Author Topic: DIY Lego Poker 2 Case (K70 style)  (Read 4268 times)
Offline koki
« on: Sat, 01 February 2014, 16:01:16 »
So if you are like me and you don't have money but you have a lot of legos, you can make one of these. :)
Hope the images work if not here: http://slokoki.imgur.com/all/
If anybody does this and hopefully can make it better looking than me, please post below pictures or just tell me! :D
It doesn't look that cool, but I like the K70 style where you can see the switches.  :thumb:
Offline billnye
  • ability man
Re: DIY Lego Poker 2 Case (K70 style)
« Reply #1 on: Sat, 01 February 2014, 16:04:25 »
Looks pretty cool!
I think I know someone else who likes to make keyboard things from legos.....
Offline syNRG
« Reply #2 on: Sat, 01 February 2014, 16:20:46 »
Wow i like it. Post more pictures? I'd like to see a bit more. Could you also post pictures of just the case?
Offline koki
« Reply #3 on: Sat, 01 February 2014, 16:21:55 »
Coming in a few minutes :)
Offline koki
« Reply #4 on: Sat, 01 February 2014, 16:35:26 »
Here you guys go! :D Sorry for bad quality I am really bad with cameras!  :(
Bam hope it's enough! ;) :thumb:
« Reply #5 on: Sat, 01 February 2014, 16:46:04 »
Some other threads with some info on these cases, there may be more around as well.
http://geekhack.org/index.php?topic=51730.msg1139705#msg1139705
http://geekhack.org/index.php?topic=40251.0
I am hoping to one day attempt a TKL case out of Lego, although since I sold my phantom kit, I do not know when I will get around to it.
Offline koki
« Reply #6 on: Sat, 01 February 2014, 16:48:14 »
Ahhhhh  >:D Now I don't feel special anymore  :(
Offline dragonxx21
« Reply #7 on: Sat, 01 February 2014, 17:47:06 »
How's the wiggle room? Do you find that the pcb moves around a lot inside of the case?
Keyboards Owned:
Realforce Topre 91 Key JIS Profile - Main
CM Quickfire Rapid Blue Switches
IBM Model M in Industrial Shell
Offline koki
« Reply #8 on: Sat, 01 February 2014, 17:52:03 »
No dude it's a perfect fit! Like to a milimeter!  :thumb:
« Reply #9 on: Sat, 01 February 2014, 17:59:03 »
Mine was a little loose, used a piece of folded paper to make it glove fit. I never did get around to securing the pcb to the bottom either, but I had a plan to glue the pieces that connect to others onto the pcb(the circle ones that plug in and can rotate).
Offline dragonxx21
« Reply #10 on: Sat, 01 February 2014, 19:02:49 »
I still need to do something like this... Now to find a place to get a poker 2 PCB >.>
Keyboards Owned:
« Reply #11 on: Sat, 01 February 2014, 19:14:07 »
Just grab a GH60 pcb and build away!
Offline dragonxx21
« Reply #12 on: Sat, 01 February 2014, 22:07:10 »
Any idea when they are coming out with the final revision? I know there's a bunch of Rev Bs on Taobao but I've never actually ordered from there before.
Keyboards Owned:
Offline syNRG
« Reply #13 on: Sun, 02 February 2014, 01:10:29 »
So nice, thanks for more pics!  :D
