Author Topic: Model M on modern pc  (Read 5987 times)
Offline ianxblog
  • no
« on: Sun, 09 February 2014, 02:54:44 »
Does the IBM Model M fully work on a modern PC using a AT to PS/2 adapter?
That's it, thanks :)
Offline intelli78
Re: Model M on modern pc
« Reply #1 on: Sun, 09 February 2014, 03:12:31 »
Yes.
Offline damorgue
    • Personal portfolio
« Reply #2 on: Sun, 09 February 2014, 03:15:23 »
Not guaranteed. Even though your motherboard has a PS/2 connector it might not be able to supply enough current, something which has been an issue with PS/2 ports on modern motherboards.
Offline ianxblog
  • no
« Reply #3 on: Sun, 09 February 2014, 03:19:51 »
How can i know?
Its a pretty "dated" motherboard. Bought on 2009
GA-G31M-ES2C rev 1
Offline quickcrx702
  • Ready to bomb with Vietnam tatted on my back
Offline EDI
« Reply #5 on: Sun, 09 February 2014, 04:50:17 »
I thought this "not enough current" thing only applied to USB to PS/2 adapters.
AT and PS/2 are basically the same connector. PS/2 is only smaller.
« Reply #6 on: Sun, 09 February 2014, 07:43:18 »
You start losing current as soon as you leave the source.
Every inch of wire and every mechanical connection causes you to lose something, so you should always strive to keep cable lengths and numbers of connections to a minimum.
That said, I have been pretty lucky, and have used long cables and multiple connectors with few problems.
- D Trump 2026-09-28
Offline aref
« Reply #7 on: Sun, 09 February 2014, 10:57:26 »
I recently bought a new PC and my Model M KBs work fine under PS/2 and USB.
Also, I found the standard Model M cable allows for all functions to work as they
should. An (aftermarket) USB cable I bought would not wake my PC; and occasionally
the keyboard would lag. When I went back to the standard Model M cable, the KB
worked with no issues.
Offline intelli78
« Reply #8 on: Sun, 09 February 2014, 11:02:18 »
Interesting info, I stand corrected...
Offline terrpn
  • Alpha Geezer
  • - Buy Vintage -
« Reply #9 on: Sun, 09 February 2014, 11:47:48 »
my model m will function after booting with the generic (purple end) converter- but no LED's.......
the generic (purple end) works with all my other ps2 boards- no issues
works like a charm with the "ziotec" straight up- immediately :thumb:
Luga G80-1865/MX Reds + Dolch G80-1813/MX Blues + G80-3700HQAUS + DK9008G2 Pro/MX Browns Thick PBT + DK9008G2 Pro/MX Clears Thick PBT +  QFR TKL/Ghetto Greens + Cherry G80-1800/MX Blues + IBM Model M SSK Bolt Modded + IBM Model M + IBM Model F + IBM AT F + Cherry G80-1000 (HAD)/MX Vintage Blacks + Razer BWU/MX Blues + Leading Edge DC2214/Blue Alps + Compaq MX11800/Browns + Chicony 5181/Monterey Blues + Chicony 5161/MX Black Cherry Clone + Focus 2001/White Alps + Chicony 5191/White Futabas + Olivetti ANK27-101 + Dell (Old Logo) AT101/Black Alps + NMB RT8255C+/Black Space Invaders + Unitek K260/Green Alps + Apple M0116/Orange Alps + AEK II M3501/Cream Alps + AEK M0115/Orange Alps + NEC  APC412/Blue Sliders + NEC APC410/Blue Sliders + Omnikey /White Alps + Wang/Yellow Alps (Omrons) + Laser/White SMK + Fame/Blue Aruz + AEK II M3501/Salmon Alps + Zenith ZKB-2R/Green Alps + Wang 724/Orange Alps + DK1087/Green Alps + Zenith ZKB-2/Yellow Alps + Dell Old Logo AT101/Salmon-Pink Alps + Leading Edge AK1012/White SMK's + Magitronic SK-1030/White (Linear) Futaba's + Packard Bell/White (Clicky) Futaba's + Datacomp DFK101/White  Alps + SGI AT101/Dampened White Alps + NMB AQ6RT-72511/Grey Space Invaders (Hi-Tek) + Datacomp/Blue Alps + Phillips 2812/White Space Invaders (Linear) + Dah Yang K251/Vintage MX Blues + Chicony 5161/DS Caps/Vintage MX Blue + Archie-NMB AQ659ZRT-725/Black Space Invader (Tactile) + IBM Model M 71G4644 (RD) Bolt Modded with Soarers Converter + IBM Model M Silver Label 1390131 + Cherry G80-1501/Vintage MX Clears + Focus FK8000/Linear Futabas + Gateway 2000 Anykey Programmable/Maxi-Switch + Dell GY13PVAT101/Dye Sub Caps/Salmon Alps + Chicony 5161/White Alps + AST K0B101/Slider over RD + Qtronix QX-32H + Everex/NMB RT8255CW+ Black Space Invaders-Split Erase + Tandon/NMB AQ659ZRT-101A/Beige Space Invaders + Cherry G80-11903 MNRUS/MX Blacks + Apple IIGS A9M0330/SMK Whites + WYSE PCE/MX Blacks + Chicony 5160AXT/Clicky Futaba + Cherry G80-0528/Vintage MX Blacks + Dell AT101/Linear (Modded) Black Alps+Topre 55g
Offline kod
« Reply #10 on: Mon, 10 February 2014, 12:06:15 »
I've had no trouble using model Ms on reasonably modern dell desktops with a generic adaptor.
Offline aref
« Reply #11 on: Mon, 10 February 2014, 20:12:59 »
http://pckeyboard.com/page/UKBD/UNI0P4A
http://pckeyboard.com/page/UKBD/UB40P4A
I have a Unicomp Ultra Classic and it's a nice keyboard. Lexmark's buckling-spring switch, licensed by IBM and I was told taken over by Unicomp, is a nice switch. It has a slightly different feel from my original IBM Model Ms, requiring a little less down force to actuate each key; and (to me) the keys feel as if they have a bit more travel than my original Model Ms. Regardless, the keyboards are a good buy and perform flawlessly on older and newer PCs. I first used mine on a five-year-old PC and now on a new Dell desktop. I picked up a black Ultra Classic with gray key caps; it looks great and is not as wide as a traditional Model M; and at $79, it's a good value. I'd use it more of the time if I wasn't so enamored of my RF87U and SSK.
« Reply #12 on: Mon, 10 February 2014, 22:44:35 »
I'm not convinced that purpose one is as generic as you may think. It looks like the excellent ID innovations multimode USB adapter and should perform admirably without issue.
