Author Topic: From mx Red to mx Blue  (Read 4694 times)
Offline Norz
« on: Thu, 13 February 2014, 16:20:44 »
So I own a K90 with MX Red and decided I wanted to get a custom keyboard from WASD. I didn't get the opportunity to really test MX blue, only through the sample kit but really liked it, so i ordered it with MX Blue.
The clicky feeling of the MX blue is awesome, but i'm afraid the need for more pressure compared to mx reds make my fingers hurt in the long run. I only received the keyboard today and have been using it for a few hours, but it feels pretty "heavy".
Is there any chance the keys gets a bit less heavy once ive used the keyboard for a few days ? Is it a standard feeling that should disappear after a few days ? Anyone experienced the switch from red to blue before and has any thoughts in that regard ?
Thanks !
Offline lcs
  • Lover of Grape Drank
  • はやく
Re: From mx Red to mx Blue
« Reply #1 on: Thu, 13 February 2014, 16:23:21 »
Perhaps it is just a matter of you getting used to the blues.
If you don't, you can always swap the springs, if you don't mind desoldering the switches.
Offline ianxblog
  • no
« Reply #2 on: Thu, 13 February 2014, 16:24:29 »
When you come from a light switch like reds, you got to stay at it 1 week as much and you will be like home, as far as actuation force goes.
MX Blues aren't even a heavy switch. Blacks or buckling springs are.
Offline IvanIvanovich
  • Mr. Silk Underwear
« Reply #3 on: Thu, 13 February 2014, 16:28:44 »
Red and blue have almost same actuation force. They use the same springs. Blue need more preload though, due to the click mechanism... you may find yourself bottoming more hard due to more preload and then it collapsing. Probably just take a little to get used to it.
Offline Candyflip
« Reply #4 on: Thu, 13 February 2014, 16:28:55 »
Yes I think its just getting used to blues. Swapping springs I would not recommend since I believe they use the same springs, the stem is what makes the weight difference (correct me if I am wrong).
To OP: I think blues will eventually break down and lose slightly of the click they have but I am not sure about the pressure needed to actuate, I am quite used to them even tho I like the lightness of the reds too.
Offline Norz
« Reply #5 on: Thu, 13 February 2014, 16:30:06 »
Alright, thanks for all the quick posts so far
you guys are awesome
Offline 1pq
  • Hipster Doofus
« Reply #6 on: Thu, 13 February 2014, 16:53:56 »
They will also lighten up a good deal with usage.
main kbs:  87UB (55g)  Custom Filco TKL (62g clears)
WTS JD40, Custom Ergoclear Filco
WTB ROHS Red BBv2 (Topre), OG EK Tri-Color Skull (TOPRE)
Offline Norz
« Reply #7 on: Thu, 13 February 2014, 17:29:40 »
Oh i forgot to mention
My keyboard came with the thinner version of o-rings. 0.2mm, red.
Do those help ? make no difference, or in the contrary require a bigger pressure for the key to activate ?
Might as well ask, in case..
Offline ianxblog
  • no
« Reply #8 on: Thu, 13 February 2014, 17:31:26 »
I don't really know, but maybe they're forcing you to bottom out, or almost do it, and therefore you would need more force.
It's matter of trying. Remove one keycap and take off the o-ring. Put it back in. compare.
If you're not sure, take some letters like QWERTY and try with more than 1 finger. :)
Offline Norz
« Reply #9 on: Thu, 13 February 2014, 17:38:27 »
yeah maybe.
Ill try that thx !
Offline varslot
    • Portfolio
« Reply #10 on: Thu, 13 February 2014, 18:37:20 »
I also recieved my Ducky Shine 3 today with MX blue, comming from SS 7G MX black. I can't really compare myself to others, because I have really strong fingers since I've played guitar for almost 12 years. MX Blue feels really nice, even though they are light to press compared to the MX back, the bump makes it perfect.
Ducky Shine 3 (MX blue)
HHKB Pro 2 Type-S
Offline aref
« Reply #11 on: Thu, 13 February 2014, 18:47:20 »
Cherry MX Blue switches require very little down force, just a tad more than MX Red switches, and are supposed to peak at 60 grams; where a Red switch is a constant 45 grams. You may prefer a Realforce variable key-weight keyboard. I don't know of any switch between Reds and Blues; there's only a 5-gram increase when actuating an MX Blue, compared with an MX Red. But, the Blue switch does have an increase in gram-weight when actuated, if you take the switch through its entire 4mm travel. Perhaps you should try some soft o-rings or soft landing pads (Elite Keyboards) on your MX Blue keyboard.
Offline Norz
« Reply #12 on: Thu, 13 February 2014, 19:13:35 »
Well I do have soft o-rings :)
When I compare my mx red keyboard with the new mx blue i feel like the blue switches are easily twice as hard. So maybe the keyboard just need some using for the switches to settle and soften a little ?
Offline Polymer
« Reply #13 on: Thu, 13 February 2014, 19:37:11 »
Just remember that actuation force is only where pressure needed at actuation.  It doesn't take into any bump you have to overcome to get there.
Which is why both MX brown and MX blue take more force than MX red to get to actuation.
With MX Brown, you need to overcome the bump which is about 55g but a short bump..it then actuates at 45g.  That little bump is why it takes slightly more force.
In the case of MX blues, it has a slightly longer bump and you need 60g.
With MX Reds it starts off at 30g and then goes up in linear fashion to get to actuation at 45g.  At bottom out you're approaching 60g.
Same spring but the slider will change how it feels and how much force it takes to press down.  Blues are definitely heavier than reds....
But that said, you'll get used to it..they're not that much heavier...reds are just, imo, rather light..
Offline exitfire401
  • The Force is Re/\l
« Reply #14 on: Thu, 13 February 2014, 21:06:31 »
When I went from red to blue, it took me about 2 weeks to get used to the difference in both sound and pressure. I'd suggest giving it about the same window of time before you decide if you really like them or not. The switch from linear to tactile is massive, but well worth it imho.
Offline Linkbane
« Reply #15 on: Thu, 13 February 2014, 21:10:59 »
I started Red and went to Blue as well. I love Blues now, but it did feel slightly heavier at first. The switches definitely do 'break in', though, and I feel like old Blues are better than the heavy, fresh ones. One important point is that if you use Blues and want to type, it's important to learn not to bottom out, or the point of tactility is lost. It'll make you much faster and it's a lot better for your fingers.
Quickfire TK MX Blue Corsair K60 MX Red Ducky Shine 3 Yellow TKL MX Blue Leopold FC660C
Current best: 162 wpm.
Offline aref
« Reply #16 on: Thu, 13 February 2014, 22:39:16 »
This is an interesting post. I didn't know MX Red switches were initiated with 30 grams. I was, wrongly, under the impression the switch was 45g from the onset. Thanks for the clarification.
Offline paldepind
« Reply #17 on: Fri, 14 February 2014, 02:25:35 »
And that is why it's called a linear switch and not constant like you said. The force linearly increased with the travel distance as shown in this diagram. Had it been constant the diagram would have shown a straight horizontal line.
Offline Linkbane
« Reply #18 on: Fri, 14 February 2014, 02:35:02 »
He said that he thought it was 45g from the initial press, not that it required uniform force. In that case it would be a rubber dome, collapsing at the same time.
Offline Norz
« Reply #19 on: Fri, 14 February 2014, 04:33:00 »
You guys can think of any artificial, efficient way to "break in" the keys ? I mean something faster than typing a whole book :p
Also I wonder if i'm not too easily bottoming out due to the 0.2 red and if that's not something that makes my finger hurt a bit, more than the pressure required to activate the click..
Then again, i shouldnt bottom out too easily on mx blue if i'm used to mx red right ?
Offline Linkbane
« Reply #20 on: Fri, 14 February 2014, 10:19:26 »
I wouldn't necessarily say that. I still bottomed out all the time after switching from my Reds because I was used to bottoming out (or I couldn't be sure of the key registering), and it took me a lot of conscious practice to almost always not bottom out. I couldn't say if there are any ways to break in the keys, but I actually do like the Blues on my cheap TK more than I do those on the Ducky because they feel a lot lighter. I got used to it, but it took over a week.
Offline Norz
« Reply #21 on: Fri, 14 February 2014, 13:26:44 »
I'm gonna give it a full week starting from this week end, and if i don't get used to it i guess ill try to trade it for a MX Red of similar quality (WASD, Filco, Ducky etc) on this forum. Really sucks because with the shipping fees US > Switzerland, the custom fees etc it really costed me quite a bit.
Offline 1pq
  • Hipster Doofus
« Reply #22 on: Fri, 14 February 2014, 14:13:22 »
Welcome to WalletHack!
Offline paldepind
« Reply #23 on: Sat, 15 February 2014, 03:00:02 »
No, that is not what he said.
Which is the same as saying it requires a uniform force which was what I was correction. A red switch has a linear increase in force, not a constant/uniform force.
Offline Wildcard
  • When caffeine isn't enough
« Reply #24 on: Sat, 15 February 2014, 14:31:52 »
Why switch from Red's to Blue's, just use them both :)
Offline Norz
« Reply #25 on: Sat, 15 February 2014, 14:42:52 »
Sadly I can't use the Blues. If my hands are well rested I start typing and zomg, feels so good. It lasts a few minutes and then I very quickly can feel how tiring it is for my fingers.
I can't start a thread in the marketplace section yet, but yeah, i'm gonna have to sell my WASD ISO 88 keys (TKL) board. Or trade it for some similar quality board, with MX Red. Has to be ISO 88 keys.
If anyone's interested, can always shout me a pm !
Offline Tony
« Reply #26 on: Sun, 16 February 2014, 06:34:57 »
I have both red and blue. To switch between them requires conscious change in typing force (blue is considerably 10g heavier). Plus you have to get used to the knuckle sound and bump of blue.
Offline Norz
« Reply #27 on: Sun, 16 February 2014, 06:39:58 »
You're right, but as far as im concerned it's mostly a weight concern really. Rest I can adapt to.
Ironically I can totally see how MX Blue are so SO good because that's how I feel for a couple minutes once I start typing. Sadly, it doesn't last..
Offline Norz
« Reply #28 on: Sat, 22 February 2014, 10:34:10 »
... fast forward a few days later
I ended up removing the sound dampeners because why not. Well, i don't know if they were not correctly installed (received keyboard with o-rings already attached to key caps) but my god, such a difference. It's like the keys are 3x lighter. Never suspected it could really make a difference.
That's all i needed to really start liking MX Blue. It's definitely awesome to type, now i'm just not sure i wont prefer gaming on MX red. And since i do a lot of both it's gonna be a tough choice..
Offline lonedruid
  • Red switch fan
« Reply #29 on: Sat, 22 February 2014, 12:36:48 »
OMG OP norz, you are ****ing just like me.
Even though i enjoy typing on my reds, blues, and hhkb topre,_now i am gonna say something sacrilegious in the holy keyboard land that is geekhack_i always find myself finding relief in going back to enjoying myself a day or two of light typing with my good old rubberdome keyboards.
WHen i use my ducky blues, after a day or two i find it too heavy then, find myself switching back to my steelseries reds just because the blues proved to be too heavy despite me liking the whole blue-clicky thing.
I must say, i am now quite used to the hhkb topre ald, i dont find them heavy anymore, especially when i am typing really fast: the whole keyboard seems to come together and molds itself responsively to my flow of typing and become one with my hand.
But blues man, still heavy.At first, i thought, it is the ducky shine 3's double pcb metal plate thing , that makes it more sturdy and make the keys heavy. After i saw your post, i guess blues are indeed heavy, regardless of brand or board.
Yea, to answer op's question, i dont think you will get used to the whole heavy-switch thing. I have been typing awhile on my blues now(gaming_which means i type alot:i play dota 2 invoker alot which means i even type more keys than average dota player)and i still find them heavy to my taste.
Norz , may be it is just that our fingers are slender and not enough strength when we type. Or may be we wank too much, Who knows?  ;D
Steelseries 6gv2 red switch
Ducky shine 3 TKL blue switch http://i.imgur.com/5LcUxh.jpg
HHKB Professional 2 no-blank http://i.imgur.com/JSIa1.pngk
Offline Norz
« Reply #30 on: Sat, 22 February 2014, 14:25:59 »
@lonedruid
If you read my last post you'll see that removing o-rings to use "naked" blue switches made a BIG difference though ! They're much much lighter now, to a point i really started to like them. Since its probably inferior for gaming tho, it's now all about whether i want my keyboard to be more gaming or typing oriented. Tough choice..
