Author Topic: LEDs: High-res photos of various switch LED shapes  (Read 86818 times)
Offline Thumper_
  • Spend all my money.
Re: LEDs: High-res photos of various switch LED shapes
« Reply #50 on: Mon, 30 March 2015, 08:46:41 »
Thanks. Is there a chance that you have a SP DSA PBT key cap and can test if it bottoms out without hitting the LED?
Offline qwack
« Reply #51 on: Mon, 30 March 2015, 08:52:47 »
Unfortunately I do not have this keycap profile on hand. But if height turns out to be a problem it's easy enough to sand/file down the top of the LED (1 mm is largely enough) to avoid this problem (I edited my original answer with that last bit of info).
Pure Pro w/MX Red - [review]
Offline FoC_Tow
  • Brokehlicious
« Reply #52 on: Mon, 30 March 2015, 23:16:51 »
Thx to Photoelectric and qwack for the great comparison shots!
Definitely very helpful information!  :thumb:
This thread should be stickied, IMHO. Great information for anyone working with Cherry MX switch boards. Should I PM Soarer to request this?
+1 Yesh pls Ooby! Maybe this could be added to the tools and resources thread for example =)
Offline deadall127
« Reply #53 on: Fri, 11 November 2016, 16:12:59 »
sorry for the up but do rgb leds exist in 3mm package?
I'm near to finish routing an ISO 105 pcb with 4 pad THT footprint for leds so I'll be enoyed if I can't find what to put on it :/
Offline Gshock
« Reply #54 on: Sat, 05 October 2019, 15:48:47 »
Thank you for posting this.
