Author Topic: Topre spacebar springs  (Read 1913 times)
Offline kelske
  • The North Borders
« on: Tue, 28 January 2014, 13:41:30 »
I'm pretty inexperienced at spring shopping...  :rolleyes:
Anyone know what I should be searching for if I want to find a substitute for these springs they stick under Topre spacebars? I'd be looking for 5-10g, must be same diameter to fit over the topre plunger, would be interested in about 60 of them.
Here's to shots in the dark!
Re: Topre spacebar springs
« Reply #1 on: Tue, 28 January 2014, 13:42:31 »
There was a similar thread recently I believe someone had taken some springs from an older board and modified them.
Offline Wildcard
  • When caffeine isn't enough
« Reply #2 on: Tue, 28 January 2014, 13:45:38 »
That would be me. I've got a good system down for these replacement springs. Shoot me a PM and I'll get you some replacements.
Offline kelske
  • The North Borders
« Reply #3 on: Tue, 28 January 2014, 14:24:09 »
Sweet! YGPM
« Reply #4 on: Wed, 29 January 2014, 21:40:05 »
Unless the idea above involves hand-making a replacement spring, or disassembling a Topre keyboard, I don't think I've seen replacement springs for sale anywhere.
And anything Topre seems to be getting harder to get these days.
Offline Hypersphere
« Reply #5 on: Thu, 10 April 2014, 16:16:56 »
I have also been looking for these springs (the ones used under the spacebar on the HHKB Pro 2). Per your suggestion, I've also sent you a PM. Thanks.
