Author Topic: Artisan Mousepad - recommend me one!  (Read 61939 times)
Offline combataran
Re: Artisan Mousepad - recommend me one!
« Reply #100 on: Wed, 25 June 2014, 19:00:57 »
Hien is even rougher in texture, so I'd rule out that one.
Shiden is very smooth, but the Hayate should be even smoother.
my vote goes to Hayate :p it's really nice, definitely an improvement over QcK!
Great, thanks!
Cherry G80-1000HFD | CM Storm Spawn | Keypuller.com - Key Caps News & Database
Offline combataran
« Reply #101 on: Fri, 18 July 2014, 07:07:36 »
I just had carpet burn on my QCK+. I gotta get my Hayate soon. Or is there something softer?
Offline munch
« Reply #102 on: Fri, 18 July 2014, 10:28:48 »
Hayate x-soft is very nice and soft :p but if you rub fast enough, any cloth pad will give you a rug burn. I do think the rubber of the Artisan pads is a LOT better though.
Offline combataran
« Reply #103 on: Fri, 18 July 2014, 11:42:40 »
It's CS:GO. You gotta rub fast ;D Would the Shiden actually make things easier, or at least not encourage me to rub the pad so quickly? Sometimes when things get intense I kinda push down on the mousepad hard, plus the high speed rubbibg really takes a till on my palm. There's a callus from all the years of gaming already.
Offline munch
« Reply #104 on: Fri, 18 July 2014, 11:45:30 »
ahh, yeah that makes more sense. perhaps you'd want a faster pad then. ;) the QcK isn't very fast.
Offline combataran
« Reply #105 on: Fri, 18 July 2014, 13:04:18 »
Wouldn't a faster pad mean a harder pad, which might also mean a rougher pad?
Offline davkol
  •  Post Editing Timeout
« Reply #106 on: Fri, 18 July 2014, 13:31:37 »
Not really, it's a matter of cloth texture in the first place. My Corsair MM200XL is definitely smoother/faster than QcK, but still soft (rubber base thickness is right between ordinary QcK and QcK Mass/Heavy). If you want something even faster, you have to go hard though, but I don't think it's that bad with pads that have a rubber base and a plastic surface (like say Roccat Sota).
Offline combataran
« Reply #107 on: Fri, 18 July 2014, 23:37:51 »
So...a softer pad like the Hayate, or a hard one like the Shiden?
Offline Glenn315
  • Hey
« Reply #108 on: Mon, 21 July 2014, 18:23:45 »
I've been using the Hayate for about a month now, and I love it.
Offline munch
« Reply #109 on: Mon, 21 July 2014, 20:46:07 »
well, the Shiden is very different from the QcK (you have one no? :p) so I don't think that is necessary.
a hard pad doesn't mean faster, generally, so a Soft one should be fine. like, soft Raiden is super fast and still soft. very very smooth.
