Author Topic: Paintjob  (Read 1896 times)
Offline ianxblog
  • no
Paintjob
« on: Fri, 07 February 2014, 12:48:36 »
Hello.
I want to paint a keyboard blank white.
The board and the keycaps.
They are not PBT or anything, regular plastic.
Laser engraved infilled.
Is there any prodecure I should do before painting?
I'd be using spray paint for plastic, is this ok?
Would it be sticky?
Thanks.
Offline digi
  • elite af tbh
  • keyboard game on fleek
Re: Paintjob
« Reply #1 on: Fri, 07 February 2014, 12:50:10 »
Online Findecanor
Re: Paintjob
« Reply #2 on: Fri, 07 February 2014, 17:27:20 »
I would advice against painting keycaps. It may look good at first, but the paint will wear off with use.
If the board has Cherry MX switches, then there are several options for replacement keycaps that are blank and white.
Offline HPE1000
  • Keycap Paparazzo
Re: Paintjob
« Reply #3 on: Fri, 07 February 2014, 17:28:49 »
Yeah, please dont paint the keycaps, you will regret it.
You can get cheap blank white pbt keycaps from banggood for 17 or do dollars shipped although the shipping is slow.
