Author Topic: Has anybody made a keyboard case / housing out of PBT?  (Read 6102 times)
Offline Kamen Rider Blade
« on: Mon, 10 February 2014, 01:20:27 »
Just curious as to whether any keyboard case / housing is made out of PBT instead of ABS?
BTW, I'm not talking about Keycaps.
If anybody knows this answer and can point at an example, that would be great.
Offline jacobolus
Re: Has anybody made a keyboard case / housing out of PBT?
« Reply #1 on: Mon, 10 February 2014, 02:22:22 »
Matias makes theirs out of polycarbonate.
Offline Comment
« Reply #2 on: Mon, 10 February 2014, 02:30:26 »
IIRC polycarbonate and PBT are different substances.
Check out my WTB/WTS/WTTF Thread!
   HHKB Pro 2                 Noppoo Choc Mini
Offline jacobolus
« Reply #3 on: Mon, 10 February 2014, 03:28:56 »
Obviously. https://en.wikipedia.org/wiki/Polybutylene_terephthalate https://en.wikipedia.org/wiki/Polycarbonate
The OP may still be interested, though, as polycarbonate has many material advantages over ABS.
Offline Zeal
    • Zeal Generation Inc.
« Reply #4 on: Mon, 10 February 2014, 04:42:45 »
I don't think it would be a wise idea to mold a case out of PBT as PBT is naturally brittle -- it would cause unneeded troubles during shipping for the retailer+manufacturer.
« Reply #5 on: Mon, 10 February 2014, 05:32:20 »
Zeal got it. You want a plastic that is impact-resistant, I.e. bends instead of cracks if it is bent. PC is good at that. ABS exists in several types, of which some are more than others. There is also PC-ABS blend and PVC.
PVC is being phased out because manufacturing byproducts being harmful for the environment.
« Reply #6 on: Mon, 10 February 2014, 07:37:00 »
We call such a material property "toughness". It's the area under the stress/strain curve and represents how much energy a material can absorb before failure. Diamonds have high (very high) young's modulus, but very low toughness: you can crack them with a hammer (they also burn. I've never been a fan). PBT is the same way (you can look up the destructive hammer test for PBT)
As far as other materials, assuming cost is no object, PC/ABS blends were very popular for computer cases a few years ago, now it seems everyone has moved to magnesium (which has similar issues to PBT: It's not ductile enough for my taste) or a fiber reinforced PC/ABS blend. The reinforcing fibers sacrifice some durability in favor of much higher strength: it's really up to the use case if this is a good idea or not.
I'd like to see a FR-PC+ABS keyboard case, but I'm not sure it'll be cheap enough.
« Reply #7 on: Mon, 10 February 2014, 13:01:21 »
What do you mean when you state "FR-PC", what material is that?
« Reply #8 on: Mon, 10 February 2014, 13:03:27 »
Filler/Fiber reinforced polycarbonate and ABS blend I'm guessing?
Offline PolaBurrr
« Reply #9 on: Mon, 10 February 2014, 13:55:17 »
iirc, the majestouch 2 newer revisions have been made with pbt casing.
Offline neunelfer
  • HHKB Pro
« Reply #10 on: Mon, 10 February 2014, 13:58:05 »
I remember reading this as well. The case of my MJ2 has a rough texture while my Filco keypad has a smooth texture.
« Reply #11 on: Mon, 10 February 2014, 20:21:43 »
Now I understand why manufacturers use ABS for keyboard case's / housing's.
That bending nature of it is very nice compared to shattering under high pressure.
Offline Elrick
  • Hype Master
  • Keyboard Orgasmist
« Reply #12 on: Mon, 10 February 2014, 20:41:06 »
http://www.youtube.com/watch?v=JyaYVLjlGhg
That is why when you drop a Model-M onto a concrete floor it will shatter/crack the casing, but a Filco just bounces with no damage, trust me I've experimented this when I was loaded back in 2012  :thumb: .
« Reply #13 on: Mon, 10 February 2014, 22:09:06 »
Is there a way to coat ABS plastic to prevent it from yellowing when hit with UV light?
« Reply #14 on: Mon, 10 February 2014, 22:42:01 »
Yes, this is how they are stamped usually. I suspect it has something to do with RoHS.
Yes, but as far as I know, modern plastics don't have the same additives that were used back in the day that turned yellow. I think it has something to do with bromine or whatever was added as a fire retardant then that causes yellowing primarily.
Very interesting. I never knew this. I can only wonder why they would do that.
« Last Edit: Mon, 10 February 2014, 22:45:10 by dorkvader »
Offline pbtforever
« Reply #15 on: Tue, 11 February 2014, 01:28:38 »
Which ones?
