Author Topic: Fujitsu FKB4725  (Read 7806 times)
Offline 127001
Fujitsu FKB4725
« on: Fri, 10 January 2014, 20:12:03 »
http://www.ebay.com/itm/321295048791
Fujitsu peerless switches apparently. I know nothing about it our the switch but I only see something like this every few months so I thought I'd post it.
Offline ComradeSniper
  • HHKB Pro
Re: Fujitsu FKB4725
« Reply #1 on: Fri, 10 January 2014, 21:55:32 »
Just btw, this is my listing   :)
Offline fourzeropooh
Re: Fujitsu FKB4725
« Reply #2 on: Fri, 10 January 2014, 22:58:13 »
Is it tactile or linear?
  • HHKB Pro
Re: Fujitsu FKB4725
« Reply #3 on: Sat, 11 January 2014, 02:23:12 »
It's fairly tactile, but the tactility goes away if you really hammer on it, which I guess can be said for most keyboards.
Offline berserkfan
Re: Fujitsu FKB4725
« Reply #4 on: Sat, 11 January 2014, 03:16:17 »
So you're 341880?
What's the significance of that number? Just like I'm wondering what's the significance of 127001.
Offline jevvix
Re: Fujitsu FKB4725
« Reply #5 on: Sat, 11 January 2014, 03:24:27 »
As an owner of a Fujitsu Peerless keyboard I'll mention that they are more of a novelty/collector piece rather than an every-day keyboard. Don't know what an AT adapter runs to get that one to work but I'd imagine you could use that as a bargaining chip :p
Offline jevvix
Re: Fujitsu FKB4725
« Reply #6 on: Sat, 11 January 2014, 03:26:23 »
So you're 341880?
With a few .'s it becomes 127.0.0.1 which is the localhost/loopback IP.
Re: Fujitsu FKB4725
« Reply #7 on: Sat, 11 January 2014, 12:33:56 »
Pretty sure plenty of people around here use AT keyboards regularly...
Re: Fujitsu FKB4725
« Reply #8 on: Sat, 11 January 2014, 12:49:51 »
Usually it's just a few dollars for an AT-to-PS/2 adapter, then you can use any PS/2 port or (most) any PS/2-to-usb adapter. I prefer the ID innovations ones, but they are like $15.
So it's not THAT expensive. I have AT to PS/2 adapters (as well as the much less useful other way) that I'm not even using.
  • HHKB Pro
Re: Fujitsu FKB4725
« Reply #9 on: Sat, 11 January 2014, 13:37:31 »
So you're 341880?
It's my mom's account, but the entire family uses it for convenience purposes. "34" was 10-code for police officer in the department that my mom worked at, and "1880" was her badge number.
