Author Topic: Blue ALPS broke my heart (question about broken keyboard)  (Read 3338 times)
Offline Cats_Claw
« on: Fri, 10 January 2014, 15:54:24 »
It's my first post on this forum so...
Hello keyboard geeks!  :thumb:
Recently I bought perfect condition KB-6251EA v. 2 with original box, instuctions etc. It has SKCM Blue ALPS although I thought it would be white ALPS, following deskthority wiki.
I felt in love with feeling of these switches (especialy when I consider the low price I paid)  :rolleyes:
Today I had some time to blow it with compresed air and give it a little cleanup with teeth brush.
I did it as I did few times before with other keyboards - I took of cover, disconnected wires from pcb, blow it, and brush beetwen the switches (this time I don't had to use any cleaning liquids, because it was in really good shape).
After the cleaning I connected it back to PC, and it turned out that something is wrong.
Here is what happening:
When PC is OFF, diodes are responding when I'm pressing numlock, capslock, and scrollock;
When I turn on my PC they are turning ON and OFF few times before system boots;
In the login screen (Windows 7), when I press any key, numlock LED blinks, and keyboard don't respond anymore.
I'm using DIN -> PS/2 adapter.
Other keyboard work fine on this PS/2 socket - I'm writing right now on old ALPS-White-like-keyboard (kpt).
I must admit that I've got very excited about that keyboard and I would get depressed if it would break after one day of using...  :confused:
Does anyone had similar issue before?
Offline Cats_Claw
Re: Blue ALPS broke my heart (question about broken keyboard)
« Reply #1 on: Fri, 10 January 2014, 16:50:36 »
I figured it out.
AT/XT switch was in 8088 postion instead of 80286...  ;D
« Reply #2 on: Fri, 10 January 2014, 16:59:49 »
Yay problem solving!
« Reply #3 on: Fri, 10 January 2014, 17:13:17 »
Welcome to Geekhack!
Thanks for posting the solution - it might help someone else later on.
Offline AKIMbO
  • HHKBro
« Reply #4 on: Fri, 10 January 2014, 17:51:30 »
Blue alps are the best!
| KBD75 (box reds)
Offline Daniel Beardsmore
  • RIP
    • Boring twaddle
« Reply #5 on: Thu, 16 January 2014, 17:09:35 »
I wrote that page based solely on the models I was able to find, which is true for most of the wiki — we're only documenting what has been discovered. I'll update the 6251EA entry to note that it was also sold with blue Alps, with a reference back to this topic.
KB-6252 was also discovered with Aristotle Cherry MX clones (not seen those in a Nan Tan before). The weirdest one is the Omron version that uses a steel plate instead of a plastic plate. Gotta love Far East consistency …
Bore Awards
  • RIP
    • Boring twaddle
« Reply #6 on: Thu, 16 January 2014, 18:56:03 »
BTW, are the keycaps doubleshot or pad printed?
Bore Awards
