Author Topic: lokking for a new keyboard: TKL, detachable cable, MX red, plated mount  (Read 3296 times)
Offline Heimdallr
Hi all,
i want to buy a new keyboard, the requirements are these:
tenkeyless
detachable cable
mx red (possibly, but i can also go for blue or green)
plated mount
Of course it must be a solid choice and readily available, i don't want to shop on taobao or wait some group buy, i would like to have it in a short time.
I was about to buy another Filco but it lacks the detachable cable, until now my only option seems to be a wasdkeyboard v2.
Is there another contender?
thanks
stefano
Re: lokking for a new keyboard: TKL, detachable cable, MX red, plated mount
« Reply #1 on: Thu, 23 January 2014, 01:47:37 »
cmstorm quickfire rapid meets all the requirements, I think.
« Reply #2 on: Thu, 23 January 2014, 03:14:06 »
QFR, or Ducky perhaps.
Offline Suichoy
« Reply #3 on: Thu, 23 January 2014, 06:01:06 »
Leopold is also an option and is cheaper than WASD or Filco. I like the design of my Leopold better than my QFR in pretty every way but I have to admit the non-standard spacebar is a big PITA.
Offline bazh
« Reply #4 on: Thu, 23 January 2014, 06:04:42 »
maybe CODE keyboard ?
HHKB Pro2 white
Newbie again
Offline xuanwumen
  • * Commercial Vendor
    • EZKB
« Reply #5 on: Thu, 23 January 2014, 08:28:40 »
will this meet ?
NIZ KEYBOARDS VENDOR
« Reply #6 on: Thu, 23 January 2014, 08:31:56 »
Leopold 700R?
Wait, that might not be a good option if you don't want to wait for shipping since the easiest way to get one is from HendyZone and he's in Indonesia.
Offline Heimdallr
« Reply #7 on: Thu, 23 January 2014, 10:01:35 »
will this meet ?
yes it looks good, i didn't remember keycool had removable cable, i will check it out.
I tought about that but it's completely out of stock, also i could save some money ordering a barebone V2.
At first I discarded Leopold for this very reason (non-standard spacebar).
I tought Ducky had a tenkeyless model without backlighting?
Thank you all.
stefano
Offline Linkbane
« Reply #8 on: Thu, 23 January 2014, 11:15:09 »
I think that Ducky has the Zero, but I'm not sure if it comes in TKL version. Keycool and QFR should also be quite good, and a Filco if you're looking to spend more.
Quickfire TK MX Blue Corsair K60 MX Red Ducky Shine 3 Yellow TKL MX Blue Leopold FC660C
Current best: 162 wpm.
« Reply #9 on: Thu, 23 January 2014, 11:17:07 »
Ducky Year of the Dragon.
Offline tbc
« Reply #10 on: Thu, 23 January 2014, 11:58:52 »
Just get a shine 3 and turn off the backlights.
As long as the presence of LEDs that aren't even turned on don't offend you, you'll save alot of time waiting.
Offline Heimdallr
« Reply #11 on: Fri, 24 January 2014, 01:27:19 »
thank you all, i think i will take a ducky shine 3 or a wasdkeyboard v2.
Someone can tell me where the shine 3 is available?
thanks
stefano
Offline Moosecraft
  • HHKB Pro
« Reply #12 on: Fri, 24 January 2014, 01:53:58 »
mechanicalkeyboards.com
Offline BakerMan1971
« Reply #13 on: Fri, 24 January 2014, 04:40:04 »
I can second the recommendation of the Keycool 87  I have an 87II backlit, Extremley good keyboard
The FlashGet G600 has full NKRO on USB and is quite literally plate mounted a bit like a Corsair K65
Offline isaske
  • Stop whining!
« Reply #14 on: Fri, 24 January 2014, 05:54:50 »
Leopold 700R?
He ships very fast.
HOW DO I COMPUTER?
Offline Heimdallr
« Reply #15 on: Fri, 24 January 2014, 15:57:17 »
Thanks guys
stefano
