Author Topic: Found this at a university overstock warehouse for $15. Good Find?  (Read 6155 times)
Offline Regal
« on: Mon, 17 February 2014, 15:06:26 »
http://imgur.com/tASUC4Y
No sticker on the back, so I don't have any idea about specifics. Only problem is that the spacebar sticks every once in a while, but I'm hoping a clean will fix that. Can anyone link me to a thread on how to clean it?
-Regal
Offline Pacifist
  • on hiatus
Re: Found this at a university overstock warehouse for $15. Good Find?
« Reply #1 on: Mon, 17 February 2014, 15:09:27 »
good find
remove keycaps put in denture tablets
clean under the keycaps with qtips
« Reply #2 on: Mon, 17 February 2014, 15:10:43 »
XT Model F by IBM, a capacitive buckling spring keyboard. Good find, especially for $15. Those are some of my favorite switches, I don't like the layout as much. You can mod it though. And to answer your question, you might like these threads:
fohat.digs' Model F bolt mod thread - has info about F's in general
phosphorglow's Model M reconditioning video - Not exactly the same as an F but it's got some great info
« Reply #3 on: Mon, 17 February 2014, 15:26:28 »
That spacebar is a woolly booger. See if you can clean everything else with vacuum and Q-tips, but don't pull it off unless you have to.
- D Trump 2026-10-24
Offline Regal
« Reply #4 on: Mon, 17 February 2014, 15:46:18 »
Yeah, I'm a bit nervous about taking off the spacebar. I've never done taken apart a keyboard before and lack most tools. I'll save the project for next weekend and will do some more research on how to do a good job so I don't botch things up.
 I tested it out and at first I thought it didn't work, and I was dissappointed,  but then I tried again, and it worked! :D
-Regal
Offline Pacifist
  • on hiatus
« Reply #5 on: Mon, 17 February 2014, 15:48:41 »
-Regal
You have a computer that uses XT scancodes?
Offline Regal
« Reply #6 on: Mon, 17 February 2014, 16:00:21 »
Nope, I have a KE-XTUSB. It actually just came in the mail today. I got my first mechanical keyboard just the other day and realized that I needed an XT adapter to use it, so purchased one. Went out today on a whim to the surplus store and found the other keyboard and bought it because I liked it. Haggled them down to $15 from $30 because of the sticking spacebar. When I got back my adapter was here and I tested out both keyboards and both seem to work! And now I am talking with you all :) Next thing that I need to figure out is how to program keys, as the arrow keys on my first one aren't registering.
-Regal
Offline berserkfan
« Reply #7 on: Mon, 17 February 2014, 20:59:55 »
-Regal
Let me repeat this because it's so important.
Never take off the spacebar.
Or you are in for a damn pain in the ass. Don't listen to the folks who say you can put it back by just pulling on a dental floss string. These guys have like 1000 posts and years of modding experience. For clumsy idiots like me, and for noobs like you, spacebar can never be put back once it comes off. I tried the dental floss thing for at least 30 minutes and gave up.
Offline Regal
« Reply #8 on: Mon, 17 February 2014, 21:03:27 »
Geez, good timing :) I was thinking about doing that very thing right now!  :confused:
Offline Regal
Can I fix it?
« Reply #9 on: Tue, 18 February 2014, 11:13:53 »
Gah, now it's not working. I don't think it was the cleaning that did this, as it was temperamental to begin with, but I wonder what could be the problem? Every once in a while it will register, but now it has yet to register at all today. Perhaps it's the cable? Anything you'd recommend I try to either test to see what the problem is or fix it? I'm talking about the model f by the way.
Thanks! This whole keyboard subculture thing is awesome!
-Regal
Offline ebacho
« Reply #10 on: Tue, 18 February 2014, 11:47:06 »
If you're so inclined, you could try to make a Soarer and see if the converter's the issue.  It costs about $28 in parts and an hour or two of your time, even if you've never done soldering before.
http://geekhack.org/index.php?topic=17458.0
Offline Tony
« Reply #11 on: Wed, 19 February 2014, 00:29:32 »
You should buy a Unicomp for spare parts before trying to fix an IBM model F. Sooner or later the cost of repair will exceed the cost of a Unicomp anyway.
Offline ebacho
« Reply #12 on: Wed, 19 February 2014, 00:42:13 »
If you need springs, caps, etc it's probably cheaper to pick up a terminal board off ebay for ~$20-25.  Unless you were talking about replacing the F with an M, then I don't agree in the slightest; a M feels worlds different than a F, no matter which version of the F you have.
Offline Novus
  • Formerly the1onewolf
  • Mondai nothing~
« Reply #13 on: Wed, 19 February 2014, 00:50:23 »
Buy it.
Get a friend.
Get a gun.
Get a video camera.
Go to a safe remote area.
While your friend films, proceed to shoot that keyboard several times.
Post videos of the said deed.
Savor the dismay of everybody here.
« Reply #14 on: Wed, 19 February 2014, 00:56:01 »
Buy it.
Get a friend.
Get a gun.
Get a video camera.
shoot all day and KB is still fine.
Dismay at wasting expensive ammo shooting unbreakable object.
Offline Novus
  • Mondai nothing~
« Reply #15 on: Wed, 19 February 2014, 01:07:13 »
Gotta put two between the spacebar.
« Reply #16 on: Wed, 19 February 2014, 06:38:56 »
You guys are just weenies about the spacebar. Sure, it is a nuisance and PITA, and will probably take multiple attempts to get it right, but so are numerous other components of the process.
Akimbo has a guide for adjusting the force of the spacebar, while you are in there, you can do that, too.
Offline Regal
« Reply #17 on: Wed, 19 February 2014, 16:24:16 »
Yes, I'm prone to suspecting it to be immune to anything less than the fires of Mount Doom. I suspect bullets would only anger it, so I'll abstain from that. I'm actually considering the Soarer plan, but the casual way that ebacho refers to it taking no more than "an hour or two" can probably safely be translated as it taking somewhere between a month and never. ;)
-Regal
Offline NAMESPACE
  • YES, I ALWAYS WRITE IN CAPS.
« Reply #18 on: Wed, 19 February 2014, 19:01:41 »
Just beware the PING!
Cool find. Wish I had one. :thumb:
« Reply #19 on: Wed, 19 February 2014, 19:08:00 »
Wish I had one.
Toss in a few more twenties and get an AT F.
That is 1000% preferable.
Offline Pacifist
  • on hiatus
« Reply #20 on: Wed, 19 February 2014, 19:14:57 »
How much ping does F have?
« Reply #21 on: Wed, 19 February 2014, 19:25:01 »
Triple the amount of M.
Offline Pacifist
  • on hiatus
« Reply #22 on: Wed, 19 February 2014, 19:26:00 »
:Shudder:
How much would the floss mod reduce F ping?
« Reply #23 on: Wed, 19 February 2014, 19:37:02 »
This moves into very esoteric opinion territory.
I agree that an unflossed F borders on the "shudder" sensation, so I have flossed all of mine. To me, the flossed F is perfect. The deep metal rumble of the heavy plates is unaffected, while the annoying overtones are attenuated.
Neither flossed nor unflossed M has the right sound or feel to me anymore, I think that the so-called "ping" is actually pretty lifeless because of the plastic barrel plate, and  flossing deadens the sound overall but has little effect on the overtones because they never "rang" (maybe "sang" would be a better description) to begin with.
In essence, a Model F sounds and feels alive, even when flossed, in a way that a Model M seems to feel lifeless, at best.
« Last Edit: Wed, 19 February 2014, 20:52:30 by fohat.digs »
Offline Pacifist
  • on hiatus
« Reply #24 on: Wed, 19 February 2014, 19:42:55 »
Neither flossed not unflossed M has the right sound or feel to me anymore, I think that the so-called "ping" is actually pretty lifeless because of the plastic barrel plate, and  flossing deadens the sound overall but has little effect on the overtones because they never "rang" (maybe "sang" would be a better description) to begin with.
In essence, a Model F sounds and feels alive, even when flossed, in a way that a Model M always feels lifeless, at best.
Sweet! Thanks for the help!
Offline kleme
« Reply #25 on: Wed, 19 February 2014, 20:58:50 »
very good find! just find it a good home!
Offline Regal
« Reply #26 on: Wed, 19 February 2014, 22:28:47 »
Thanks Kleme, I want to fix it before I do anything further with it though. It is a rather temperamental device. A lot of the time it doesn't register, while other times it will. I just plug it in and unplug it, then plug it back in, and once every 20 times or so it will register and I can type a few sentences and then it will stop registering again. I have no idea what the problem is.
-Regal
Offline Regal
« Reply #27 on: Wed, 19 February 2014, 22:47:09 »
P.S. Another interesting thing I found is that if I hold down some keys and slowly plug it in it will register and lock in, which makes me think it might be the cable that's the problem, and nothing internal, which makes me hopeful that making a Soarer might fix the problem (if my grasp on what a Soarer is is accurate). Any other ideas before I try that would be greatly appreciated as well though too. :)
Thanks,
Regal
Offline handystack
« Reply #28 on: Thu, 20 February 2014, 10:33:09 »
Once again, for emphasis:
Don't remove that spacebar unless you absolutely have to!
Offline tipo33
  • "Ski"
« Reply #29 on: Thu, 20 February 2014, 12:27:59 »
That is a GREAT find,  I have been searching for a Model F for a long while..
KM4COL    R.I.P.  SmallFry
Offline dgreekstallion
  • B.S. Fiend
« Reply #30 on: Thu, 20 February 2014, 22:56:48 »
Arg! More fuel to the fire about whether or not I should floss-mod my 122.
Recent keyboard fanatic.
Model F-122 convert.
Offline Pacifist
  • on hiatus
« Reply #31 on: Thu, 20 February 2014, 23:03:33 »
You shouldn't floss mod it. Send it to me and I will do so for you. It'll take a year for me to do it tho :))
Offline Techno Trousers
  • ʘ_ಠ
« Reply #32 on: Thu, 20 February 2014, 23:10:44 »
Go for it. Unlike most mods around here, flossing is 100% reversible. It'll probably be easier to undo it than it will be to do it, in fact.
« Reply #33 on: Fri, 21 February 2014, 06:29:13 »
It is fairly easy to undo if you have the beast apart. Only taking the keycaps off you will have to fiddle with it a lot more.
If your floss sections are as tall as the springs, you can pick them out with a sharp pair of tweezers. Below the top of the spring - much harder.
My experience is that perhaps up to a third of them will fall out if you turn it upside-down and shake, but many will be fairly stubborn. Straightening out a small fish hook is probably the most effective, but don't pull too hard and stretch the spring.
Unless you simply like the loud ringing overtones, you are likely to be happy with the mod. An un-modded F is overbearing to me.
Remember that when you are inserting the floss, if you don't hit it on the 1st or 2nd try, you will probably have flared out the weave and will need to cut it back to get a tight fresh edge.
Offline CatNip :3
  • bouncy bouncy
« Reply #34 on: Sun, 23 February 2014, 02:11:28 »
Great find! I love that fancy lay-out. :D
