Author Topic: Model M right Shift key problem  (Read 1382 times)
Offline ricekin
« on: Sat, 25 January 2014, 13:06:49 »
Hello,
has anyone else here ever had problems with their right shift keys on one of these keyboards? Mine has recently caused me some worries. Namely, when I press on the right hand side it would get stuck, probably by the tilt. I have been able to mitigate the problem by putting a small amount of silicone grease in both holes, but the key now sort of feels mooshy and I get the feeling that if I don't fix the underlying cause, I will subject it to excessive wear.
Any ideas?
Thanks
Re: Model M right Shift key problem
« Reply #1 on: Sat, 25 January 2014, 14:01:08 »
Whatever the problem is, lubrication is not likely to be the solution.
Could you attach a photo with the key removed?
If it is an old one (pre-1989) with a wire stabilizer, did you verify that the stabilizer was properly seated under the hold-down tabs?
And here is something else, from the good folks over at Deskthority:
http://deskthority.net/workshop-f7/binding-sticking-of-oversize-keys-on-model-m-s-t6535.html
« Last Edit: Sat, 25 January 2014, 14:24:10 by fohat.digs »
- D Trump 2026-09-28
