Author Topic: Your Apple Extended Keyboard's new best friend  (Read 5078 times)
Offline Jaydoublem
« on: Sat, 21 February 2009, 17:16:38 »
http://cultofmac.com/retro-mac-hacker-puts-mini-inside-disk-drive/8381#more-8381
This would be a great combination with an AEK and the original Apple Mouse / Optical Mouse hack.
Offline bhtooefr
    • bhtooefr.org
« Reply #1 on: Sun, 22 February 2009, 12:33:22 »
Only problem is, the AEK will look too new next to that thing...
Put a USB keyboard controller on an Apple //e's keyboard (which uses a key matrix, and even has Open Apple (Command) and Closed Apple (Option) keys,) though. Then it'll look right.
Even if the computer is actually in the floppy drive, not the computer itself. :p
All that leaves is adapting the Mini's output to composite, but that's not a problem. Hook it up to an Apple Color Composite Monitor for maximum win. :)
Offline cmr
« Reply #2 on: Mon, 23 February 2009, 15:54:37 »
I only use my AEK2 in Windows Vista. How's that for blasphemy?
Offline bhtooefr
    • bhtooefr.org
« Reply #3 on: Mon, 23 February 2009, 23:07:30 »
Dude, the computer gods are waiting for a great time to smite you. :p
Offline FKSSR
« Reply #4 on: Fri, 06 March 2009, 12:35:00 »
I saw that retro hack a little while ago.  I'm not into macs, but I like the idea.  I thought of doing something similar with a windows machine, but I have to find the right hardware to do it.
Add me on Steam | Twitter
Offline bhtooefr
    • bhtooefr.org
« Reply #5 on: Fri, 06 March 2009, 14:04:28 »
A Nano-ITX board would probably do the trick...
