Author Topic: Butterfly Aluminium KeyPad GB  (Read 76876 times)
Offline Rayne
  • For Science!
Re: Butterfly Aluminium KeyPad GB
« Reply #150 on: Wed, 19 February 2014, 23:37:36 »
paid for shipping, thanks nubbinator :D
Offline Aleksander
« Reply #151 on: Fri, 21 February 2014, 13:40:04 »
HOW DO WE PROGRAM THIS?
I don't really need a hotkey for writing "The" all thou it makes it really easy to write TheTheTheTheTheTheTheTheTheTheTheTheTheTheTheTheTheTheTheTheTheTheTheTheTheTheTheTheTheTheTheTheTheTheTheTheTheTheTheTheTheTheTheTheTheTheTheTheTheTheTheTheTheTheThe
Offline chocobunny
« Reply #152 on: Fri, 21 February 2014, 14:53:20 »
Bah could have sworn that I paid shipping.  Apologies for the delay. :)
Offline meiosis
  • Time
« Reply #153 on: Fri, 21 February 2014, 16:39:39 »
I believe you can you Genovation MacroMaster (at least thats what i use for my 356pad)
Keyboards:
Aripeko TKL
Offline Jupiter
« Reply #154 on: Fri, 21 February 2014, 17:37:58 »
Damn, missed out on this. Am very keen now hahha
(Going to be) building Phantom - Red MDPC / White Heatshrink Pexon Cable - WoR/RoW Klaxon - Shiny Titanium Spacebar - Titanium Zerg key
Offline joneslee85
  • HHKB Scrub JP
  • Professional Rubyist programmer!
    • Ruby Journal
« Reply #155 on: Fri, 21 February 2014, 21:58:30 »
What screw are for the case? Is it T6?
TOO MANY KEYBOARDS THAT I COULD NOT COUNT! BUT I AM STILL USING MY MODEL F77
Offline Photoelectric
« Reply #156 on: Fri, 21 February 2014, 22:22:54 »
The ones for the LightSaver fit my T6 metric star-shaped screwdriver.  Probably the same for the keypad.
Offline joneslee85
  • HHKB Scrub JP
    • Ruby Journal
« Reply #157 on: Sat, 22 February 2014, 00:18:58 »
Thx, it is T6
Offline acidtrip69
« Reply #158 on: Sat, 22 February 2014, 02:28:22 »
i will like to ask why does this pad cost so much ? you would think something so small would not cost so much XD lolz
Offline Pacifist
  • on hiatus
« Reply #159 on: Sat, 22 February 2014, 02:30:53 »
How much is one atom of elements with half lives of milliseconds? This pad pales in comparison.
But to answer your question, high quality aluminum
« Reply #160 on: Sat, 22 February 2014, 02:40:27 »
Time and knowledge of CAD to make the product, distributed prototyping cost, small production run, high quality aluminum, milling costs, anodizing costs, PCB SMD component soldering costs, laser cut stainless steel plate (or aluminum, not sure which it is) and so on.  It would be considerably cheaper if it were just the PCB, but a milled aluminum case and laser cut and properly finished plate makes it much pricier.
I couldn't afford one at the time, but, all things considered, it's actually not a bad price for what you're getting.  I think it's actually cheaper than some of the other Korean custom keypads you see pop up on here from time to time.
Offline jonathanyu
« Reply #161 on: Sat, 22 February 2014, 11:37:33 »
you should look at 356pad, then you know this one is not really expensive
« Reply #162 on: Sat, 22 February 2014, 11:49:14 »
All orders have been packaged, all labels have been printed, and all orders I was reshipping will be in the mail shortly.
Offline witbliz
« Reply #163 on: Sat, 22 February 2014, 11:51:20 »
Anybody know where I can buy the bigger brother ? Lightsaver ? Interested :)
Offline jufa
« Reply #164 on: Sat, 22 February 2014, 12:01:23 »
i think lightsaver already sold out, but you can ask elton5354
Offline elton5354
« Reply #165 on: Sun, 23 February 2014, 10:26:26 »
Did that program work? I need to program mine too. It does the same...
Offline KyesaRRi
« Reply #166 on: Sun, 23 February 2014, 23:34:51 »
Having a play with the pad:
To get it into programming mode with the USB unplugged hold down the top left key down then plug the USB in; in Device Manager you will see "ATm32U4DFU" appear. Programming will be done with flip.
When i get home ill have a stab at it.
Got FLIP running, recognizes the pad but I have no idea on how to dump the hex / write my own from scratch.
« Last Edit: Mon, 24 February 2014, 02:36:22 by KyesaRRi »
Offline tjweir
« Reply #167 on: Mon, 24 February 2014, 08:18:57 »
Took a bit of time this weekend and soldered my switches.
Thanks again for organizing Elton.
Offline affect656
« Reply #168 on: Mon, 24 February 2014, 15:40:42 »
Received mine today, thanks nub and elton
I like linear.
Offline Rayne
  • For Science!
« Reply #169 on: Mon, 24 February 2014, 17:23:42 »
got mine today :D thanks elton and nubbs, will post pics when it is done.
Offline jonathanyu
« Reply #170 on: Mon, 24 February 2014, 17:56:06 »
Thanks ;) got mine today
Offline jonathanyu
« Reply #171 on: Mon, 24 February 2014, 19:21:42 »
same here, have no idea how to put the program into it or what program should i use
Offline elton5354
Offline jonathanyu
Offline KyesaRRi
« Reply #174 on: Tue, 25 February 2014, 00:56:43 »
Anyone else having runtime error 76 "02D_KeyMapperForKBD4U"?
Whenever i try to save the program isnt getting a directory list and crashes *sadface*
Offline jonathanyu
« Reply #175 on: Tue, 25 February 2014, 00:59:36 »
just type a name that you want to be the file name, than it will be saved in the folder that contain 02D_KeyMapperForKBD4U
Offline KyesaRRi
« Reply #176 on: Tue, 25 February 2014, 01:25:26 »
Wow, i thought the default would have worked, why didnt i try that.
Haha cheers jonathanyu!
Offline justnits
« Reply #177 on: Thu, 27 February 2014, 11:19:11 »
anybody wants to let go their butterfly pad PCB and/or plate?
Ducky DK9008 Shine 2 Gateron Red w/ Korean 55g gold lubed spring & custom LED | Ergodox with Aluminium top plate | IBM Model M SSK | GHPad | GON's Nerd TKL | Filco Majestouch 2 TKL MX Blue
[Sold]Keycool 87 PBT White Cherry MX Blue | [Sold]ikbc F-104 Cherry MX Brown
Offline nuclearsandwich
« Reply #178 on: Tue, 04 March 2014, 14:33:15 »
Added acrylic sides on the pad
Elton where did you get those made?
« Reply #179 on: Tue, 04 March 2014, 14:35:28 »
I forgot to do so when I had the US orders, but if anyone has an unassembled plate, could you scan it?
« Reply #180 on: Tue, 04 March 2014, 14:38:25 »
I haven't assembled mine yet but I'm not sure if the scanner/copier/printer I have scans properly as I usually use a portable document scanner. I'll give it a shot this evening.
« Reply #181 on: Tue, 04 March 2014, 14:42:26 »
Thanks.  I want try the PCB with Alps and a reference for the plate will make life easier.
Offline elton5354
« Reply #182 on: Tue, 04 March 2014, 14:55:26 »
I have the cad drawing for alps plate. I can email you it.
I got mine from true custom. He doesn't sell them though
« Reply #183 on: Tue, 04 March 2014, 15:14:04 »
Is it a CAD extension? Some of the places I've checked out can't work from that format.  In any case, I'll definitely take it and see if I can make it work.
Offline Aleksander
« Reply #184 on: Fri, 07 March 2014, 15:16:07 »
Just got a refund for the overestimated shipping, Thanks Elton!
Offline ninjadoc
« Reply #185 on: Sun, 09 March 2014, 08:57:21 »
Hmm conflicted on what finish
one of each?
That's about the number of balls my girlfriend will kick if I get both
girlfriend...pffff....just wait until its wife.... ;)
I have no idea what you mean. I'm sure you've NEVER hidden packages from her!
« Reply #186 on: Thu, 20 March 2014, 10:13:53 »
Does anyone know of a way to set the default lighting mode in firmware? I would like to not have to use a key for fn toggle and set up lighting modes and just have the LEDs default to ON.
Offline WinterIsle
« Reply #187 on: Thu, 20 March 2014, 10:58:16 »
Try http://duck0113.tistory.com/84
Offline dadgh
« Reply #188 on: Thu, 20 March 2014, 19:15:24 »
It's surprisingly heavy for its size.
Offline okwchin
« Reply #189 on: Fri, 21 March 2014, 11:06:48 »
Oh it looks soo good!!  :thumb:
I shall need to be on the lookout for one in the future..
Offline kekkon
« Reply #190 on: Sun, 23 March 2014, 07:54:02 »
Hi elton, do you happen to also have the side acrylic drawing for this butterfly pad? :)
Offline Matt3o
  • -[°_°]-
  • ** Robot Emeritus
« Reply #191 on: Wed, 24 December 2014, 02:40:41 »
whops sorry (wrong thread)
Offline tjweir
« Reply #192 on: Sun, 28 December 2014, 12:19:10 »
Does anyone have an extra plate lying around doing nothing?
If so, please PM me, I'd like to use it.
Offline JaccoW
  • Fire Typer!!
  • Keyboard is Lava!
« Reply #193 on: Sun, 12 July 2015, 09:15:11 »
Does anyone have the matrix of these? As in Row/columns to what keys?
Metalliqaz is trying to adapt his Easy AVR USB Keyboard Firmware and Keymapper to several boards. It's a whole lot easier to use for programming and gives a ton of options that the classic TMK firmware doesn't account for such as volume and media keys.
I just got mine a few days ago so I will be making some shots before I send it off to be modified anyway but maybe someone already has the necessary info.
I believe you can find them here. I can check later but I definitely have a pair that fits.
Could be that they are the same ones as for the Lightsaver V1
« Last Edit: Sun, 12 July 2015, 09:19:16 by JaccoW »
|||My other keyboards :
x
Offline E3E
« Reply #194 on: Fri, 14 August 2015, 23:20:21 »
Would anyone happen to have a spare Duck Pad they aren't using or wouldn't mind selling? I'm looking for a silver one. Sorry to bump this thread, but I'm hoping someone might be willing to let one go!
Offline Jersern
  • Australian Keyboard Modding and Repair Service
« Reply #195 on: Wed, 19 August 2015, 03:12:01 »
If only there was a second run ~sighs~
Offline E3E
« Reply #196 on: Mon, 23 November 2015, 13:50:47 »
« Last Edit: Sat, 06 August 2016, 21:39:16 by E3E »
Offline JaccoW
  • Fire Typer!!
  • Keyboard is Lava!
« Reply #197 on: Fri, 03 February 2017, 02:30:44 »
I may or may not have damaged part of the PCB of my keypad while desoldering. :-\
If I wanted to buy a replacement PCB, would KBD4U be the only one that fit this case, or are there other ones that are compatible as well?
x
