keyboard.)
