Author Topic: Random LED's lit on Ducky Shine 3  (Read 1857 times)
Offline adion227
« on: Fri, 14 February 2014, 15:10:33 »
So last night, I accidentally spilled some water on my ducky shine 3 and this morning I noticed that there were random LED's lit up.
For the most part, the keyboard works fine except there was an 5minute incident where the keys that have these LEDs lit up were not working then shortly after that the whole keyboard was unresponsive. Anyone knows whats wrong or how to fix it? Thanks
Offline Lastpilot
  • Power stance
Re: Random LED's lit on Ducky Shine 3
« Reply #1 on: Fri, 14 February 2014, 19:14:32 »
I'm seriously not trying to sound sarcastic here, but if I had to guess, permanent water damage would be my guess. Especially if you spilled it while LED's were running and didn't try to dry out your keyboard [typical 24+ hours in rice] before plugging it in again, this would have caused permanent damage exactly as you describe. The first thing I would try is drying it out for maybe the next 48 hours and then trying again?
http://geekhack.org/index.php?topic=51090
http://geekhack.org/index.php?topic=54776
http://geekhack.org/index.php?topic=54173
http://geekhack.org/index.php?topic=54338
« Last Edit: Fri, 14 February 2014, 19:21:21 by Lastpilot »
Offline adion227
« Reply #2 on: Fri, 14 February 2014, 22:51:12 »
Yeah I figured its the water but it wasnt even that much water. I'll try to dry it out though. Thanks
