Author Topic: Alps RGB Mods  (Read 3175 times)
Offline Pacifist
  • on hiatus
Alps RGB Mods
« on: Fri, 14 February 2014, 23:48:52 »
Does anybody know if there are ALPS RGB mods? Google search got nothing.
If no one makes prefabbed RGB mods, does anyone know how effective RIT dye is on gray keys?
Re: Alps RGB Mods
« Reply #1 on: Sat, 15 February 2014, 00:48:00 »
SP can do ALPS keys, but I do think RGB mods for alps exist, I think I rememeber seeing them on a kingsaver or something.
Offline nuclearsandwich
Re: Alps RGB Mods
« Reply #2 on: Sat, 15 February 2014, 01:25:50 »
If the kingsaver you're referring to was in the classifieds from Sherryton a while back those RGB were dyed by their owner.
Offline Pacifist
  • on hiatus
Re: Alps RGB Mods
« Reply #3 on: Sat, 15 February 2014, 01:34:16 »
Ah good to know. I will figure out how to use SP's GB system and start a GB for everyone. Seems like these aren't that common
Offline IvanIvanovich
  • Mr. Silk Underwear
Re: Alps RGB Mods
« Reply #4 on: Sat, 15 February 2014, 07:22:03 »
I don't see many... but I do see often R G B legend on beige/light grey doubleshot. It seem to be the more common way it was done on Alps.
Offline terrpn
  • Alpha Geezer
  • - Buy Vintage -
Re: Alps RGB Mods
« Reply #5 on: Sun, 16 February 2014, 11:04:40 »
 :thumb:
that would be great :thumb:
most should  be 1.5's.......
Luga G80-1865/MX Reds + Dolch G80-1813/MX Blues + G80-3700HQAUS + DK9008G2 Pro/MX Browns Thick PBT + DK9008G2 Pro/MX Clears Thick PBT +  QFR TKL/Ghetto Greens + Cherry G80-1800/MX Blues + IBM Model M SSK Bolt Modded + IBM Model M + IBM Model F + IBM AT F + Cherry G80-1000 (HAD)/MX Vintage Blacks + Razer BWU/MX Blues + Leading Edge DC2214/Blue Alps + Compaq MX11800/Browns + Chicony 5181/Monterey Blues + Chicony 5161/MX Black Cherry Clone + Focus 2001/White Alps + Chicony 5191/White Futabas + Olivetti ANK27-101 + Dell (Old Logo) AT101/Black Alps + NMB RT8255C+/Black Space Invaders + Unitek K260/Green Alps + Apple M0116/Orange Alps + AEK II M3501/Cream Alps + AEK M0115/Orange Alps + NEC  APC412/Blue Sliders + NEC APC410/Blue Sliders + Omnikey /White Alps + Wang/Yellow Alps (Omrons) + Laser/White SMK + Fame/Blue Aruz + AEK II M3501/Salmon Alps + Zenith ZKB-2R/Green Alps + Wang 724/Orange Alps + DK1087/Green Alps + Zenith ZKB-2/Yellow Alps + Dell Old Logo AT101/Salmon-Pink Alps + Leading Edge AK1012/White SMK's + Magitronic SK-1030/White (Linear) Futaba's + Packard Bell/White (Clicky) Futaba's + Datacomp DFK101/White  Alps + SGI AT101/Dampened White Alps + NMB AQ6RT-72511/Grey Space Invaders (Hi-Tek) + Datacomp/Blue Alps + Phillips 2812/White Space Invaders (Linear) + Dah Yang K251/Vintage MX Blues + Chicony 5161/DS Caps/Vintage MX Blue + Archie-NMB AQ659ZRT-725/Black Space Invader (Tactile) + IBM Model M 71G4644 (RD) Bolt Modded with Soarers Converter + IBM Model M Silver Label 1390131 + Cherry G80-1501/Vintage MX Clears + Focus FK8000/Linear Futabas + Gateway 2000 Anykey Programmable/Maxi-Switch + Dell GY13PVAT101/Dye Sub Caps/Salmon Alps + Chicony 5161/White Alps + AST K0B101/Slider over RD + Qtronix QX-32H + Everex/NMB RT8255CW+ Black Space Invaders-Split Erase + Tandon/NMB AQ659ZRT-101A/Beige Space Invaders + Cherry G80-11903 MNRUS/MX Blacks + Apple IIGS A9M0330/SMK Whites + WYSE PCE/MX Blacks + Chicony 5160AXT/Clicky Futaba + Cherry G80-0528/Vintage MX Blacks + Dell AT101/Linear (Modded) Black Alps+Topre 55g
Offline esoomenona
  • Gnillort?
Re: Alps RGB Mods
« Reply #6 on: Tue, 04 March 2014, 10:21:50 »
Alps RGB GB IC?
Offline terrpn
  • Alpha Geezer
  • - Buy Vintage -
Re: Alps RGB Mods
« Reply #7 on: Tue, 04 March 2014, 13:35:16 »
here here............. :thumb:
Offline jacobolus
Re: Alps RGB Mods
« Reply #8 on: Tue, 04 March 2014, 17:53:01 »
Note, SP's Alps caps use costar-style stabilizers, so the shifts won’t work on most existing Alps plates.
Of course, if you’re making a completely custom plate as well, then you should be fine.
Offline jacobolus
Re: Alps RGB Mods
« Reply #9 on: Tue, 04 March 2014, 17:55:29 »
Focus FK-2001s, and similar keyboards, use those Tai-Hao doubleshot caps, and the mods have colored letters on medium gray.
