Author Topic: Business card source code  (Read 181905 times)
Offline fatchoi
Re: Business card source code
« Reply #50 on: Sat, 17 May 2014, 01:35:47 »
A big thanks to Grendel for his source code. I'm thinking about making a acrylic case for the card when I have time :D
Have to learn some proper drawing software though, I guess it shouldn't be too difficult.
Offline Grendel
« Reply #51 on: Mon, 19 May 2014, 14:32:42 »
Migrated another function from my regular keyboard code into the keycard, a simple countdown timer with 1min resolution up to 255min. I find it quite useful for reminding me that the food should come out of the oven or that I better get ready for a meeting/appointment (as you can tell, I'm not a friend of installing "apps" or another piece of software cluttering my systems ;P)
The attached archive contains the changed source and hex file w/ the timer active, if you want to go back to the previous functionality comment the line "#define __TIMER" at the beginning of kb.c and recompile the code.
The LED's still reflect the NUM, CAPS, and SCR lock status, the NUML and SCRL layers did not change (see build_kbd_report() in kb.c), but the top layer (no LED's active) is now: Left key: cancel timer, middle key: add 10min to timer (and start it if not active), right key: add 1min to timer (and start it if not active.) Once the timer expires the LED's will go nuts until you hit a key (to cancel or restart it.) Be warned:
IF YOU ARE SENSITIVE TO FLASHING LIGHTS OR SUFFER FROM PSE, THIS HAS THE POTENTIAL TO TRIGGER BAD THINGS. Please approach with caution !
The card has now become a permanent fixture in my setup at work. It's pinned to my cube wall at about eye level next to my monitor. That way I can immediately see if I hit a lock key by accident and have easy access to the keys to set/kill the timer. :cool:
« Last Edit: Mon, 19 May 2014, 19:06:29 by Grendel »
- I'm game !
Offline jacksonmr
« Reply #52 on: Mon, 30 June 2014, 13:14:03 »
What do I need to do to get the card up and running on mac osx? specifically 10.9.2
Offline domoaligato
« Reply #53 on: Thu, 10 July 2014, 14:32:18 »
define up and running please... you can just plug it in and it should do the default stuff.
to develop/ customize the card I would suggest installing ubuntu in a vm as it is the easiest way to compile your own hex. flashing should be possible via atmel flip in the vm.
« Last Edit: Thu, 10 July 2014, 14:33:51 by domoaligato »
Offline domoaligato
« Reply #54 on: Thu, 10 July 2014, 14:40:50 »
Mac: Install MacPorts following these instructions: http://www.macports.org/install.php#pkg
Once MacPorts is installed, in a Terminal window, type sudo port install dfu-programmer
Offline jacksonmr
« Reply #55 on: Fri, 11 July 2014, 20:30:42 »
I ended up flashing it on my family pc, thanks for the response though, will do it next time this way.
Offline pichu23
  • ୧༼ಠ益ಠ༽୨ FITE ME
  • ʕ ͡·ᴥ ͡· ʔ
« Reply #56 on: Wed, 03 September 2014, 08:01:25 »
Sorry to bump this thread but anyone knows how to get my leds working again?
I used the Easy AVR USB Keyboard Firmware and Keymapper to reprogram, the leds wouldn't switch on anyhow afterwards :(
Offline freakkater
    • Osu! Card for CTB
« Reply #57 on: Sun, 14 December 2014, 14:02:44 »
Hi there,
i shortened the main techkeys a bit to just have a shift, left and right key like that:
Code: [Select]
uint8_t keys1[] = {KSHIFT};
uint8_t keys2[] = {KLEFT};
uint8_t keys3[] = {KRIGHT};
My problem is now, that the keys are stupidly slow in refresh rate. Where do i change the timings? and what do i have to edit? is it timer.c? Timing was a few lines lower and using a program called switchhitter i got what my problem was. waittimes AND extra keys that got hit.
now my problem is this report, this happens when i hit 2 buttons (shift and left) at the same time:
08:10.0793 Left (0x25, BIOS 0xE04B) DOWN
08:10.0809 Left (0x25, BIOS 0xE04B) UP -> 35ms
08:10.0856 Left (0x25, BIOS 0xE04B) DOWN
08:10.0887 Left (0x25, BIOS 0xE04B) UP -> 35ms
08:10.0918 LShift (0x10, BIOS 0x2A) DOWN
08:10.0949 LShift (0x10, BIOS 0x2A) UP -> 35ms
« Last Edit: Sun, 14 December 2014, 17:12:03 by freakkater »
owner of this sweety: http://osucard.w4f.eu/
