Author Topic: BS boards and lubrication  (Read 2573 times)
Offline ibell7945
« on: Tue, 14 January 2014, 12:49:48 »
As I anticipate the arrival of my Teensy for my Model M 122 key, I've naturally tapped on the keys, just to enjoy that wonderful buckling spring sound. In the course of this, I've discovered that some of these keys seem a little rough and stiff. Though I've heard that lubing is bad for buckling springs (especially membrane models), I've been wondering if this is just urban keyboard legend. Also, if I decide to lube my board, what kind of lube should I use? Will the same lube that works well for cherry MX (stuff like krytox and other PTFE lubricants), work here?
TL;DR
Should I lube my BS board?
IBM 122 Key Model M
Re: BS boards and lubrication
« Reply #1 on: Tue, 14 January 2014, 12:52:30 »
This mini discussion might be a good starting point.
Offline E TwentyNine
    • Some of My Keyboards
« Reply #2 on: Tue, 14 January 2014, 13:14:56 »
I've been using BS keyboards for a long time and have never lubricated one.
Did you take a look at the springs on the keys which are stiff for any dirt/corrosion/rust/deformity?  Or dirt in the barrel?
It could be as simple as the key sitting wrong on the spring, pulling it and putting it back may be enough.
If there is damage to the springs they can be replaced without dismantling the keyboard.
Offline terrpn
  • Alpha Geezer
  • - Buy Vintage -
« Reply #3 on: Tue, 14 January 2014, 14:30:11 »
i actually took an old bs board that has passed its hey day and shoved a bunch of silicone in the spring barrel
linear bs without the click, nothing special and really did not see much of a change in pressure- albeit i did not measure
Luga G80-1865/MX Reds + Dolch G80-1813/MX Blues + G80-3700HQAUS + DK9008G2 Pro/MX Browns Thick PBT + DK9008G2 Pro/MX Clears Thick PBT +  QFR TKL/Ghetto Greens + Cherry G80-1800/MX Blues + IBM Model M SSK Bolt Modded + IBM Model M + IBM Model F + IBM AT F + Cherry G80-1000 (HAD)/MX Vintage Blacks + Razer BWU/MX Blues + Leading Edge DC2214/Blue Alps + Compaq MX11800/Browns + Chicony 5181/Monterey Blues + Chicony 5161/MX Black Cherry Clone + Focus 2001/White Alps + Chicony 5191/White Futabas + Olivetti ANK27-101 + Dell (Old Logo) AT101/Black Alps + NMB RT8255C+/Black Space Invaders + Unitek K260/Green Alps + Apple M0116/Orange Alps + AEK II M3501/Cream Alps + AEK M0115/Orange Alps + NEC  APC412/Blue Sliders + NEC APC410/Blue Sliders + Omnikey /White Alps + Wang/Yellow Alps (Omrons) + Laser/White SMK + Fame/Blue Aruz + AEK II M3501/Salmon Alps + Zenith ZKB-2R/Green Alps + Wang 724/Orange Alps + DK1087/Green Alps + Zenith ZKB-2/Yellow Alps + Dell Old Logo AT101/Salmon-Pink Alps + Leading Edge AK1012/White SMK's + Magitronic SK-1030/White (Linear) Futaba's + Packard Bell/White (Clicky) Futaba's + Datacomp DFK101/White  Alps + SGI AT101/Dampened White Alps + NMB AQ6RT-72511/Grey Space Invaders (Hi-Tek) + Datacomp/Blue Alps + Phillips 2812/White Space Invaders (Linear) + Dah Yang K251/Vintage MX Blues + Chicony 5161/DS Caps/Vintage MX Blue + Archie-NMB AQ659ZRT-725/Black Space Invader (Tactile) + IBM Model M 71G4644 (RD) Bolt Modded with Soarers Converter + IBM Model M Silver Label 1390131 + Cherry G80-1501/Vintage MX Clears + Focus FK8000/Linear Futabas + Gateway 2000 Anykey Programmable/Maxi-Switch + Dell GY13PVAT101/Dye Sub Caps/Salmon Alps + Chicony 5161/White Alps + AST K0B101/Slider over RD + Qtronix QX-32H + Everex/NMB RT8255CW+ Black Space Invaders-Split Erase + Tandon/NMB AQ659ZRT-101A/Beige Space Invaders + Cherry G80-11903 MNRUS/MX Blacks + Apple IIGS A9M0330/SMK Whites + WYSE PCE/MX Blacks + Chicony 5160AXT/Clicky Futaba + Cherry G80-0528/Vintage MX Blacks + Dell AT101/Linear (Modded) Black Alps+Topre 55g
Offline Wildcard
  • When caffeine isn't enough
« Reply #4 on: Tue, 14 January 2014, 14:32:43 »
nvm
« Last Edit: Tue, 14 January 2014, 14:34:52 by Wildcard »
« Reply #5 on: Tue, 14 January 2014, 16:44:21 »
The grease mod that Captain Bad Ass referred you to is a noise-reduction scheme with similar results to the floss mod, not strictly a "lubrication" concept to reduce friction.
I have never lubed anything on buckling springs except for greasing the wire stabilizer clips.
When I get a buckling spring keyboard, I completely disassemble it and thoroughly clean everything, including barrels and sometimes (but rarely) even the spring hammers.
My strong guess is that you have a dirt or corrosion issue.
"you've got to cheat like hell"
- D Trump - 2026-09-10 Dallas, Texas
"The pure products of America go crazy"
- William Carlos Williams - "For Elsie" 1942
Offline ibell7945
« Reply #6 on: Wed, 15 January 2014, 08:44:30 »
Yes, upon further inspection it seems to be an issue with dirt. I don't think I have a corrosion issue because it seems that the barrels are plastic.
IBM 122 Key Model M
« Reply #7 on: Wed, 15 January 2014, 10:40:55 »
I have seen springs rust, especially near the bottom. The barrels (aka chimneys) are always plastic, but on the F they are individual and mount into a steel plate.
« Reply #8 on: Wed, 15 January 2014, 12:31:53 »
I have an M with a few rusted springs that I need to change out.  Surprisingly enough, the keys do not feel that much different...
