Author Topic: Classic Beige set for Filco?  (Read 4702 times)
Offline lolkey
« on: Sat, 08 February 2014, 17:16:12 »
Does anyone know where I can get a classic beige otaku set for a filco? Something like this -
filco ninja mj2 tkl · mx brown · black case · blank black pbt
varmilo va87mr tkl · gateron red · black case · dye sub pbt ❤
vortex pok3r rgb · mx silent · white case · blank xda pbt
Offline lolkey
Re: Classic Beige set for Filco?
« Reply #2 on: Sun, 09 February 2014, 10:55:30 »
Offline intelli78
« Reply #3 on: Sun, 09 February 2014, 11:33:03 »
http://www.originativeco.com/collections/keysets/products/bsp-classic-beige
I don't think that is a complete set for the Filco, unless I'm missing something.
That set is the appropriate layout for the keyboard in the OP's post, but AFAIK Filcos have 1.25x modifiers, so yes you'll be short a bunch of modifiers
« Last Edit: Sun, 09 February 2014, 11:35:01 by intelli78 »
Offline Photoelectric
« Reply #4 on: Sun, 09 February 2014, 11:38:25 »
The BSP dye sub set doesn't have 1.25x modifiers or a spacebar.  If you want similar looking Cherry profile thick PBT keycaps that would fit a TKL or a full-sized Filco, your best bet is to get a blank set from IMSTO.  It will have all the proper sized caps for a standard Filco.
Offline iAmAhab
  • Established member
« Reply #5 on: Sun, 09 February 2014, 11:38:42 »
You should talk to imsto, he can probably provide a blank two tone pbt set.
Offline IvanIvanovich
  • Mr. Silk Underwear
« Reply #6 on: Sun, 09 February 2014, 12:09:04 »
If imsto is out... I will be doing another round of groupbuy for these in mid spring if you can wait.
Offline t2russo
« Reply #7 on: Sun, 09 February 2014, 13:07:41 »
Yuuuus.  Fixed capslock or are folks just gonna have to nut up and deal with it?
« Reply #8 on: Sun, 09 February 2014, 13:21:58 »
I will make sure it is done right next time... Actually, assuming everything is all good with using PLUM I will likely use them moving forward for PBT. PLUM have a lower MOQ and seem to be a lot more willing to do certain things.
Offline intelli78
« Reply #9 on: Sun, 09 February 2014, 13:39:28 »
Look forward to it!
Offline gameaholic
« Reply #10 on: Mon, 10 February 2014, 13:04:04 »
Awesome I'm basically looking for the Originative two tone set but with fixed tab, extra stepped capslock, and windows 8 logos.  I'm in for at least 2.
IBM Model M SSK, Filco MJ2 Ninja TKL with Reds ergo-clears, CM Storm QFR 55g Whites, Poker II with Reds
Offline lolkey
« Reply #11 on: Mon, 10 February 2014, 13:28:47 »
Contacted him, but he only has the set with a white caps lock key which is a bit odd.
Want this so badly:
Offline 1pq
  • Hipster Doofus
« Reply #12 on: Mon, 10 February 2014, 15:06:34 »
YUS! Great news :thumb:
main kbs:  87UB (55g)  Custom Filco TKL (62g clears)
WTS JD40, Custom Ergoclear Filco
WTB ROHS Red BBv2 (Topre), OG EK Tri-Color Skull (TOPRE)
Offline berserkfan
« Reply #13 on: Thu, 13 February 2014, 00:56:45 »
btw, SpamRay has been trying to sell a similar set, except it's got legends. Maybe he can give you a tip or two.
Offline CatNip :3
  • bouncy bouncy
« Reply #14 on: Thu, 13 February 2014, 01:04:49 »
YUSSSSSS! :D
Offline CommonCurt
  • One of the cool kids
  • 🍒 Beige or Bust
    • My Flickr Page
« Reply #15 on: Thu, 13 February 2014, 01:12:48 »
Yes :)
When you do could you please add the option to get blank win caps if you decide to use the win8 logo on the sets with legends?.
I simply can not force myself to like that win8 logo.
Some of Ye ole  Keyboards -->
WTB/WTS/WTT ---->
Offline phoenix1234
« Reply #16 on: Thu, 13 February 2014, 01:36:21 »
Want this so badly:
If I'm not missing any thing, the image that you quoted is Imsto blank.
It is the one that you are looking for - Otaku for Filco.
You can see in the right top corner the white cap locks with center stem and the stepped cap locks with off-center stem.
I like linear switches
