Author Topic: Detachable cable kit for 87u?  (Read 2645 times)
Offline tbc
« on: Tue, 14 January 2014, 22:42:50 »
like the title says, i've seen pexon's cable kit for filcos, is there one for the 87u?
i'm fine with being forced to use the center route.
Offline tjcaustin
  • King Klaxon
    • Buy stuff
Re: Detachable cable kit for 87u?
« Reply #1 on: Tue, 14 January 2014, 22:46:18 »
It would pretty much be the same thing.
« Reply #2 on: Tue, 14 January 2014, 22:49:06 »
Are you just wanting a short stub sticking out with a female end on it?
Offline tbc
« Reply #3 on: Tue, 14 January 2014, 22:56:23 »
ya spamray.  a tail is fine.
has anyone actually used this for a realforce? i'm not sure if there is some weird length or cable thickness issue.
« Last Edit: Tue, 14 January 2014, 23:01:08 by tbc »
Offline khaangaaroo
« Reply #4 on: Tue, 14 January 2014, 23:29:23 »
There's enough room for an internal female usb port. I did it here (http://geekhack.org/index.php?topic=45978.0) with a Teensy because I needed to convert from ps2 to usb, but just a female usb port wired directly to the pcb works too. I've done it several times.
Limitations:
- you're limited to the center port (like you mentioned)
- you have to use usb cables with a slim-ish male connector (QFR sized or smaller)
EDIT: if you plan to use the cable kit that sticks out the back, you would need at least 6 inches of cable from the pcb end to the base of the female end to clear the back of the case. Extra length would be ok, because there's enough room inside the case to wind the cable around a few times before exiting the case. Cable width shouldn't be an issue. The channels that hold the cable in place can be cut to make room for wider cables.
« Last Edit: Tue, 14 January 2014, 23:44:18 by khaangaaroo »
Offline terran5992
  • One With The Cup Rubber
« Reply #5 on: Wed, 15 January 2014, 03:12:06 »
Thats alot of work for a small project
Offline MJ45
  • HHKB Pro
« Reply #8 on: Wed, 15 January 2014, 08:06:02 »
Here is a detachable RF 87u mod that I did to mine; http://geekhack.org/index.php?topic=50821.0 The USB breakout board is from SparkFun for $1.95.
