Author Topic: Best place to get blank keycaps for customising  (Read 2044 times)
Offline kakakowie
  • Make Love not War
« on: Mon, 03 February 2014, 09:22:29 »
Would anyone recommend a site to order blank keycaps that are suitable for customisation?
I only know of wasdkeyboards, they seem to be the only site selling individual blank keycaps.
I also have a filco tenkeypad and this apparently has a row 5 key profile that is higher than any other key. Is it possible to get these or will i have to make do with row 4 keycaps?
Thanks,
Lionel
Offline Excessive
  • Signature Plastics
Re: Best place to get blank keycaps for customising
« Reply #1 on: Mon, 03 February 2014, 09:36:56 »
You can try SP. They have a DSA set here: http://keyshop.pimpmykeyboard.com/product/dsa-pbt-blank-sets
Offline Oobly
« Reply #2 on: Mon, 03 February 2014, 09:42:01 »
http://www.banggood.com/PBT-87-Blank-White-Key-Caps-For-Cherry-MX-Keyboard-p-84084.html
Blank white PBT OEM profile. They accept dye well. Nice price, too :D
Buying more keycaps,
it really hacks my wallet,
but I must have them.
Offline kakakowie
  • Make Love not War
« Reply #3 on: Mon, 03 February 2014, 10:17:50 »
Thanks for the replies,
I forgot to mention that i'm using a Filco Tenkeyless and would like to match the profile as much as possible.
It gives me a headache just looking at all the different key profiles and sizes.
The one from banggood seems ok, save for the transparent strip on the caps and scroll lock.
