Author Topic: Ducky Shine 3 Help with commands  (Read 21781 times)
Offline Adava
« on: Tue, 04 February 2014, 14:26:38 »
Hi!
I had a Ducky shine 3 before and switched to Ducky Shine 3 Gold edition but I'm having a hard time figuring out how I max the light on the spacebar, but keeping the color purple.
I also have a hard time setting a saved mode to (1), (2) on numpad. How do I do that?
And finally, max the light on the mode where the keys light up when you press them. Here I want the maxed light and at the same time , fading away in 1 sec instead of 4.
Offline Grendel
Re: Ducky Shine 3 Help with commands
« Reply #1 on: Tue, 04 February 2014, 15:39:48 »
Check the manual ? Additional info here.
- I'm game !
Offline C5Allroad
  • Formerly HUNTERANGEL121
« Reply #2 on: Tue, 04 February 2014, 17:04:28 »
To save a color to the numpad press alt+Fn and then a number of your choosing.
Hit Fn+F10 a few times and once you're on the reactive lighting mode press Fn+ the arrows keys.
« Last Edit: Tue, 04 February 2014, 17:10:41 by HUNTERANGEL121 »
Offline Adava
« Reply #3 on: Tue, 04 February 2014, 17:53:08 »
When I was press alt+fn +1 it just goes black and I  have to set the color again.
And with the arrow keys - well, upwards just increases the lightning. I want this, on max, but still keep the mode! When I max it, the keys are on max light - all of them - without me even pressing them. And left to right have no effect while they are all highlighted.
Offline C5Allroad
« Reply #4 on: Tue, 04 February 2014, 18:28:34 »
Ok I found it.... Fn + R_Alt + ↑↓
That's for the reactive mode...
To save a color for me it's  Fn + R_Alt any number....
Holding Fn+F10 turns all of the lights off on the new 1.1.8 firmware.
Offline Adava
« Reply #5 on: Wed, 05 February 2014, 08:11:42 »
Awesome. Thank you very much sir.
