Author Topic: Is it possible to remap my un-num-locked keypad's 5 to down arrow?  (Read 2283 times)
Offline kenmai9
  • Unicornforce
  • Skrrr
I have a leopold 210tp, and I want to change my 5 key, when not num locked to be a down arrow. I don't know why in the world they put the down arrow at the 2, when its obviously more natural to do it at the 5.
Does anyone know if I can change it? I tried sharpkeys, but it doesn't register the non numlocked 5.
Thank you
Offline esoomenona
  • Gnillort?
Re: Is it possible to remap my un-num-locked keypad's 5 to down arrow?
« Reply #1 on: Sat, 11 January 2014, 17:05:25 »
I was wanting to do the same thing, but it doesn't register anything, so I'm thinking it's not possible (barring getting into the firmware).
Offline kenmai9
  • Unicornforce
  • Skrrr
« Reply #2 on: Sat, 11 January 2014, 17:46:32 »
Ah, thanks for the confirmation!
Offline tjcaustin
  • King Klaxon
    • Buy stuff
« Reply #3 on: Sat, 11 January 2014, 17:47:09 »
Isn't that the numpad that registers only like the number row?  I thought there was one that works like that instead of a standard number pad.
Offline terran5992
  • One With The Cup Rubber
« Reply #4 on: Sun, 12 January 2014, 00:06:04 »
12128
2012-8
Offline kolonelkadat
  • Location: the vicinity of an area adjacent to a location
    • Force Project X
« Reply #5 on: Sun, 12 January 2014, 02:43:29 »
wouldnt it be possible to write a custom driver for it instead of using the default hid driver?
"Obviously, windows are central to Windows. But what is a window?"
« Reply #6 on: Sun, 12 January 2014, 17:32:37 »
I think a custom driver would work. The OS would load a different driver depending on the Vendor and Product IDs  that it reads from each USB device on startup.
It might also be possible to make a AutoHotkey script select on Vendor and Product ID but I don't know how to do that...
Offline clickclack123
« Reply #7 on: Sun, 12 January 2014, 23:46:26 »
I would love to know how to do the custom driver thing also for my CM Quickfire TK.
Offline damorgue
    • Personal portfolio
« Reply #8 on: Sun, 12 January 2014, 23:54:53 »
Precisely. Leopold have had issues where their numpads send scancodes belonging to the number row, not the numpad. This means that you can't enter alt-codes for special characters and some other weirdness.
