Author Topic: 60% Availability  (Read 5412 times)
Offline dragonxx21
60% Availability
« on: Sun, 19 January 2014, 07:00:32 »
I'm thinking about delving into the world of 60% and am wondering what kind of options I have. I'm looking for a fairly easy to acquire keyboard and off the top of my head the only two I can think of are the KBT Pure and the Poker 2. I also noticed the TEX Beetle and it looked somewhat interesting. What custom keyboards are currently available in the 60% format besides the GH60 which seems to be hard to acquire without getting the PCB made myself. Should I just go for the easy to acquire and popular Poker 2 or are there any better options? Budget is ~$200, but preferably lower.
Edit: Also, is there such a thing as a 60% alps board? I'd assume not but I figured I'd give it a shot.
« Last Edit: Sun, 19 January 2014, 07:05:45 by dragonxx21 »
Keyboards Owned:
Realforce Topre 91 Key JIS Profile - Main
CM Quickfire Rapid Blue Switches
IBM Model M in Industrial Shell
Offline Oobly
Re: 60% Availability
« Reply #1 on: Sun, 19 January 2014, 07:32:39 »
Matias will be announcing a 60% Alps soon. Will have the same edit and arrow keys as the Ergo Pro.
Poker 2, Pure Pro, HHKB Pro2, Tex Beetle are the other popular options that come to mind right now. I guess you could kind of call ErgoDox a 60%.
Buying more keycaps,
it really hacks my wallet,
but I must have them.
Offline nzhao20
« Reply #2 on: Sun, 19 January 2014, 08:46:33 »
There are various gh60 rev b on taobao and you could source switches and all that stuff from the same proxy to keep costs down. This all really depends on if you mind the poker 2 layout. I really don't see a reason to get gh60 unless you have a special layout that you want like hhkb or you just want to build your own keyboard.
Offline Oobly
« Reply #3 on: Sun, 19 January 2014, 13:35:57 »
And Tex have just annouced this: http://geekhack.org/index.php?topic=53669.0
60% board with Trackpoint nub. Uses MX switches for mouse buttons, aluminium case, etc. Nice.
Offline LONGZILLA
  • ヽ(`Д´)ノ rawr
« Reply #4 on: Sun, 19 January 2014, 13:53:27 »
Duckmini V2 supported Alps, but pretty out of your budgets.
Poker is one of the safer 60% choices because of it's layout, works with most standard keycap sets.
Offline reziak
  • Topre/60% Enthusiast
« Reply #5 on: Sun, 19 January 2014, 15:22:25 »
Check out Sprit's GB too!
HHKB Pro 2 | FC660C | HHKB Pro 2 Type-S
Offline dragonxx21
« Reply #6 on: Sun, 19 January 2014, 17:15:31 »
Sprit's GB including everything sadly goes over my budget :(
I'm currently looking at the Poker 2 off of banggood. The white is looking incredibly nice right now :P
Keyboards Owned:
Offline mooswa
« Reply #7 on: Sun, 19 January 2014, 19:01:55 »
For my first 60 board I am going with Sprit.  I figured I have to have a programmable board as all available layouts are not satisfactory IMHO.  I am not getting the case though.  If I end up really liking it, I think there will be cheaper options.  There was (still is?) ali's case for about 50$ shipped in classifieds recently.
Offline swill
  • builder & enabler
    • swillkb.com
« Reply #8 on: Sun, 19 January 2014, 21:03:38 »
Just get the sprit pcb and worry about a case after. Especially if you want alps. I should be able to give you a guide for a DIY case soon. Check my sig.
Offline dragonxx21
« Reply #9 on: Sun, 19 January 2014, 22:41:34 »
What kind of DIY case are you talking about. I have access to literally 0 materials. Also, I really don't want to have just the pcb lying around.
Keyboards Owned:
Offline swill
  • builder & enabler
    • swillkb.com
« Reply #10 on: Mon, 20 January 2014, 00:29:33 »
I plan to set up a buy list with sourcing (will try to get most everything from Amazon.com). Check my case. If you are interested I will work on a guide to source and build it.
Offline dragonxx21
« Reply #11 on: Mon, 20 January 2014, 00:38:37 »
May be interested. Would definitely like to see some prototypes before I commit to anything though.
Keyboards Owned:
Offline Oobly
« Reply #12 on: Mon, 20 January 2014, 01:43:26 »
Oh yes, I forgot the Ducky Mini. It is case-compatible with the Pure and Poker also. Full LED backlighting and 2 function layers, one of which is completely programmable. I have only seen ISO layout so far, though.
https://www.teraset.net/ducky.php#8
« Reply #13 on: Mon, 20 January 2014, 08:49:15 »
There's a Massdrop for the Pure Pro going on right now with the lowest price point met.
Offline LONGZILLA
  • ヽ(`Д´)ノ rawr
« Reply #14 on: Mon, 20 January 2014, 09:45:43 »
From what I've read, there's no plans for a ANSI Ducky Mini. In any case, it's basically a Poker with LEDs
Offline Oobly
« Reply #15 on: Mon, 20 January 2014, 13:09:21 »
I did a little research and it appears you are right! You can actually add the LED's to a Poker II to get the same functionality (seven brightness levels). It has the same programmable 3rd layer.
The more I read about it, the more I like it. Thick PBT caps, programmable, standard ANSI layout and keycap options, plate mounted, removable cable, etc. Would be nice if there were an option to remap Caps to Ctrl without having to use the Pn layer, but that's a small issue. At least you can replace the Win key with Fn on the left side :)
« Reply #16 on: Mon, 20 January 2014, 13:10:11 »
You can also buy a Poker 2 that already has LED's.
Offline tbc
« Reply #17 on: Mon, 20 January 2014, 16:18:46 »
^ but where's my duck :( :P
Offline Linkbane
« Reply #18 on: Tue, 21 January 2014, 10:34:13 »
If you want to try Topre, there's the FC660C for about $190. Otherwise, that seems to cover the non-custom 60% boards.
Quickfire TK MX Blue Corsair K60 MX Red Ducky Shine 3 Yellow TKL MX Blue Leopold FC660C
Current best: 162 wpm.
Offline swill
  • builder & enabler
    • swillkb.com
« Reply #19 on: Wed, 22 January 2014, 10:54:36 »
I am not a huge fan of Topre (i know, call me crazy), but the FC660 boards are a thing a beauty.  I find the layout so perfect and comfortable.  The only reason I have not sold my FC660C is because I enjoy the layout so much.  It is pretty much perfect for me.
« Reply #20 on: Wed, 22 January 2014, 11:01:27 »
You can get the FC660M...same layout...cherry switches!!
Offline swill
  • builder & enabler
    • swillkb.com
« Reply #21 on: Wed, 22 January 2014, 11:32:43 »
Ya I know, but I have 5 boards on their way for me to build, so I can't justify that right now.  :)  I am hoping a 75% board will be my perfect board.  We will see...  :)
« Reply #22 on: Wed, 22 January 2014, 14:58:42 »
5 new boards?
Strong with this one the GH spirit is!
Offline swill
  • builder & enabler
    • swillkb.com
« Reply #23 on: Wed, 22 January 2014, 15:31:10 »
5 new boards?
Haha, ya...  Just got my JD40 which I have to put switches on.  I have two GH60s coming with different plate layouts (I will probably PCB mount one and plate mount the other).  I have a 60 and 75 coming from Sprits GB as well.  Oh, I forgot to include the SmallFry prototype which I will be building as well.  So I guess thats 6.
I need lots of boards to test the different options of my case design.  :)
Offline Pacifist
  • on hiatus
« Reply #24 on: Wed, 22 January 2014, 15:33:36 »
5 new boards?
whats a jd40?
« Reply #25 on: Wed, 22 January 2014, 15:34:48 »
5 new boards?
whats a jd40?
http://geekhack.org/index.php?topic=53617.0
Offline swill
  • builder & enabler
    • swillkb.com
« Reply #26 on: Wed, 22 January 2014, 15:36:58 »
5 new boards?
whats a jd40?
It is similar to the SmallFry 40% board but it is powered by a Teensy instead of an on board controller.  There are a bunch of other differences, but thats the main difference...
Offline Pacifist
  • on hiatus
« Reply #27 on: Wed, 22 January 2014, 15:46:12 »
5 new boards?
whats a jd40?
Ah, whats better? Is it easier to modify?
Offline swill
  • builder & enabler
    • swillkb.com
« Reply #28 on: Wed, 22 January 2014, 16:03:13 »
5 new boards?
whats a jd40?
I don't want to derail this thread anymore than we already have, but here you go.
The SmallFry is an improved version of the JD40.  Some differences are (from JD):
1. SmallFry has holes in the PCB for PCB-mount switches. (JD40 requires a switch mounting plate)
2. SmallFry has holes in the PCB for PCB-mount stabilizers. (see above)
3. SmallFry has an ATmega32U4 controller mounted onboard. (JD40 used a Teensy)
4. SmallFry has LED pads connected to traces, as on the GH60.  (JD40 has led holes, but they are not connected to any traces)
5. SmallFry has mounting holes in the PCB for use with standoffs in cases.  (JD40 does not have mounting holes, so it requires a special sandwich case)
Things I am not totally sure about:
- The JD40 is all through hole.  I think the SmallFry has some SMD pads.
